Canon Support for PowerShot V10 | Canon U.S.A., Inc.
PowerShot V10
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Video camera |
| Image Processor | DIGIC X |
| Type | 1-inch high-sensitivity CMOS sensor (back-illuminated) |
| Effective Pixels | During Movie recording (Full HD, 16:9) - Approx. 13.1 megapixels During Still photo shooting - Approx. 15.2 megapixels |
| Total Pixels | Approx. 20.9 megapixels |
| Color Filter System | RGB primary color filters |
| Focal Length | During Movie recording (Full HD, 16:9) - 6.6 mm (Approx. 19 mm equivalent, 35mm format equivalent) During Still photo shooting - 6.6 mm (Approx. 18 mm equivalent, 35mm format equivalent) |
| Angle of View | During Movie recording (Full HD, 16:9) - 97.5° During Still photo shooting - 100.2° |
| F-number (max. aperture) | f/2.8 |
| Aperture | f/2.8f/8 |
| Lens configuration | 8 elements in 7 groups |
| Aspherical lenses | 3 lenses, 6 surfaces |
| Optical zoom | None |
| Optical IS | None |
| ND filter | Included (equivalent to 3 stops) |
| Protective glass | Included (no lens barrier) |
| Focusing range | 0.05 m / 0.16 ft. to infinity |
| Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.31* *Supports time offset information |
| Image Format |
| File Numbering | 1. File numbering methods a. Continuous i. The numbering of captured images continues even after you replace the card. b. Auto reset i. When cards are replaced, the numbering is reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card. 2. Manual reset a. Resets the file number to 0001, and creates a new folder automatically. * When manually resetting the file number, folders can also be renamed. |
| Recording Media | (One) microSD card slot Compatible with UHS-I microSD, microSDHC, and microoSDXC memory cards |
| File Size / Number of Shots Available | Please click here for full specifications. *1: Number of shots using a 32 GB card that conforms to Canon testing standards. * File sizes are determined based on Canon testing standards. * File size and number of shots available vary by shooting conditions (such as aspect ratio, subject, ISO speed, and Custom Functions). |
| Movie Recodring Format |
| Movie Recording Size Overview | Please click here for full specifications. | ||||||||||||||||
| Estimated Recording Time, Movie Bit Rate, and File Size | Please click here for full specifications. * Bit rate only applies to video output, not audio or metadata. * Movie recording stops when the maximum recording time per movie is reached. * No audio is recorded for approx. the last two frames with the compression method for movie recording quality setto IPB (Standard) or IPB (Light). Moreover, the video and sound may be slightly out of sync when movies are played back in Windows. |
| Card Performance Requirements | Please click here for full specifications. | ||||||||||||||||
| Movie Color Filters | 14 filters available | ||||||||||||||||
| Smooth Skin Movie | Can record movies with a smooth skin effect | ||||||||||||||||
| Built-in Microphone |
| Audio Noise Reduction | 3-mic noise cancellation | ||||||||||||||||
| External Microphone |
*1: Plug-in power specifications vary by manufacturer. Stereo Microphone DM-E100 is recommended if plug-in power will be used. |
| Digital Zoom | Off / 1.5× / 2.0× / 3.0× * Cannot be combined with image stabilization or auto level. |
| Digital IS | Movie digial IS Supported * Cannot be combined with digital zoom or auto level. |
| Movie Self-timer |
| Remote Control Recording | Supported | ||||||||||||||||
| Maximum Recording Time per Recording |
| Settings | (1) Auto (Ambience priority / White priority) (2) Daylight (3) Shade (4) Cloudy*1 (5) Tungsten light (6) White fluorescent light (7) Color temperature *1: Effective also in twilight and sunset. |
| White Balance Shift | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels * Adjustable in [Color tone] in compatible modes. |
| Focus Method | Contrast detection |
| Focusing Operation | Please click here for full specifications. *1 Activated by the right cross key during output to a single screen over HDMI. |
| Focusing Area | Still photo shooting (with face detection) - Approx. 100% vertical and horizontal coverage Movie recording (with face detection) - Approx. 100% vertical and horizontal coverage Number of AF areas for One-Shot AF (still photos) - Max. 31 areas (7×5; corners not available) |
| Tap-based Subject Selection | Subjects to track are specified by tapping * People only |
| Other | Connect App for Mini PTZ Cam available on compatible
iOS and Android devices. View and transfer images,
control device, change device settings - see app store
for full details Wireless Webcam Utility for Mini PTZ Cam available for Windows. For full details see support pages |
| Type | TFT color, liquid-crystal monitor | ||||||
| Screen Size | 2.0-inch (screen aspect ratio of 3:2) 1.97 in./5.0cm diagonal (1.61 in./4.1cm width, 1.10 in./2.8cm height) |
| Dot Count | Approx. 460,000 dots | ||||||
| Angle of View | Approx. 160° vertically and horizontally | ||||||
| Coverage | Movies - Approx. 100% vertically and horizontally (at an aspect ratio of 16:9) Still Photos - Approx. 100% vertically and horizontally (at L image size and an aspect ratio of 3:2) |
