Canon Support for EOS-1D Mark II | Canon U.S.A., Inc.
EOS-1D Mark II
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 06.10.08
File Size 5.33 MB
Date 04.16.09
File Size 6.96 MB
Date 10.15.10
File Size 8.08 MB
Date 06.10.08
File Size 10.99 MB
Date 07.23.12
File Size 6.38 MB
Date 04.01.07
File Size 5.32 MB
Date 01.25.12
File Size 10.69 MB
Date 10.15.10
File Size 8.41 MB
Date 10.01.07
File Size 11.53 MB
Date 07.23.12
File Size 6.88 MB
Date 04.14.09
File Size 7.50 MB
Date 10.21.10
File Size 11.20 MB
Date 03.05.10
File Size 12.70 MB
Date 03.26.08
File Size 1.84 MB
Date 06.10.08
File Size 4.94 MB
Date 04.01.07
File Size 4.05 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR
Recording Media Type I or II CF card, SD memory card
Image Format 28.7 x 19.1mm
Compatible Lenses Canon EF lenses (except EF-S lens)
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels Approx. 8.20 megapixels
Total Pixels Approx. 8.50 megapixels
Aspect Ratio 3:2
Color Filter System RGB primary color filter
Low Pass Filter Located in front of the image sensor, non-removable
Recording System
Recording Format DCF 2.0 (Exif 2.21): JPEG and RAWRAW+JPEG simultaneous recording provided, Backup image recording enabled (Same image recordable on CF card and SD memory card)
Image Format JPEG, RAW (12-bit)
File Size (1) L (Large): Approx. 2.8 MB (3504 x 2336 pixels)(2) M1 (Medium1): Approx. 2.2 MB (3104 x 2072 pixels)(3) M1 (Medium2): Approx. 1.7 MB (2544 x 1696 pixels)(4) S (Small): Approx. 1.0 MB (1728 x 1152 pixels)(5) RAW: Approx. 8.3 MB (3504 x 2336 pixels)JPEG quality: 8.Exact file sizes depend on the JPEG quality, subject, ISO speed, etc.
Folders Folder creation/selection enabled
File Numbering (1) Consecutive numbering(2) Auto reset(3) Manual reset
Color Space Five standard types plus two types that can be registered with color matrix
Interface IEEE1394 for personal computers; USB for direct printing; Video output (NTSC/PAL)
White Balance
Settings Auto, daylight, shade, cloudy, tungsten light, fluorescent light, flash, custom, color temperature setting, custom white balance (Total 10 settings)
Auto White Balance Auto white balance with the image sensor
Color Temperature Compensation White balance bracketing: &plusmn;3 stops in full-stop increments, White balance correction: &plusmn;9 stops in full-stop increments*Blue/amber bias or magenta/green bias possible
Viewfinder
Type Eye-level pentaprism
Coverage Approx. 100 percent vertically and horizontally with respect to the effective pixels
Magnification 0.72x (-1 diopter with 50mm lens at infinity)
Eye Point 20 mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Interchangeable (9 types), Standard focusing screen: Ec-CIII
Mirror Quick-return half mirror (Transmission:reflection ratio of 37:63, no mirror cut-off with EF 1200mm f/5.6 or shorter lens)
Viewfinder Information AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, manual exposure, spot metering circle, ISO speed, exposure level, exposure warning), flash information (flash ready, FP flash, FE lock, flash exposure level), white balance correction, JPEG recording, number of remaining shots, memory card information
Depth Of Field Preview Enabled with depth-of-field preview button
Eyepiece Shutter Built-in
Autofocus
Type TTL-AREA-SIR with a CMOS sensor
AF Points 45 AF points (Area AF)
AF Working Range EV 0-18 (at ISO 100 at 20&deg;C/68&deg;F)
Focusing Modes One-Shot AF (ONE SHOT); AI Servo AF (AI SERVO); Manual focusing (MF)
AF Point Selection Automatic selection, manual selection, home position (switch to registered AF point)
Selected AF Point Display Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam Emitted by the dedicated Speedlite
Exposure Control
Metering Modes 21-zone TTL full aperture metering(1) Evaluative metering (linkable to any AF point)
(2) Partial metering (approx. 13.5% of viewfinder at center)
(3) Spot metering
Center spot metering (approx. 3.8% of viewfinder at center)AF point-linked spot metering (approx. 3.8% of viewfinder)Multi-spot metering (Max. 8 spot metering entries)(4) Center weighted averaged metering
Metering Range EV 0-20 (at 20&deg;C/68&deg;F with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Equivalent to ISO 100-1600 (in 1/3-stop increments), ISO speed can be expanded to ISO 50 and 3200
Exposure Compensation AEB: +/-3 stops in 1/3-stop increments. Bracketing methods:1. Shutter speed or aperture2. ISO speed, Manual: +/-3 stops in 1/3-stop increments (can be combined with AEB)
AE Lock Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved. Manual: By AE lock button in all metering modes.
Shutter Electronically-controlled focal-plane shutter1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec.Soft-touch electromagnetic release10-sec. or 2-sec. delayRemote control with N3 type terminal
Type Electronically-controlled focal-plane shutter
Shutter Speeds 1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. or 2-sec. delay
Remote Control Remote control with N3 type terminal
External Speedlite
EOS Dedicated Speedlite E-TTL II autoflash with EX-series Speedlite
PC Terminal Provided
Drive System
Drive Modes Single, low-speed continuous, high-speed continuous, self-timer
Continuous Shooting Speed Low-speed continuous: Approx. 3 shots/sec. High-speed continuous: Approx. 8.5 shots/sec.
Maximum Burst JPEG: Approx. 40 shots (Large, JPEG 8)
RAW: Approx. 20 shots
LCD Monitor
Type TFT color liquid-crystal monitor
Monitor Size 2.0 in.
Pixels Approx. 230,000
Coverage 100% with respect to the effective pixels
Brightness Control Five levels provided
Playback
Display Format Single image, single image (INFO.), 4-image index, 9-image index, magnified zoom (approx. 1.5x - 10x), rotated image
Highlight Alert In he single image and single image (INFO.) formats, any overexposed highlight areas will blink in the image display.
Image Protection and Erase
Protection Erase protection of one image, all images in a folder, or all images in the memory card can be applied or cancelled.
Erase One image, all images in a folder, or all images in the memory card can be erased (except protected images).
Sound Recording
Recording Methods The voice annotation recorded with the built-in microphone is attached to the image.
File Format WAV
Recording Time Max. 30 sec. per recording
Power Source
Battery One Ni-MH Pack NP-E3
AC power can be supplied via the AC adapter and DC coupler.
Number of Shots At 20&deg;/68&deg;F: Approx. 1200
At 0&deg;C/32&deg;F: Approx. 800
The above figures apply when a fully-charged Ni-MH Pack NP-E3 is used.
Battery Check Automatic
Power Saving Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min.
Back-up Battery One CR2025 lithium battery
Dimensions and Weight
Dimensions (W x H x D) 6.1 x 6.2 x 3.1 in. / 156 x 157.6 x 79.9mm
Weight 43 oz. / 1220g (Body only. battery: 11.8 oz. / 335g)
Operating Environment
Working Temperature Range 0&deg; C- 45&deg; C / 32&deg; F - 113&deg; F
Working Humidity Range 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Important Notice About Your Canon Product
Advisory Type
Date 10.16.05
Title Canon Support | Service Notice: Owners of Canon EOS 1D Mark II
Advisory Type
Date 12.31.08
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
Title Canon Support | Service Notice: Mistaken Origin Displayed on Packaging of Optional Interface Cables
Advisory Type
Date 02.19.08
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
