Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 06.27.24
File Size 142.00 B
Software Development Kit
Compatible Cameras EOS cameras equipped with a Multi-function Shoe
Flash Coverage (Focal length; for 35mm full-frame)
14mm Wide Panel: Manual
*Not compatible with EF15mm f/2.8 Fisheye or EF8-15mm f/4L Fisheye USM shooting angles of view
24mm
Zoom
A: Auto
Flash coverage is set automatically, accounting for [Auto zoom for sensor size] and [Light distribution] settings at the lens focal length.
M: Manual
Flash coverage is set manually
[Auto zoom for sensor size] and [Light distribution] settings are not taken into account.
28mm
35mm
50mm
70mm
80mm
105mm
Guide Number The maximum Guide No. is approximately 131.2 ft./40m at ISO 100 and 105mm flash coverage.
-When the extendable wide panel is pulled out, the flash coverage is 14mm.
Minimum Flash Output 1/1024 Minimum flash output is 1/128 when set to high-speed sync. Flash output 1/64 or less via expanded setting.
Continuous Flash count at full output To level 1: 55 times or more To level 2: 65 times or more
Flash firing restriction due to temperature increase
  Level 1 Level 2
LCD Panel illumination Lit in green blinking green
Firing interval (approx.) 10 sec. 45 sec.
Flash Exposure Compensation ±3 stops, in 1/3-stop or 1/2-stop increments. *The Speedlites flash exposure compensation takes precedence if flash exposure compensation is performed by both the Speedlite and the camera. Users who prefer to enable flash exposure compensation by the camera should set flash exposure compensation by the Speedlite to 0. *1: Corresponds to exposure level increments on the camera.
FEB ±3 stops, in 1/3-stop or 1/2-stop increments. *FEB is automatically deactivated after three shots. *Can be used with flash exposure compensation and FE lock. *1: Corresponds to exposure level increments on the camera.
FE Lock Supported
FE Memory Supported Stores the flash output of E-TTL II / E-TTL autoflash and automatically sets the stored output level if users switch the flash mode to manual flash. *Flash output may vary slightly between E-TTL autoflash and manual flash. Colors may vary between E-TTL autoflash and manual flash under the following conditions: *When the color temperature of the Speedlite light differs greatly from that of ambient lighting and flash exposure compensation is set toward the negative end. *When E-TTL balance is set to [Ambience priority]. Differences in colors between E-TTL autoflash and manual flash may be reduced by taking one of the follow steps: *Using the provided color filter. *Setting white balance to an option other than AWB. *When combined with specific cameras, FE Memory is possible by operating the camera buttons (by using the cameras C.Fn of by custom buttons).
Recharge Time
Battery Quick Flash Normal Flash
AA/Alkaline 0.12.2 sec. 0.12.5 sec.
AA/Ni-MH 0.11.3 sec. 0.11.5 sec.
Recharge Level
Normal Flash State when fully charged and the Speedlite can be used without restriction
Quick Flash Can fire, but some restrictions apply:
* Max. intensity is in a range of approx. 1/2 to 1/3 of the fully charged intensity.
*No Quick flash firing under the following conditions:
When P.Fn-01: Quick flash is set to OFF.
When using a camera that does not support E-TTL II/E-TTL autoflash.
When used wirelessly via radio transmission.
When the manual flash output is set in the range of 1/1 to 1/3.2
Charging in progress Does not fire in this state.
Products supporting Wireless second-curtain sync via radio transmission
Accessory Shoe Compatible Device Sender Receiver
Compatible with multi-function shoe EL-5 Yes Yes
EL-10 Yes Yes
ST-E10 Yes -
Compatible with conventional accessory shoe EL-1 - Yes
600EX II-RT - Yes
600EX-RT - Yes
430EX III-RT - Yes
MT-26EX-RT - -
ST-E3-RT (Ver. 3) Yes -
ST-E3-RT (Ver.2) Yes -
ST-E3-RT - -
Wireless Functions via radio transmission The Speedlite EL-10 can be set to function as a sender or receiver in wireless flash photography using radio transmission Second-curtain sync The Speedlite EL-10 supports second-curtain synchronization in radio transmission wireless shooting.
Click here to view the full specifications PDF
Wireless Functions via optical transmission Not supported
Communication Functions
Compliance standards IEEE 802.15.4, ARIB STD-T66
Communication method Primary modulation: OQPAK
Secondary modulation: DS-SS
Transmission frequency 2405-2475 MHz
Channel Channel 1-15
Setting: Auto / Manual
Wireless Radio ID 0000 to 9999
Setting: Manual
Transmission range*¹*² Approx. 98.4 ft. / 30 m
Groups Up to 5 groups (A-E)
*Sender units are set to Group A
Number of possible units for communication Up to 16 units of senders and receivers in total
Max. sender units Up to 15
*Secondary and additional units serve as sub-senders
Max. receiver units Up to 15
*1: Without any obstructions between senders and receivers, and without radio interference from other devices.
*2: Transmission range may be shorter depending on factors such as how units are arranged, the surrounding environment, and weather conditions.
