Canon Support for EOS-1D X Mark III | Canon U.S.A., Inc.
EOS-1D X Mark III
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
High-sensitivity, high-resolution, large single-plate full-frame CMOS sensor
Pixels
Effective Pixels: Approx. 20.1 megapixels
Total Pixels
Approx. 21.4 megapixels
Aspect Ratio
3:2 (Horizontal: Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
High Detail Low Pass Filter, breaking one incoming light ray into 16 rays at image sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit
Self-cleaning can be done automatically when the power is turned on/off.During manual cleaning ([Clean now]), the data for light spot correction is also obtained.(2) Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.(3) Manual cleaning
Recording Format
Design Rule for Camera File System 2.0 and EXIF 2.31*
* Supports time difference information.
File Name
File Size
JPEG (8bit), HEIF (10 bit), RAW (14 bit, Canon original)
Backup Recording
N/A
File Numbering
The following three types of file numbers can be set:
(1) Continuous numbering The numbering of captured images continues even after you replace the card.(2) Auto resetWhen you replace the card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.(3) Manual reset Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Simultaneous recording of any combination of RAW/C-RAW and JPEG or HEIF image-recording quality is supported.
Color Space
sRGB, Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Defined 1-3*
* [Standard] is the default setting for [User Def. 1-3]
Settings
Auto (Ambience priority/White priority), Daylight, Shade, Cloudy*1, Tungsten Light, White Fluorescent Light, Flash (Auto Setting)*2, Custom (Custom WB) 1-5*3, Color Temperature
*1 Also effective in twilight and sunset.
*2 With an EX or EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000K if the flash unit does not have the color temperature communication feature.
*3 [Select image on card], [Record and register WB], and [Edit WB name] are supported. HEIF image cannot be selected.
Auto White Balance
Option between ambience priority and white priority settings
Color Temperature Compensation
Blue/amber bias: ±9 levelsMagenta/green bias: ±9 levelsCorrected in reference to the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
Eye-level SLR type, with pentaprism
Coverage
Approx. 100% vertically and horizontally
Magnification
Approx. 0.76x (-1m-1 with 50mm lens at infinity) / 35.1° angle of view
Eye Point
Approx. 20mm (at -1m-1 from eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0 m-1 (diopter)
Focusing Screen
Fixed
Mirror
Quick-return half mirror
Viewfinder Information
AF displays, with red dot-matrix illumination:
191 AF points; active AF Area; Zone AF brackets; Automatic AF point select brackets
Exposure Displays:
Manual mode icon; AE Lock icon; Flash ready icon; FEL icon; Shutter speed; Aperture; Exposure compensation scale; Frames remaining on card; ISO; Highlight Tone Priority (D+) active; AF confirmation icon; AI Servo AF active arrows
Right side display:
+/- 3-stop metering scale; Flash Exposure Compensation/FEL/Flash Metered Manual scale; Frames remaining in burst (0,99); JPEG/RAW icons; Battery level icon
Displayed on focus screen, via LCD overlay:
Spot metering circle; Electronic level display; Grid lines; Shooting mode; Metering mode; White Balance setting; Drive mode; AF Operation; Flicker Detection icon; Warning symbol; AF status indicator
All except Spot meter circle can be displayed or not with [Show/Hide in viewfinder]
Depth Of Field Preview
Provided
Type
TTL secondary image-forming phase-difference detection system with High-res AF Sensor
AF Points
Max. 191 points (Cross-type AF points: Max. 155 points)The number of AF points, cross-type AF points and dual cross-type AF points vary depending on the lens used.
AF Working Range
Focusing Modes
(1) Autofocus
One-Shot AFAI Servo AF(2) Manual focus
AF Point Selection
Manually-selected AF Areas
Spot AFSingle-point AFAF point Expansion (4-point surround)AF point Expansion (8-point surround)Zone AFLarge Zone AF (all AF points divided into three large zones)
Automatic AF point selection (all AF points available; reference brackets around AF array)
AF Function Registration/Switching
Customizable with Custom Controls
Selected AF Point Display
Red dot-matrix illumination of AF points, zone AF brackets, and Auto AF Area brackets
Active AF Point Indicator
(1) Displayed in viewfinder area
AF Assist Beam
When an external EOS-dedicated Speedlite is attached to the camera, the following options are available:
(1) Enable
(2) Disable
(3) IR AF assist beam only
Metering Modes
Optical Viewfinder: 216-zone (18 x 12) metering with approx. 400,000-pixel RGB+IR metering sensor.
