Canon Support for varioPRINT 140 Series | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
varioPRINT 140 Operation Guide
File Name
Safety Guide - varioPRINT 140 Series
File Name
Operation Guide - Decurler Unit-C1
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
varioPRINT 140/130/115 | |||
| MAIN ENGINE | |||
| TECHNOLOGY | DirectPress | ||
| RESOLUTION | Up to 600 x 2400 dpi | ||
| PRINT SPEED (SIMPLEX / DUPLEX) | |||
vP140
vP130
vP115
| 8.5" x 11" | Up to 140 ipm | Up to 130 ipm | Up to 115 ipm |
| 11" x 17" | Up to 73 ipm | Up to 68 ipm | Up to 60 ipm |
| PAPER SIZE | 5.5" x 7.17" to 12.6" x 19.2" | ||
| PAPER FEEDING | |||
| STANDARD | Up to 4,000 Sheets (20 lb. Bond) | ||
| MAXIMUM | Up to 12,000 Sheets (20 lb. Bond)* | ||
| PAPER WEIGHT | 13 lb. Bond to 110 lb. Cover* (50 gsm to 300 gsm) | ||
| DUPLEXING | Automatic Duplex Any Supported Stock | ||
| POWER SOURCE | 208 V/20 A | ||
| DIMENSIONS (H x W x D) | 56.3" x 44.5" x 30.1"(Includes operator panel) | ||
| INPUT ACCESSORIES | |||
| ePIM (External Paper Input Module) | |||
| PAPER CAPACITY | Up to 4,600 Sheets (20 lb. Bond) | ||
| MAXIMUM CAPACITY | Up to 8,000 Sheets (20 lb. Bond)* | ||
| PAPER SIZE | 8” x 8” to 12.6” x 19.2” | ||
| PAPER WEIGHT | 13 lb. Bond to 110 lb. Cover (50 gsm to 300 gsm) | ||
| DIMENSIONS (H x W x D) | 41.6" x 38.9" x 29.3" | ||
| POWER SOURCE | 120 V/15 A | ||
DUPLEX COLOR IMAGE READER-L1** | |||
| IMAGE SENSOR | CCD | ||
| DOCUMENT SIZE | Statement to 11" x 17" | ||
| RESOLUTION | Up to 600 x 600 dpi | ||
| TRAY CAPACITY | Up 300 Sheets (20 lb. Bond) | ||
| SCAN SPEED | |||
| BW/COLOR: | Up to 120 ipm (300 x 300 dpi) | ||
| BW: | Up to 108 ipm (600 x 600 dpi) | ||
| COLOR: | Up to 120 ipm (600 x 300 dpi) Up to 25 ipm (600 x 600 dpi) | ||
| FINISHING ACCESSORIES | |||
| MULTIFUNCTION PROFESSIONAL PUNCHER-B1 | |||
| PAPER WEIGHT | |||
| PLAIN | 20 lb. Bond to 110 lb. Cover(75 gsm to 300 gsm) | ||
| COATED | 20 lb. Bond to 110 lb. Cover(80 gsm to 300 gsm) | ||
| PAPER SIZE | 12" x 18", 11" x 17", LTR, LGL, LTR-R, STMT | ||
| DIE SET PATTERNS | Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole | ||
| DIMENSIONS (H x W x D) | 40.9" x 17.5." x 31.2" | ||
| POWER SUPPLY | 120 V/15 A | ||
| HIGH-CAPACITY STACKER-H1 | |||
| OFFSET STACK CAPACITY | Up to 6,000 Sheets (20 lb. Bond) | ||
| TOP TRAY CAPACITY | Up to 200 Sheets (20 lb. Bond) | ||
| PAPER SIZE | 7.2" x 7.2" to 13" x 19.2" | ||
| PAPER WEIGHT | 14 lb. Bond to 110 lb. Cover(52 gsm to 300 gsm) | ||
| MAX. CONNECTIVITY | 1 Unit | ||