Transmission Status Display
Transmission status Display Lamp LCD Panel
Sender Receiver
Connected Yes Yes On (in green) Sender,
Receiver
Not Connected Yes Yes Off Sender,
Receiver
Too many units/Error Yes   Off Sender,
Receiver
Sub-sender Yes   On (in green) Sub Sender
Wireless Firing Control
Wireless firing control via radio transmission
Flash Mode E-TTL II / E-TTL autoflash
Manual flash
Stroboscopic flash
Group firing E-TTL II / E-TTL autoflash
Manual flash
Auto external flash metering
E-TTL II / ETTL autoflash details
ALL Flash metering control of all groups (A/B/C) as if they were a single flash unit
A:B Flash metering control providing the flash ratio set for groups A and B
Flash ratio setting: 8:1 to 1:8
Flash exposure compensation: +/-3 stops
A:B:C (1) Flash metering control providing the flash ratio set for groups A and B
(2) Flash metering control of group C as if it were a single flash unit
Flash Exposure compensation +/- 3 stops
(3) Flash exposure compensation can be set for the flash output of (1) and (2) above
Manual flash details
ALL Flash output setting: 1/1024* to 1/1
A+B Flash output setting: 1/1024* to 1/1
A+B+C Flash output setting: 1/1024* to 1/1
1: Minimum of 1/128 for high-speed sync
2: Speedlites not supporting minimum flash output of 1/1024 fire at a level close to 1/1024
3: When [Sender flash firing] is disabled, a flash output of up to 1/8192 is possible
Stroboscopic flash Not supported
Group firing details Enables separate configuration of flash firing control conditions 1-3 below for each groups (A, B, C, D, E), to combine multiple methods of flash firing control. (1) E-TTL II / E-TTL autoflash (2) Manual flash (3) Auto external flash metering For all flash output set for groups A-E above, the same flash exposure compensation can be set. *Flash exposure compensation ±3 stops
Test flash Available (Sender/Receiver)
Modeling flash Not available
Modeling lamp Not available
Receiver Functionality Sender unit functions that receivers can control remotely Remote release Test flash Modeling flashFootnote*1 *Sub-senders cannot be controlled remotely *1. Modeling flash is only available by using the combination of a camera, not from the EOS R series or the EOS M series, with a compatible Speedlite as a sender, and using EL-10 as a receiver.
Type FSTN LCD
Size Approx. 1.89(H) x 1.04(V)in.
Display Format Dot-matrix display
Dot Count Approx. 12,000 dots (172x72)
Power source Battery Pack - 4x AA/LR6 alkaline batteries *AA/HR6 Ni-MH batteries can be used, AA/FR6 lithium batteries cannot be used.
Battery level indicator Not Supported
External power source Not Supported
Radio Transmission wireless shooting time Approx. 9 hrs. continuously *Time until the Speedlite turns off with sender flash firing disabled, when using radio transmission wireless * Using new AA/LR6 Alkaline batteries, based on Canon testing standards.
Maximum flash count
AA/LR6 alkaline batteries Approx. 210-1400 times
Size AA Ni-MH batteries Approx. 260-1700 times
Dimensions
Speedlite EL-10 2.8x4.6x3.9 in. (70.6x116.3x98.3mm)
Mini stand 2.6x0.4x3.0 in. (66.8x10.3x75.9mm)
Weight
Speedlite EL-10 Approx. 287 g Approx. 10.1 oz
Mini stand Approx. 22g Approx. 0.8 oz
Speedlite Case Approx. 41 g Approx. 1.4 oz
Light Distribution
Set in C.Fn-21
0: Standard A light distribution setting that balances light distribution and the guide number.
1: Guide number priority Prioritizes illumination at the center of the screen, the periphery may be dark.
2: Light distribution priority Light distribution that reduces peripheral darkness.
Custom Functions
14 Functions
Function Number Setting
C.Fn-00: Distance indicator display 0 m (display in meters)
1 ft. (display in feet)
C.Fn-01: Auto power off 0 ON (90 sec.)
1 OFF
C.Fn-08: AF-assist beam firing 0 ON (enabled)
1 OFF (disabled)
C.Fn-10: Receiver auto power off timer 0 60 min.
1 10 min.
C.Fn-11: Receiver auto power off timer 0 Within 8 hours
1 Within 1 hour
C.Fn-13: Flash exposure compensation setting 0 Button and dial
1 Direct setting with the dial
C.Fn-19: FEM (FE Memory) 0 OFF (disabled)
1 ON (enabled)
C.Fn-21: Light distribution 0 Standerd
1 Guide number priority
2 Even coverage
C.Fn-22: LCD panel illumination 0 Stay on for 12 sec. after operation
1 OFF Disable panel illumination
2 ON Illumination always on
Personal Functions
P.Fn-01: LCD Panel Contrast   Display contrast: 5 levels
P.Fn-02: QUICK (Quick Flash) 0 On (enabled)
1 OFF (disabled)
P.Fn-03: LINKED SHOT (FLASH FIRING DURING LINKED SHOOTING) 0 OFF (disabled)
1 On (enabled)
P.Fn-04: DIRECT (Change settings with dial) 0 OFF (disabled)
1 On (enabled)
Canon Flashes Limited International Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
  1. loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
  2. if equipment is defective as a result of leaking batteries or liquid damage.
  3. if equipment has been serviced or modified by other than our Authorized Agents.
  4. Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
  5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
Equipment covered by this Warranty will be repaired in other countries:
a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
Online Repair
Title Canon Support | Service Notice: Caution Concerning use of Lithium Batteries
Advisory Type
Date 04.28.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
