Web Content Viewer
The Printer
You Won't Hate.
Learn how the WG7200 Series Multifunction Printers can transform your workflow
The Printer Inspired by Small-Business Proffesionals, Like You.
Canon spoke with hundreds of small-business professionals who understand the pressure of trying to fit 12 hours of productivity into an 8-hour day.
After hearing about the same pain points again and again, we went to work creating a solution to answer your needs. The result is the WG7200 Series of Multifunction Printers. Designed and built to deliver whatever you need, whenever you need it, to keep your business running smoothly and productively.
Usability
Featuring a large 5-inch LCD touchscreen that displays easy-to-follow set-up instructions — plus a built-in USB port1 that lets you print and scan without a computer — the WG7200 Series Printers are designed for ultimate ease-of-use.
Performance
Tackle high volume print jobs, with fewer interruptions, thanks to an innovative, jam-defying design2. And when supplies run low, simply open the front panel to easily access and replenish the printer's maintenance and ink cartridges — hassle-free.
Productivity
Engineered to be intuitive and efficient, these printers are equipped with built-in sensors that detect the specific paper size loaded and adjust their settings automatically — offering extensive media support for various types, weights and sizes up to 13" x 19".
Simple Intuitive Touchscreen
Self Serviceable Design
Wide Range of Media Support
Jam Defying Design
High Speed Printing
Anti-Curl Technology
ReImagine Your Productivity
Discover how & why the WG7200 Series Printers consistently outpace the competition
Designed for maximum efficiency, the WG7200 Series Printers work hard to keep your productivity and workflow at peak performance. With fast print speeds, a large paper capacity and a straight paper path that reduces paper jams2, these powerful printers excel at keeping usability, performance and productivity top-of-mind.
In this eBook, you’ll learn why these printers consistently outpace the competition and gain exclusive knowledge on:
- Best practices for using this technology
- Insight for increasing your ROI
- How to overcome common challenges
- Guidelines from industry experts
The needs of your small business are unique, and the Canon WG7200 Series has solutions to fit every need.
Models shown with optional CF10 Paper Cassette Feeding Unit.
50/80 Print Speed (PPM)3 |
40/70 Print Speed (PPM)3 |
6.5 Seconds / Fast First Print Out Time (FPOT)3 |
40/65 Scanning Speed (IPM)4 |
5.0" LCD Touchscreen |
Print / Copy / Scan | Print / Copy / Scan | Print / Copy / Scan | Print / Copy / Scan |
ADF | ADF | ADF | ADF |
Jam Defying Design2 | Jam Defying Design2 | Jam Defying Design2 | Jam Defying Design2 |
High-Density Black & Highlighter Resistant Ink |
XXL Cartridges | XXL Cartridges | XXL Cartridges | XXL Cartridges |
Single-Pass Duplex Scanning | Single-Pass Duplex Scanning | Single-Pass Duplex Scanning | Single-Pass Duplex Scanning |
Ethernet | Ethernet | Ethernet | Ethernet |
Wi-Fi® / Wireless5 | Wi-Fi® / Wireless5 | Wi-Fi® / Wireless5 | — |
Fax Capable | Fax Capable | — | — |
NFC8 | — | — | — |
Shift Sorter | — | — | — |
1,150 Sheets Total Standard Paper Cassettes (2) 550 Sheets / Per Cassette (x2 Cassettes) + 50 Sheet Multi-Purpose Tray |
OPTIONAL | OPTIONAL | OPTIONAL | OPTIONAL |
2,250 Sheets Total +2 Additional Paper Cassettes (2) 550 Sheets / Per Cassette (x4 Cassettes) + 50 Sheet Multi-Purpose Tray |
- OR - | - OR - | - OR - | - OR - |
CB10 Cabinet Base Unit Raise the WG7200 Series to a more comfortable height while using the 2 included paper cassettes |
Shop Now | Shop Now | Shop Now | Shop Now |
Turn to the experts for product pricing, printing solutions, special offers9 and more.
1-855-85-Canon.
Disclaimer
SPECIFICATIONS ARE SUBJECT TO CHANGE WITHOUT NOTICE. ALL VIEWSCREEN AND OUTPUT IMAGES ARE SIMULATED.- Supported file formats include: JPEG, TIFF and PDF.
- "Jam Defying Design" refers to the WG7200 Series straight paper path designed to help reduce and prevent paper jams.
- Print Speed is based on ISO/IEC 24734 including Canon original method. Measured in default mode (General Office Mode: 600dpi) / fast mode (Office Document Mode: 300dpi). Print speed varies depending on system configuration, interface, software, content of document, print mode,media type, weight and used cassette, etc. Print Speed (FPOT) is based on ISO/IEC17629. Print speed varies depending on system configuration, interface, software, content of document, print mode, media type, weight and used cassette etc.
- ADF scan speeds are based on ISO/IEC 17991, scESAT30secA. Scanning Speed (SEND) is based on ISO/IEC 17911, scEFTP30secF. ADF scan speeds/Scanning speed (SEND) vary depending on system configuration, interface, software, etc.
- Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to Mac running MacOS X 10.9 or later supports AirPrint via USB connection.
- Requires Android mobile device with Android 4.4 operating system or later with the Mopria® Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria® Print Service experience is also available on Android 4.4 mobile devices with a download of the Mopria® Print Service from Google Play.
- Requires an Android mobile device with NFC hardware running Android 4.1 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality. Requires an Internet connection and theCanon PRINT Business app, available for free on the App Store and at Google Play. Compatible with iPad and iPhone devices running iOS 9.0 or later, and Android mobile devices running Android 4.1 or later. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Certain exceptions and restrictions may apply.
- Special available til December 31, 2019 and only redeemable by contacting Canon CITS.
