Canon Support for Speedlite 430EX | Canon U.S.A., Inc.
Speedlite 430EX
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.19.15
File Size 4.49 MB
Date 01.04.08
File Size 2.98 MB
Software Development Kit
Flash
Type Mode: E-TTL II, E-TTL, TTL
Compatible Cameras All Canon EOS cameras; PowerShot G series cameras
Guide Number 141 ft./43m (at ISO 100); flash head at 105mm zoom setting
Flash Coverage Fixed condenser lens with inner zoom: (1) Auto Zoom, (2) Manual Zoom, (3) Wide Panel
Zoom positions: 24mm, 28mm, 35mm, 50mm, 70mm, 80mm, 105mm; Indicated by numerals on the LCD's focal length display
Image Size Zoom Control: With cameras compatible with auto zoom, it zooms automatically to match the camera's image size
Number of Flashes Approx. 200 to 1,400, with AA-size Alkaline Batteries manufactured within the last three months or AA-size Ni-MH fully-charged batteries
Recycling Time Approx. 0.1 to 3.7 seconds (AA-size Alkaline Batteries)/0.1 to 2 seconds (AA-size Ni-MH batteries)
Flash Range At ISO 100, with EF 50mm f/1.4
For normal flash: Approx. 2.3-79.7 ft./0.7-24.3m
For high sync speed (EF flash): Approx. 2.3-39.4 ft./0.7-12m
AF Assist Beam Built-in; covers all focus points in EOS cameras up to 9 AF points
Effective range:
At center: Approx. 2.3-32.8 ft./0.7-10m
Periphery: Approx. 2.3-16.4 ft./0.7-5m (in total darkness)
Custom Functions Six user-selectable Custom Functions built-in; set on Speedlite's LCD panel
General
Power Source Four AA-size Alkaline Batteries (6V); Four AA-size Ni-MH (4.8V)
Dimensions 2.8 x 4.8 x 4.0 in./72 x 122 x 101mm
Weight 11.6 oz./330g (without batteries)
Canon Flashes Limited International Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
  1. loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
  2. if equipment is defective as a result of leaking batteries or liquid damage.
  3. if equipment has been serviced or modified by other than our Authorized Agents.
  4. Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
  5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
Equipment covered by this Warranty will be repaired in other countries:
a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
Online Repair
Title Canon Support | Service Notice: Caution Concerning use of Lithium Batteries
Advisory Type
Date 12.16.14
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
