Canon Support for Color imageCLASS MF729Cdw | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup How-To Videos
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
Printer Specifications
| Printer Type | Color Laser MFP |
| Print Speed | Up to 10ppm (2-sided plain paper letter) Up to 21ppm (1-sided plain paper letter)1 |
| First Print Time | 14.3 seconds or less (letter)2 |
| Printer Language | UFR II LT (Host-based), PCL (6, 5c) PS |
| Print Resolution | Up to 1200 x 1200 dpi (9600 x 600 dpi quality) |
| Maximum Print Size | Up to Legal |
| Duplex Print | All mode (Print, Scan, Copy, Fax) |
| Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
| Print Memory | 1GB (shared) |
| Direct Print from USB | via USB Host v1.1 Print File format: JPEG, TIFF, PDF |
Copier Specifications
| Copy Type | Color Laser |
| Copy Speed | LTR: Up to 21ppm (Black/Color)1 A4: Up to 20ppm (Black/Color )1 |
| Duplex Copy Speed | LTR/A4: Up to 10ppm (Black/Color)1 |
| Copy Resolution | Up to 600 x 600 dpi |
| Original Type | Text/Photo/Map |
| Halftones | 256 Levels |
| Warm-up Time | 23 sec or less from power-on |
| First Copy Time | Black/Color: Approx. 15.5/16.2sec (A4), 15.3/16.0 sec (LTR)3 |
| Recovery Time | Approx. 8 sec |
| Maximum Number of Copies | Up to 99 copies |
| Duplex Copy/Bind Time | Yes |
| Reduction/Enlargement | 25 - 400% in 1% increments |
| Zoom | 25 - 400% in 1% increments |
| Copy Size | Platen: Up to Letter, ADF: 5.5" x 5" to Legal |
| Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
| Copy Memory | 1GB (shared) |
Fax Specifications
| Modem Speed | Up to 33.6 Kbps4 |
| Fax Resolution | Up to 406 x 391 dpi |
| Transmission Time | JBIG (approx. 3 seconds) |
| Memory Capacity | Up to 512 pages5 |
| Speed Dials | Up to 281 dials |
| Group Dialing | Max. 199 dials / Max. 199 destinations |
| Sequential Broadcasting | Max. 310 destinations |
| Duplex Fax | Yes |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | FAX Forwarding, Dual Access, Remote Reception, PC FAX(TX only), DRPD, ECM, Auto Redial, Fax Activity Reports, Fax Activity Result Reports, Fax Activity Management Reports |
| Memory Backup | Permanent fax memory backup. ( Backup with flash memory) |
| Activity Reports | Activity Result & Activity Management |
| pC Fax | Sending only |
| Fax Forwarding | SMB, E-mail, FTP, iFax Simple |
Scanner Specifications
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-bit |
| Scan Resolution | Optical: Up to 600 x 600 dpi Driver(digital): Up to 9600 x 9600 dpi |
| Scan Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
| Duplex Scan | Yes |
| Compatibility | TWAIN, WIA (Scan Driver Compatibility) |
| Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR). Optional: PDF (Encrypted), PDF (Digital Signature), PDF (Device Support) |
| Scan Features | Push Scan, Pull Scan |
| Pull Scan | Yes, USB and Network |
| Push Scan (Scan to pC) | Yes, USB and Network |
Paper Handling Specifications
| Standard Paper Source(s) | 250-sheet cassette, 50-sheet multipurpose tray6 |
| Optional Paper Source(s) | 250-sheet cassette |
| Document Feeder | 50-sheet duplex |
| Paper Output | 125 sheets (face down) |
| Paper Weight | 16-58 lb. bond (cassette / multipurpose tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive |
| Media Types | Plain, Heavy, Recycled, Color, Coated, Transparency, Label, Envelope, Index |
| Envelope Capacity | 10 envelopes (cassette), 5 envelopes (manual feed slot) |
| Envelope Types | Com 10, Monarch, DL, C5, B5 |
Connectivity and Software Specifications
| Standard Interface(s) | USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7 |
| WiFi Access Mode | Infrastructure Mode |
| WiFi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
| WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
| WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
| Mobile Functions | Canon PRINT Business8, Apple AirPrint™9, Mopria Print Service10, Google Cloud Print™11 |
| Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB |
| Embedded Web Server (Remote UI) | Yes |
| Web Browser Support for Remote UI | Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), Email, SMB, WSD-Scan (IPv4,IPv6) |
| TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003, Mac OS X® 10.5.8 & up, Linux (print only) |
| Cable Included | Power Cord, Telephone Cable (USB not included) |
| Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
| Power Consumption | Max: 1,200W or less. During Operation: Approx. 450W. Standby: Approx. 23W. Energy Saver: Approx. 2W |
| Typical Energy Consumption | 0.9 kWh |
General Specifications
| Dimensions | 17" (W) x 19.2" (D) x 18.9" (H) |
| Unit Weight (without/with cartridge) | 63.1 lbs. (w/o cartridge), 68.3 lbs (w/cartridge) |
| Package Weight | Approx. 81.6 lbs |
| Cartridge Type | Cartridge 118 VP Black (Yields approximately 6,800 pages) Cartridge 118 Black (Yields approximately 3,400 pages) Cartridge 118 YMC (Yields approximately 2,900 pages) *Yields based on ISO/IEC Standard |
| Department Counter | Yes |
| LCD Display | 7-line QVGA Color Touch LCD |
| Duty Cycle | Up to 40,000 pages per month |
| Department ID Management | Yes, Up to 300 ID's |
| Security | Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, LDAP |
| Languages | English, French, Spanish, Portuguese |
| One-Touch Keys | Favorites Settings |
| Warranty | 1 Year Exchange / Carry-in (Extended warranty available)12 |
| Scanning Software Included: MF Scan Utility Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Grayscale, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Other Features: EPEAT Silver Rating, NFC13 Capability |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
next to your download
