Canon Support for varioPRINT 6000 Series TITAN | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| MAIN UNIT SPECS | |
| IMAGING TECHNOLOGY | Copy Press and Gemini Duplex Technology from Canon. |
| ENGINE RESOLUTION | LED, 600 x 1200 dpi, 85/106/125/141/180 lpi |
| PRINT SPEED | 6330/6270/6220/6180Footnote1 Up to 320/266/216/177 (Letter) Up to 167/143/116/95 (Ledger) |
| OPTIMAL MONTHLY PRINT VOLUME | 1,000,000 - 10,000,000 (Letter images) |
| USER INTERFACE TYPE | Intuitive 15" touch screen user interface |
| CHARACTERIZATION | Multiple and customizable views help ensure a productive and controlled workflow. Queue Manager, Job Scheduler, system status overview, multiple queues, job definition and selection options, bundle printing |
| PAPER HANDLING | Maximum: 12.6" x 19.2" (320 mm x 488 mm) Minimum: 8" x 8" (203 mm x 203 mm) Optional: 7" x 10" (178 mm x 254 mm) with Statement-sized option |
| PAPER SIZE | 8" x 8.2" (203 mm x 208 mm) to 13.8" x 19.7" (350 mm x 500 mm) with optional PIM FlexA1 |
| PAPER INPUT (STANDARD) | 4 paper trays (2 x 1700 sheets + 2 x 600 sheets) |
| OPTIONS | Second and third paper input module (standard size or PIM Flex-A1) |
| MAXIMUM PAPER CAPACITY | 24,000 Letter sheets from 4 standard and 8 optional paper trays (20lb Bond) with Duo Tray Option to increase Letter input capacityFootnote2 |
| PAPER WEIGHT | Plain Paper: 13 lb. Bond to 110 lb. Cover (50 to 300 gsm) Coated Media: 20 lb. Bond to 90 lb. Cover3 (80 to 250 gsm) Light-Weight Media: 12lb Bond to 13 lb Bond (45 - 50 gsm) with the optional light-weight media module |
| OUTPUT ACCESSORIES | |
| HIGH CAPACITY STACKER | Capacity 6000 sheets - 20 lb bond (80 g/m2) (2 stacks x 3000 sheets each). |
| FUNCTIONALITY | All paper input sizes and weights are supported including tabs. Supports OEM output to third party finishing solutions |
| OPTIONAL | Up to 3 Stackers can be configured inline, offering 18,000 sheets output capacity |
| SET FINISHER (OPTIONAL) | |
| FINISHER | Capacity 4000 sheets letter 20 lb Bond (80g/m2) |
| SIZES | The following paper sizes can be stacked (and stapled): all (custom) sizes between: - long edge:10.8" to 12" (275 to 306 mm ) - 12" - short edge: 8.2" x 8.7" (208 to 220 mm) - Number of staples in a set: 1 or 2 |
| STAPLING POSITIONS | Corner portrait or landscape, side |
| STAPLING CAPACITY | 100 sheets plain paper (20lb Bond) |
| CONNECTIVITY | |
| NETWORK HARDWARE | 10/100/1000 Mb, 1Gb Ethernet |
| NETWORK PROTOCOL | TCP/IP (LPR/LPD, socket), SMB static/auto IP (via DHCP) SNMP v1-v3 (printer MIB, private MIB, Job monitoring MIB), IPP |
| SUPPORTED PDLS (SUPPORTS AUTOMATIC LANGUAGE SENSING) | APPE (Adobe® PDF Print Engine) Adobe® PostScript® 3TM/ streaming PostScript® PPML/GA Level 1 PPML versions 1.5,2.1 and 2.2 PDF 1.7 PCL 6 Xerox® PPP support IPDS(options) Instant switching from IPDS or SRA PCL6 to PostScript 3/PDF/PCL 6 Streaming behavior for all PDLs |
next to your download
