Canon Support for varioPRINT 135/120/110 | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Finisher-AK1/AK2
File Name
Document Insertion Unit-F1
File Name
Quick Reference Guide - Print from USB
File Name
Quick Reference Guide - Scan to USB
File Name
High Capacity Stacker-E1
File Name
Booklet Trimmer-D1
File Name
Duplex Color Image Reader Unit D1
File Name
Operating Information
File Name
Quick Reference Guide - Make Basic Copy
File Name
Safety Information
File Name
Professional Puncher-B1
File Name
Two Knife Booklet Trimmer-A1
File Name
Paper Folding Unit-F1
File Name
Quick Reference Guide - Scan to Email
SELECT ERROR CODE
| Model Name | varioPRINT 135/120/110 |
| Type | DirectPress |
| Printing Resolution | Engine: 600 x 2400 dpi / 200lpi PCL: 600 x 600 dpi Adobe PostScript 3: 600 x 2400 dpi, 1200 x 1200 dpi (Enhanced) |
| Letter | (Simplex / Duplex:) 120/110/100 ipm / 135/120/110 ipm |
| Ledger | (Simplex / Duplex:) 63/57/52 ipm / 70/63/57 ipm |
| First Copy Time | 3.9 seconds |
| Maximum Original Size | 12.6" x 19.2" (320 x 488 mm) |
| Standard Paper Capacity | 4000 sheets (80 gsm) Trays 1 & 2: 1500 sheets (Ltr, Statement**) Tray 3: 500 sheets from 5.5" x 7.17" (140x 182mm) to 12.6" x 17" (320 x 432 mm) Tray 4: 500 sheets from 5.5" x 7.17" (140 x 182 mm) to 12.6" x 19.2" (320 x 488 mm)Feeding Technology (iPIM - internal Paper Input Module): Roller fed 14 lb. bond - 110 lb. cover (50-300 gsm) |
Acceptable Paper Weights
| Duplexing | Up to 300 gsm |
| Power Requirements | 208V/20A |
| Dimension | 56.3" x 44.5" x 30.1" (1430mm x 1130mm x 765mm) |
| Weight | 579.8 (263 kg) |
| Estimated Toner Yield | 96,000 / per 2 bottles* |
Feeders
| Description | Color Image Reader (Single-pass Duplex Automatic Document Feeder and Black & White/Color Scanner) |
| Acceptable Originals | Statement, Letter, Legal, 11" x 17", Custom Sizes ADF: 5.5" x 5.04" (140 x 128mm) to 17" x 12" (432 x 305 mm) |
| Scanning Speed | BW/Color: Up to 120 ipm (300 x 300 dpi) BW: Up to 100 ipm (600 x 600 dpi) Color: Up to 105 ipm (600 x 300 dpi) Up to 25 ipm (600 x 600 dpi) |
| Capacity | 300 sheets (20 lb. bond) |
| Power Source | From main unit |
Paper Supply Options
| Description | ePIM (external Paper Input Module) |
| Paper Capacity | 8,000 sheets with Duo Tray Option, (4,600 Standard) |
| Paper Sizes | 8" x 8" (203 x 203 mm) to 12.6" x 19.2" (320 x 488 mm) |
| Paper Weights | 14 lb. bond - 110 lb. cover (50-300 gsm)Feeding Technology: Air Separation, Suction Feeding |
| Power Source | 120V/15A |
| Dimensions | 40.9" x 38.6" x 29.5" (1040mm x 980mm x 750mm) |
| Weight | 440.9 lbs (200 kg) |
| Description | Document Insertion Unit-F1 (Optional) |
| Paper Capacity | 400 Sheets (200 x 2) (20 lb. Bond) |
| Paper Sizes | 13" x 19.2" |
| Paper Weights | 14 lb. Bond to 110 lb. Cover (50gsm to 300gsm) |
| Dimensions | 55.37" x 29.37" x 31.25" (1407mm x 746mm x 793mm) |
| Weight | 134 lb. (61kg) |
next to your download