Live View: 384-zone (24 x 16) metering using image sensor output signals
The following metering modes selectable:
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (Viewfinder: Approx. 6.2% of the screen) (Live View: Approx. 5.8% of the screen)
(3) Spot metering (center, approx. 1.5% of viewfinder) (Live View: Approx. 2.9% of the screen)
Center spot meteringAF point-linked spot metering (Custom Function)
Linkable to all AF points.With automatic AF point selection, center spot metering will apply.Multi-spot metering (Optical Viewfinder only)(4) Center-weighted average metering
The selectable metering modes can be restricted (Custom Function).
Metering Range
At 73°F/23°C, ISO 100, with evaluative metering: EV 0–20 (Optical Viewfinder)EV -3–20 (Live View)EV -1–20 (Movie Recording)
Exposure Control Systems
(1) Program AE (Shiftable)
(2) Shutter-priority AE (Safety shift possible)
(3) Aperture-priority AE (Safety shift possible)
(4) Manual exposure
The metering mode can be specified.(5) Bulb
(6) Three custom shooting modes
ISO Speed Range
Manual settingHighlight Tone Priority: ISO range 200–102400. Expanded ISO cannot be set during HDR shooting.Auto setting*1 ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced].*2 Varies depending on [Maximum] and [Minimum] of [Auto range]. *3 ISO 1600 when using a lens that is not compatible with "Variable control of maximum ISO Auto limit for E-TTL".*4 If outside the setting range, changed to the value closest to ISO 400.
Adjusted by user: ±5 stops in 1/3- or 1/2-stop incrementsAEB: ±3 stops in 1/3- or 1/2-stop increments * Indicated up to ±3 stops on the LCD panel and in the viewfinder.
AE Lock
(1) Auto AE lock
In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.(2) User-applied AE lock
With AE lock button in P, Av, Tv and M modes. (AE lock is updated each time you press the button.)Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlledLive View: Mechanical, Electronic 1st-curtain, and Electronic shutter operation selectable
Shutter Speeds
When [Mechanical] or [Elec. 1st-curtain] is set: 1/8000 to 30 sec., bulb
When [Electronic] is set: 1/8000-0.5 sec.
X-sync: 1/250 sec.
Available shutter speed range can be set via Custom FunctionFlash shooting not possible during Electronic shutter operation
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay
EOS Dedicated Speedlite
E-TTL II autoflash with all EX and EL Series Speedlites
Zooming to Match Focal Length
Provided
Flash Metering
Ambience Priority, Standard, Flash priority
FE Lock
Provided
External Flash Settings
(1) E-TTL each shot    (New E-TTL reading for each exposure in a continuous sequence) (2) E-TTL 1st shot    (Flash exposure locked for 2nd and subsequent exposures in a continuous sequence)Available for EX and EL series Speedlites. (1) General speedlite settings:     Flash firing; E-TTL balance; E-TTL II metering; Continuous flash control; Flash sync speed in Av mode (2) Flash function settings:     Flash exposure mode; Wireless flash control; Flash head zoom; Flash sync (1st/2nd curtain sync and High-speed sync); Flash exposure compensation; Flash exposure bracketing (3) Flash Custom Function settings
PC Terminal
Provided
* No polarity.
* Sync speed: Since the flash duration of studio flash units vary, set a sync speed within 1/125 sec. to 1/30 sec. and check if the flash sync works.
* Both the accessory shoe (X-sync contact with maximum sync speed of 1/250 sec.) and the PC terminal can be used simultaneously for simultaneous flash firing.
