Canon Support for EOS 10D | Canon U.S.A., Inc.
EOS 10D
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 06.09.08
File Size 5.33 MB
Date 09.30.07
File Size 11.53 MB
Date 10.14.10
File Size 8.08 MB
Date 04.13.09
File Size 7.50 MB
Date 07.22.12
File Size 6.88 MB
Date 03.31.07
File Size 7.83 MB
Date 06.09.08
File Size 10.99 MB
Date 06.09.08
File Size 4.94 MB
Date 12.31.03
File Size 351.91 MB
Date 04.15.09
File Size 6.96 MB
Date 03.31.07
File Size 2.19 MB
Date 01.24.12
File Size 10.69 MB
File Name 10D_PTP.pdf
Date 12.31.03
File Size 156.40 MB
Date 03.04.10
File Size 12.70 MB
Date 07.22.12
File Size 6.38 MB
Date 10.14.10
File Size 8.41 MB
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital, single-lens reflex, AF/AE camera with built-in flash
Recording Media Type I and II CF card
Image Format 22.7 mm x 15.1 mm
Compatible Lenses Canon EF lenses(35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.)
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, single-plate CMOS sensor
Pixels Approx. 6.30 megapixels (3088x2056)
Total Pixels Approx. 6.50 megapixels (3152x2068)
Aspect Ratio 3:2
Color Filter System RGB primary color filter
Low Pass Filter Located in front of the image sensor, non-removable
Recording System
Recording Format JPEG (except when Adobe RGB is set) supporting Design rule for Camera File system and RAW
Image Format JPEG and RAW (12-bit)
File Size (1) Large/Fine: Approx. 2.4 MB (3072x2048 pixels)(2) Large/Normal: Approx. 1.2 MB (3072x2048 pixels)(3) Medium/Fine: Approx. 1.3 MB (2048x1360 pixels)(4) Medium/Normal: Approx. 0.7 MB (2048x1360 pixels)(5) Small/Fine: Approx. 0.8 MB (1536x1024 pixels)(6) Small/Normal: Approx. 0.4 MB (1536x1024 pixels(7) RAW (3072x2048 pixels)RAW + Small/Normal: Approx. 6.0 MBRAW + Small/Fine: Approx. 6.4 MBRAW + Medium/Normal: Approx. 6.2 MBRAW + Medium/Fine: Approx. 6.8 MBRAW + Large/Normal: Approx. 6.7 MBRAW + Large/Fine: Approx. 8.0 MB* Exact file sizes depend on the subject and ISO speed.
File Numbering Consecutive numbering, auto reset
Color Space sRGB, Adobe RGB Standard parameters plus up to three sets of custom processing parameters (4 items with 5 settings each) can be set.
White Balance
Settings Auto, daylight, shade, cloudy, tungsten light, fluorescent light, flash, manual, color temperature setting
Auto White Balance Auto white balance with the image sensor
Color Temperature Compensation White balance bracketing: +/-3 stops in whole-stop increments
Viewfinder
Type Eye-level pentaprism
Coverage 95% vertically and horizontally with respect to the effective pixels
Magnification 0.88x (-1 diopter with 50mm lens at infinity)
Eye Point 20 mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Fixed, New Laser Matte screen
Mirror Quick-return half mirror (Transmission:reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder Information AF (AF points, focus confirmation light), exposure (shutter speed, aperture value, manual exposure, AE lock, exposure compensation amount, AEB level, partial metering area), flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, flash exposure compensation amount), warnings (exposure warning, improper FE lock warning, CF card full warning, CF card error warning, no CF card warning, busy), maximum burst for continuous shooting, shots remaining Depth-of-field preview: Enabled with depth-of-field preview button
Autofocus
Type TTL-CT-SIR with a CMOS sensor (TTL secondary image-registration, phase detection)
AF Points 7
AF Working Range EV 0.5-18 (at 20&deg;C, ISO 100)
Focusing Modes One-Shot AF, AI Servo AF, AI Focus AF, Manual focusing (MF)
AF Point Selection Automatic selection, manual selection, home position
Active AF Point Indicator Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam Stroboscopic flash
Effective Range Approx. 4.0 m/13.1 ft. at center, approx. 3.5m/11.5ft. off-center
Exposure Control
Metering Range EV 1-20 (at 20&deg;C with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Basic Zone modes: Automatic
Exposure Compensation AEB: +/-2 stops in 1/2- or 1/3-stop increments
AE Lock Auto: Applied when focus is achieved in the One Shot AF mode with evaluative metering Manual: Applied with AE lock button
Shutter Electronically-controlled focal-plane shutter180SpecificationsShutter speeds: 1/4000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/200 sec.Soft-touch electromagnetic release10-sec. delayN3-type remote control
Type Electronically-controlled focal-plane shutter180SpecificationsShutter speeds: 1/4000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/200 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay
Remote Control N3-type remote control
Built in Flash
Type Auto pop-up E-TTL autoflash (retractable)
Guide Number 13 (ISO 100, meters), 43 (ISO 100, ft.)
Recycling Time Approx. 3 sec.
Flash Ready Indicator Flash-ready icon lights in viewfinder
Flash Coverage 18mm lens angle covered
Flash Exposure Compensation +/-2 stops in 1/2- and 1/3-stop increments
External Speedlite
EOS Dedicated Speedlite E-TTL autoflash set with EX-series Speedlites
PC Terminal Provided
Drive System
Drive Modes Single frame, continuous, self-timer
Continuous Shooting Speed Approx. 3 fps (at 1/250 sec. or faster speeds)
Maximum Burst 9 shots
LCD Monitor
Type TFT color liquid-crystal monitor
Monitor Size 1.8 inches
Pixels Approx. 118,000
Coverage Approx. 100% with respect to the effective pixels
Brightness Control 5 levels
Playback
Display Format Single image, single image (Info), magnified view (approx. 1.5x - 10x in 15 steps, consecutive magnified image viewing enabled), 9-image index, autoplay, image rotation, and jump
Highlight Alert In the single image and single image (Info) modes, any overexposed highlight areas with no image information will blink
Image Protection and Erase
Protection Single images can be protected or cancelled
Erase Single image or all images in the CF card can be erased (except protected images)
Menus
Menu Categories Shooting menu: Red
Playback menu: Blue
Setup menu: Yellow
LCD Monitor Language 12 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, and Japanese.)
Firmware Update Update possible by the user
Power Source
Battery One Battery Pack BP-511/BP-512
AC power can be supplied via the DC coupler.
Battery Life At 20&deg;C / 68&deg;F: 650 (No Flash), 500 (50% Flash Use),At 0&deg;C / 32&deg;F: 500 (No Flash), 400 (50% Flash Use). These figures apply when a fully-charged Battery Pack BP-511/BP-512 is used.
Battery Check Automatic
Power Saving Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min.
Back-up Battery One CR2025 lithium battery
Dimensions and Weight
Dimensions (W x H x D) 149.7 x 107.5 x 75.0mm / 5.9 x 4.2 x 3.0 in
Weight 790 g/ 27.9 oz (body only)
Operating Environment
Working Temperature Range 0 - 40&deg;C / 32 - 104&deg;F
Working Humidity Range 85% or lower
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Safety Notice: Lithium-Ion Battery Pack
Advisory Type
Date 12.31.08
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