| Brightness Control | Manually adjustable in a range of 15 | ||||||
| Touch-screen Operation | Capacitive sensing Support for: Tap-based subject selection; Touch Shutter (Disable / Enable); Menu selection; Quick Control Menu |
| Tilt | Approx. 180° upward | ||||||
| Shooting Information Display |
| Interface Languages | 31 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Indonesian, Persian, Hebrew, and Japanese) |
| Metering Mode | Evaluative metering 384-zone (24×16) metering using the image sensor |
| ISO Speed in Still Photo Shooting | Manual ISO speed setting for still photos not configurable ISO Auto range for still photos - Auto (ISO 12512800) (in 1/3-stop increments) |
| ISO Speed in Movie Recording | Manual or Automatic ISO Speed Settings
* Expanded ISO speed not available. |
| Type | Rolling shutter, using the image sensor |
| Still Photo Shooting Shutter Speeds | 1/20001/8 sec. * Up to 1.0 sec. depending on the scene. |
| Movie Recording Shutter Speeds | 1/40001/25 sec. * Varies by movie recording mode and frame rate. Manual exposure movies: 1/40001/8 sec. |
| Movie Digital IS | Movie digital IS or movie auto level is available during movie recording. Cannot be combined with digital zoom. Using Movie digital IS results in cropped movies. * Cannot be combined with auto level. * Cannot be use in Smooth skin mode. |
| Auto Level | Keeps the movie level as it is recorded, by rotating the image and extracting a portion. * Cannot be combined with Movie digital IS. * Cannot be used in Smooth skin movie |
| Display Format | Please click here for full specifications. *1: Movie files recorded with other cameras may not be played back, even if they have the same file extensions as used by this camera. |
| Function | The Quick Control screen can be accessed by pressing the button during movie recording. * In still photo shooting, [Image quality] settings are displayed. |
| Custom Functions | None |
| Customize Buttons | button operation in movie recording mode is customizable with the following functions. Wi-Fi/Bluetooth connection Autofocus method Movie recording size Recording level Digital zoom White balance selection Color tone Color filter Digital IS setting Aspect marker Maximize screen brightness (temp) Choose USB connection app |
| Shortcut function | A customized setting screen can be opened by pressing and holding the button. |
| Supporting Standards | Equivalent to IEEE 802.11b/g/n Standards |
| Transmission Method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n) |
| Transition Frequency (Central Frequency) | 2.4 GHz band Frequency: 2412 to 2462 MHz Channels: 1 to 11 channels |
| Security | Please click here for full specifications. |
| Send Images to a Web Service | image.canon: Enables uploading of still photos (JPEG) and movies (MP4) to image.canon servers. From image.canon, images can be sent to specific social media and 3rd-party cloud image services. |
| Standards Compliance | Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology) |
| Transmission Method | GFSK modulation |
| Bluetooth Pairing | Smartphone up to 10 devices; BR-E1 remote controller 1 unit |
| Video Calls | Available * The camera is accessible to software on a computer once connected via USB. |
| Supported Protocols and Data Formats | Video USB Video Class (UVC) supported Video compression format: Motion JPEG Movie recording size: Full HD at 30 fps only Camera control from applications: Not supported Audio USB Audio Class (UAC) supported Linear PCM (48 kHz, 16 bits) Built-in or external microphone (External microphone IN terminal) |
| Streaming Services | Streaming video captured by the camera is possible by selecting a streaming
service icon on the camera to obtain a destination URL. * Linkage with compatible streaming services and other settings are configured by connecting the camera to Camera Connect. * Streamed videos are not saved on the camera. |
| Compatible Services | YouTubeLive FacebookLive * Details on each service are provided on the service website. * As of February 2023. |
| USB Terminal | USB Type-C Equivalent to Hi-Speed USB (USB 2.0) |
| HDMI Out Terminal | HDMI micro OUT terminal (Type D) * Resolution switches automatically * HDMI CEC not supported * Images not displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system |
| Microphone terminal | 3.5mm diameter stereo mini jack |
| Headphone terminal | Not provided |
| Battery | Built-in rechargeable lithium-ion battery * Not user-replaceable. |
| Rated voltage/capacity | |||||
| Recharge cycles | Approx. 500 recharging and usage cycles | ||||
| USB charging time | Approx. 1 hr. 50 min. * To fully recharge a completely depleted battery based on CIPA testing standards using PD-E1 (at room temperature) |
| Start-up Time | Approx. 1.1 sec. |
| Dimensions (W x H x D) | Approx. 2.50 × 3.54 × 1.35 in. / 63.4 × 90.0 × 34.3 mm |
| Weight | Please click here for full specifications. |
| Working Temperature Range | 040°C / 32104°F |
| Working Humidity Range | 10%90% |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
next to your download