Drive Modes
(1) Single shooting (2) High-speed continuous shooting*:       Viewfinder: Max. approx. 16 shots/sec. (user-adjustable 16,3 fps)       Live View Shooting: Max. approx. 20 shots/sec. (3) Continuous Shooting:       Viewfinder: Max. approx. 10 shots/sec. (user-adjustable 15,2 fps)       Live View Shooting*1: Max. approx. 10 shots/sec.*2 (4) Low-speed continuous shooting       Viewfinder: Max. approx. 3 shots/sec. (user-adjustable 14,1 fps)       Live View Shooting*1: Max. approx. 3 shots/sec. (5) Silent single shooting (6) Silent high-speed continuous shooting       Viewfinder: Max. approx. 8 shots/sec. (user-adjustable 8,2 fps)       Live View Shooting*1: Max. approx. 10 shots/sec.*2 (7) Silent low-speed continuous shooting       Viewfinder: Max. approx. 3 shots/sec. (user-adjustable 14,1 fps)       Live View Shooting*1: Max. approx. 3 shots/sec. *Continuous shooting speed may be slower under the following conditions: shutter speed, aperture, aperture status during continuous shooting, flash, anti-flicker shooting set to Enable, remaining battery level, temperature, subject conditions, brightness (shooting under low light, etc.), lens type, power source type, when internal memory is full (momentarily prevents shooting). *1 When the electronic shutter is used, the shooting speed of the continuous shooting becomes the same as the high-speed continuous shooting. *2 When the mechanical shutter is used, the shooting speed of the continuous shooting will be approx. 8.0 shots/sec.
Maximum Burst
The maximum burst during continuous shooting is as follows:
* File size, number of possible shots, and maximum burst vary depending on shooting conditions (including JPEG/HEIF image quality: 8, subject, memory card brand, card storage capacity, ISO speed, Picture Style, and Custom Function, etc).
*1 The number of possible shots and standard maximum burst apply to a compliant 325GB card based on Canon testing standards, in viewfinder shooting.
*2 With [HDR PQ] set to [OFF].
Shooting Modes
Still photo and video recording
Focusing
(1) Dual Pixel CMOS AF
Dual Pixel CMOS AF is possible with all EF lenses.(2) Manual focus
Magnify the image by 5x or 10x and focus manually. MF peaking and Focus Guide possible
Metering Modes
(2) Partial metering: Approx. 5.8% of the screen
(3) Spot metering: Approx. 2.9% of the screen
AE lock possible. The active metering timer can be changed.
Metering Range
EV -3–20 (at 73°F/23°C, ISO 100, with evaluative metering)
Grid Display
(1) Off
(2) 3x3
(3) 6x4
(4) 3x3+diag
Silent Shooting
Possible with Shutter mode set to ElectronicAudible sounds possible from lens operation, etc.Flash not possible when LV Shutter mode set to Electronic
File Format
Normal movie recording:
MPEG4 H.264 / AVC8-bit, 4:2:0; Color space BT.709Canon Log recording:
MPEG4 H.265 / HEVC10-bit, 4:2:2; Color space BT.709 / BT.2020Audio: AAC or Linear PCM (Audio Compression in C.Fn menu, during ALL-I or IPB recording)
Internal monaural microphone3.5mm stereo external microphone jack
File Size
* AF does not function.
** Audio not recorded at High Frame Rate 119.90 fps recording
^ 24p recording will be supported through firmware update after shipping.
Focusing
(2) Manual focus
* Magnify the image by 5x or 10x and focus manually (not possible during movie shooting).
Exposure Control
Up to ±3 stops in 1/3- or 1/2-stop increments * If AE Microadjustment is performed, the settable exposure compensation amount will decrease by the amount of the AE Microadjustment. For example, if you set the AE Microadjustment to +1 stop, the exposure compensation amount will be limited to a maximum +2 stops on the positive side.
Audio Video Output
Canon Log: OFF (H.264 / AVC)
* Bit rate indicates video output only, audio is not included.
* Movie recording is interrupted if the maximum recording time per movie, 29 min. 59 sec., is exceeded. (Time is different for High Frame Rate movies.)
*Sound is not recorded for approx. the last two frames when the compression method for movie recording quality is IPB or IPB Light (audio: AAC) and [C. Fn 7-7 Audio compression] is set to [Enable]. The video and sound may be slightly out of sync when movies are played back in Windows.
Canon Log: ON (H.265 / HEVC)
Type
TFT color, liquid-crystal monitor
Monitor Size
Size: 3.2-inches (aspect ratio 3:2)
Diagonal: Approx. 3.15 in. / Approx. 8.01 cm
Width: Approx. 2.63 in. / Approx. 6.67 cm
Height: Approx. 1.75 in. / Approx. 4.44 cm
Pixels
Approx. 2.1 million dots
Coverage
Approx. 100% vertically and horizontally Viewing angle: Approx. 170° vertically and horizontally
Brightness Control
7 levels provided (manually adjustable, in Set-up Menu)
Interface Languages
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, and Japanese)
Display Format
* In certain countries and regions, the use of GPS may be restricted. Therefore be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
Highlight Alert
On the single-image display, highlight areas without any image information will blink.