| DIMENSIONS (H x W x D) | 40.9" x 35.4" x 29.3" | ||
| STAPLE FINISHER-W1 / BOOKLET FINISHER-W1 | |||
| TRAY CAPACITY | |||
| TOP TRAY | Up to 1,000 Sheets (20 lb. Bond) | ||
| LOWER TRAY | Up to 4,000 Sheets (20 lb. Bond) | ||
| SADDLE-STITCH TRAY | Up to 30 Booklets or Limitless | ||
| STAPLE POSITIONS | Corner Stapling, Double Stapling | ||
| PAPER WEIGHT | 14 lb. Cover to 110 lb. Cover(52 gsm to 300 gsm) | ||
| PAPER SIZE | |||
| STAPLING | 11" x 17", LGL, LTR-R, EXEC, LTR,12" x 18", 13" x 19.2", Custom Size(8.3" x 11" to 13" x 19.2") | ||
| SADDLE FINISHER | 11" x 17", LGL, LTR-R, 12" x 18",13" x 19", Custom Size (8.3" x 11" to 13" x 19.2") | ||
| STAPLING CAPACITY | Up to 100 Sheets | ||
| BOOKLET STAPLING CAPACITY (20 LB. BOND) | |||
| UNCOATED | Up to 25 Sheets | ||
| COATED | Up to 10 Sheets | ||
| V-FOLDING | Up to 5 Sheets without Stitch | ||
| DIMENSIONS (H x W x D) | |||
| STAPLE FINISHER | 48.8" x 35.0" x 31.2" | ||
| BOOKLET FINISHER | 48.8" x 41.7" x 31.2" | ||
| BOOKLET TRIMMER-F1 | |||
| MARGIN TRIMMING | Front-edge Trim | ||
| TRIM AMOUNT | 0.08" to 1.1" | ||
| TRIM THICKNESS | 50 Sheets | ||
| OUTPUT TRAY CAPACITY | 30 Booklets | ||
| DIMENSIONS (H x W x D) | 40.9" x 62.1" x 30.3" | ||
| TWO-KNIFE BOOKLET TRIMMER-A1 | |||
| MARGIN TRIMMING | Top and Bottom | ||
| TRIM AMOUNT | 0.08" to 0.59" | ||
| DIMENSIONS (H x W x D) | 40.9" x 21.1" x 30.3" | ||
| PUNCHER UNIT-BS1 (OPTION FOR STAPLE FINISHER-W1 / BOOKLET FINISHER-W1 | |||
| PAPER SIZES | |||
| 2-Hole | Legal, Letter-R, Custom Size(7.2" x 7.2" to 11.7" x 17") | ||
| 3-Hole | 11" x 17", Letter, Executive-R, Custom Size (9.4" x 7.2" to 11.7" x 17") | ||
| DOCUMENT INSERTION UNIT-N1 | |||
| TRAY CAPACITY | |||
| UPPER TRAY | Up to 200 Sheets (20 lb. Bond) | ||
| LOWER TRAY | Up to 200 Sheets (20 lb. Bond) | ||
| PAPER SIZE | 11" x 17", 12" x 18", 13" x 19", LGL, LTR, LTR-R, EXEC, Custom Size (7.2" x 7.2" to 13" x 19.2") | ||
| PAPER FOLDING UNIT-J1 | |||
| DOUBLE PARALLEL FOLD | Legal, Letter-R | ||
| C/ACCORDION FOLD | Letter-R | ||
| Z-FOLD | 11" x 17" | ||
| HALF-FOLD | Letter-R | ||
| SUPPORTED MEDIA WEIGHTS | 14 lb. Bond to 28 lb. Bond(50 gsm to 105 gsm) | ||
| POWER SOURCE | From Finisher | ||
| DIMENSIONS (H x W x D) | 46.87" x 13.25" x 31.25" | ||
| WEIGHT | 157 lb. (71 kg) | ||
| CONSUMABLES | |||
| TONER | Canon varioPRINT DP Toner | ||
| FOOTNOTES | |||
| * With ePIM and two Duo Tray options installed ** Included in MFP model. Must connect to Booklet Finisher-W1. Must connect to Booklet Trimmer-F1. | |||
next to your download
