Canon Support for Color imageCLASS MF820Cdn | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.29.16
File Size 717.77 KB
Date 09.04.19
File Size 13.90 MB
Date 09.16.24
File Size 1.32 MB
Date 12.21.17
File Size 940.90 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.16 MB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 12.19.23
File Size 1.85 MB
Date 01.30.23
File Size 2.26 MB
Date 12.21.17
File Size 809.44 KB
Date 01.30.17
File Size 986.72 KB
Date 04.23.19
File Size 2.92 MB
Date 12.18.14
File Size 18.89 MB
Date 10.03.19
File Size 958.35 KB
Date 01.30.17
File Size 510.04 KB
Date 09.16.24
File Size 1.85 MB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 12.01.20
File Size 961.90 KB
Date 03.26.17
File Size 716.21 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 12.19.23
File Size 476.17 KB
Date 10.03.19
File Size 2.92 MB
Date 12.24.14
File Size 2.22 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.17.18
File Size 948.95 KB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 03.02.26
File Size 1.85 MB
Date 03.02.26
File Size 1.33 MB
Date 03.02.26
File Size 1.86 MB
Date 03.02.26
File Size 2.27 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Products ChromeOS
Printer Specifications
Printer Type Color Laser
Print Speed Up to 36ppm color (letter)4
First Print Time 9 seconds or less (letter)7
Printer Language UFR II, PCL6(5c,XL), PostScript&reg; 3&trade;, PDF
Print Resolution Up to 600 x 600 dpi
(1200 x 1200 dpi quality)
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Poster, Booklet, Watermark, Page Composer, Toner Saver
Print Memory 1 GB (Shared)
Copier Specifications
Copy Type Color Laser
Copy Speed Up to 36cpm (letter)
Duplex Copy Speed Up to 36cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Photo, Text
Halftones 256 Levels
Warm-up Time Approximately 34 seconds
First Copy Time Black/Color: Approximately 5.9/7.4 seconds8
Recovery Time Approximately 10 seconds
Maximum Number of Copies 999 copies
Reduction/Enlargement 25%, 50%, 64% 78%129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Legal
ADF: Up to Legal
Copy Features Frame Erase
Memory Sort
2 on 1
4 on 1
ID Card Copy
Copy Memory 1 GB (Shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)9
Fax Resolution Up to 406 x 391 dpi
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 512 sheets10
Speed Dials 300 coded dials
Group Dialing 199 destinations
Sequential Broadcasting 310 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Dual Access, Remote Reception, PC Fax (TX only), DRPD, ECM, Auto Redial, Fax Archive
Activity Reports Activity Result & Activity Management
pC Fax Sending only
Fax Forwarding Yes
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Legal
ADF: Up to Legal
Duplex Scan Yes
Compatibility TWAIN, WIA
Scan Features Push Scan, Pull Scan
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 550-sheet cassette plus 100-sheet multipurpose tray11
Document Feeder 50-sheet duplex11
Paper Output 250 sheets (face down)
Paper Weight 16-38 lb. bond (cassette)
16-38 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive, Statement
Media Types Thin, Plain1, Plain2, Plain3, Heavy1, Heavy2, Recycled1, Recycled2, Recycled3, Color, PrePunched, Bond Paper
Envelope Types Com 10, Monarch, DL, Custom(Min. 98.4 x 190.5 mm to Max. 216.0 x 355.6mm)
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network)
Mobile Functions Canon Mobile Printing1, Apple AirPrint&trade;2. Mopria&trade; Print Service3, Canon Mobile Scanning for Business12
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4)
OS Compatibility Windows Server 2003, Mac&reg; OS X 10.5.8 and up, Linux&reg; Drivers available for download from www.usa.canon.com
Bundled Software Printer driver, Fax driver, Scanner driver
Environmental Specifications
Power Consumption During Operation: Approx. 500W
Standby: Approx. 30W
Energy Saver: Approx. 1W (wired)
Typical Energy Consumption 0.43kWh
General Specifications
Dimensions 20.1"(W) x 22.3"(D) x 24"(H)
Unit Weight (without/with cartridge) 94.8 lbs. (w/cartridge)
97 lbs. (w/o cartridge)
Package Weight Approx. 99.2 lbs.
Cartridge Type Canon Toner 034 CMYK (CMY Yields approximately 7,300 pages, Black/K Yields approximately 12,000 pages) *Yields based on ISO/IEC Standard
LCD Display 3.5" customizable touch-panel
Duty Cycle Up to 88,000 pages per month
Security IP Address Filtering, MAC Address Filtering, Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, Department ID Management
Languages English, French, Spanish
Warranty 1 year limited onsite warranty13 (Extended warranty available)
CANON imageCLASS SERIES ON-SITE PRODUCT LIMITED WARRANTY
Canon U.S.A., Inc. ("Canon USA") warrants the Color imageCLASS MF800 Series product and Canon brand options designed for use with the imageCLASS product (collectively, the "Product") to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider") to, without charge, repair or replace any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as waste toner containers or paper, as to which there shall be no warranty or replacement.
Drums and toner bottles for the Product are covered by separate warranties. Accordingly, this limited warranty does not cover any drums and toner bottles for the Product, whether shipped with the Product or purchased thereafter.
Canon USA offers assistance for installation, operation and support* of the Product as follows:
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.usa.canon.com/support (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
If Canon USA's remote assistance above cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call via a Service Provider, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider.
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