Items
Frame Grab from 4K Movies:
Individual frames in 4K movies recorded with the camera can be saved as JPEG still photos.Approx. 8.8 megapixels (4096 x 2160) or approx. 8.3 megapixels (3840 x 2160)Frame grab images cannot be resized or cropped in-camera.
Protection
Erase protection: single image; select range; all images in folder; all images on card; all found images
Unprotection: all images in folder; all images on card;
Erase
Erase a single image, selected images, select range, all images in a folder, all images in a card or all found images.
Compatible Printers
N/A (Direct printing not possible)
DPOF
Version 1.1 compatible
Compatible Images
JPEG, RAW/C-RAW, HEIF images, and movies
*Individual and multiple image files can be selected
Custom Functions
Total 38
Camera User Settings
Current camera settings can be registered to C1, C2 and C3 in Set-up Menu (called-up for shooting on top LCD panel).Automatic updating of the registered settings can be set to Enable or Diable.* The saving of individual settings for still photos and movies is supported.
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered.
Up to five My Menu tabs can be added.
USB Terminal
USB Type-C
SuperSpeed Plus USB (USB 3.1 Gen 2)
For computer communication
Video Out Terminal
Type C (Resolution switches automatically) / CEC not compatible.Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Extension System Terminal
Wireless File Transmitter WFT-E9
* WFT-E6 and WFT-E8 are not supported.
Battery
Battery Pack LP-E19 (supplied)
Number of Shots
Approx. (Based on CIPA testing standards)
Battery Check
4-level remaining charge display icon in viewfinder, top LCD panel, and LCD screen (when shooting info displayed)Battery info. in Set-up Menu — % charge remaining, shutter count on current charge, and recharge performance displayed
Power Saving
Power turns off after the set time (1, 2, 4, 8, 15 or 30 min.) of non-operation elapses.
Date/Time Battery
Rechargeable built-in secondary battery
Maintains date/time for approx. 1 month, if primary battery pack removed or depletedRecharged by installation of charged LP-E19Recharging time approx. 8 hours
Start-up Time
Approx. 0.2 sec. (Based on CIPA testing standards)
Dimensions (W x H x D)
Based on CIPA guidelines: Approx. 6.22 x 6.60 x 3.25 in. / 158.0 x 167.6 x 82.6mm (W x H x D)
Weight
Approx. 44.09 oz. / 1250g (Body only)
Approx. 50.80 oz. / 1440g ( Including battery, and memory card)
* Weighed without body cap and eyecup.
Working Temperature Range
32-113°F/0-45°C
Working Humidity Range
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS-1D X Mark III: Firmware Version 1.2.1
Advisory Type
Date 10.06.20
Title Canon Support | Firmware Notice: EOS-1D X Mark III: Firmware Version 1.3.0
Advisory Type
Date 11.17.20
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Firmware Notice: EOS-1DX Mark III: Firmware Version 1.2.0
Advisory Type
Date 08.25.20
Title Canon Support | Firmware Notice: EOS-1D X Mark III: Firmware Version 1.5.0
Advisory Type
Date 07.06.21
Title Canon Support | Firmware Notice: EOS-1D X Mark III: Firmware Version 1.1.0
Advisory Type
Date 04.06.20
Title Canon Support | Service Notice: Future Firmware plan to support advanced video recording functions for EOS-1D X Mark III and EOS R5
Advisory Type
Date 08.25.20
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Canon Support | Firmware Notice: EOS-1D X Mark III: Firmware Version 1.6.0
Advisory Type
Date 11.30.21
Title Firmware Notice: EOS-1D X Mark III: Firmware Version 1.6.1
Advisory Type
Date 02.07.22
Title Canon Support | DPP high-performance noise reduction processing
Advisory Type
Date 07.15.21
Title Firmware Notice: EOS-1D X Mark III: Firmware Version 1.6.2
Advisory Type Firmware Notice
Date 10.18.22
Title Firmware Notice: EOS-1D X Mark III: Firmware Version 1.7.1
Date 03.30.23
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Firmware Notice: EOS-1DX Mark III: Firmware Version 1.9.0
Date 03.26.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Firmware Notice: EOS-1D X Mark III: Firmware Version 1.8.0
Date 09.26.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
