Canon Support for PowerShot SD850 IS | Canon U.S.A., Inc.
PowerShot SD850 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
| Type | Compact digital still camera with built-in flash, 4x Optical/4x Digital/16x Combined Zoom with Optical Image Stabilizer (IS) System |
Image Capture Device
| Type | 8.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD) |
| Total Pixels | Approx. 8.3 Megapixels |
| Effective Pixels | Approx. 8.0 Megapixels |
Lens
| Focal Length | 5.8-23.2mm f/2.8-5.5 (35mm film equivalent: 35-140mm) |
| Digital Zoom | 4x |
| Focusing Range | Normal: 1.6 ft./50cm-infinity Macro: 0.79 in.-1.6 ft./2-50cm (WIDE), 1.3-1.6 ft./40-50cm (TELE) Digital Macro: 0.79 in.-1.6 ft./2-50cm (W) |
| Autofocus System | TTL Autofocus |
Viewfinders
| Optical Viewfinder | Real-image optical zoom viewfinder |
| LCD Monitor | 2.5-inch low-temperature polycrystalline silicon TFT color LCD |
| LCD Pixels | Approx. 230,000 pixels |
| LCD Coverage | 100% |
Aperture and Shutter
| Maximum Aperture | f/2.8 (W) - f/5.5 (T) |
| Shutter Speed | 15-1/1600 sec. |
Exposure Control
| Sensitivity | Auto, High ISO Auto, ISO 80/100/200/400/800/1600 (Standard Output Sensitivity. Recommended Exposure Index) |
| Light Metering Method | Evaluative*, Center-weighted average, Spot** * Control to incorporate facial brightness in Face Detection AF ** Metering frame is fixed to the center Program AE; AE lock available |
| Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance
| White Balance Control | Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom |
Flash
| Built-in Flash | Auto, Auto w/ Red-eye Reduction, Flash On, Flash On w/ Red-eye Reduction, Flash Off |
| Flash Range | Normal: 1.6-11 ft./50cm-3.5m (W), 1.6-6.6 ft./50cm-2.0m (T) (when sensitivity is set to ISO Auto) |
| Recycling Time | 10 sec. or less (battery voltage=3.7V) |
| Flash Exposure Compensation | N/A |
Shooting Specifications
| Shooting Modes | Auto, Camera M, Special Scene (Portrait, Foliage, Snow, Beach, Fireworks, Aquarium, Underwater, Indoor, Kids & Pets, Night Snapshot, Creative Light Effect), Color Accent, Color Swap, Digital Macro, Stitch Assist, Movie |
| Self Timer | Activates shutter after an approx. 2-sec./10-sec. delay, Custom |
| Wireless Control | Not available |
| Continuous Shooting | Approx. 1.3 fps |
Image Storage
| Storage Media | SD Memory Card, SDHC Memory Card, MultiMediaCard |
| File Format | Design rule for camera file system, DPOF Version 1.1 |
| JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural)) |
| Number of Recording Pixels | Still Image: 640 x 480 (Small), 1,600 x 1,200 (Medium 3), 2,048 x 1,536 (Medium 2), 2,592 x 1,944 (Medium 1), 3,264 x 2,448 (Large), 3,264 x 1,832 (Widescreen) Movie: 640 x 480 / 320 x 240 (30 fps/15 fps) available up to 4GB or 60 minutes per clip, 640 x 480 (2 hours at 0.5 fps/1 fps), 320 x 240 (1 min. at 60 fps), 160 x 120 (3 min. at 15 fps |
Number of Recordable Images
| Image data |
Time of Recordable Movies
| Movie data | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Specifications
| Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Histogram, Index (9 thumbnails), Sound Memos, Slide Show, Red-eye Correction, Transition Effects Movie: Normal Playback, Special Playback, Editing |
Erasing Specifications
| Erase Modes | Still Image: single image, select by date, select by category, select by folder, all images Movie: part of movie, all of movie |
Interfaces
| Computer Interface | USB 2.0 Hi-Speed (mini-B jack) |
| Video Out | NTSC/PAL |
| Audio Out | Monaural |
| Other | Memory card slot; direct connection to Canon CP and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
| Power Supply | 1.Battery Pack NB-5L 2.AC Adapter Kit ACK-DC30Still Image: approx. 230 shots (NB-5L/LCD on)*; approx. 700 shots (NB-5L/LCD off)Approx. 360 min. (NB-5L) * The above figures comply with CIPA testing standards and apply when a fully-charged battery is used. |
| Power Source | 1.Battery Pack NB-5L 2.AC Adapter Kit ACK-DC30 |
| Shooting Capacity | Still Image: approx. 230 shots (NB-5L/LCD on)*; approx. 700 shots (NB-5L/LCD off) |
| Playback Time | Approx. 360 min. (NB-5L) * The above figures comply with CIPA testing standards and apply when a fully-charged battery is used. |
Physical Specifications
| Operating Temperature | 32-104°F/0-40°C |
| Operating Humidity | 10-90% |
| Dimensions (W x H x D) | 3.56 x 2.22 x 1.04 in./90.4 x 56.5 x 26.4mm |
| Weight | Approx. 5.82 oz./165g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
