Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 12.18.25
File Size 11.92 MB
Date 08.19.26
File Size 459.76 KB
Date 12.07.20
File Size 270.83 KB
Date 04.25.22
File Size 380.26 KB
Date 11.11.20
File Size 304.02 KB
Date 11.04.25
File Size 57.06 MB
Date 11.26.25
File Size 1.10 MB
Date 11.26.25
File Size 4.69 MB
Camera Connect
Camera Connect
image.canon
image.canon
Effective Pixels 4096x2160: when 4096 x 2160 or 2048 x 1080 is selected as the resolution (Approx. 8.85 megapixels)
3840 x 2160: when 3840 x 2160 or 1920 x 1080 is selected as the resolution (Approx. 8.29 megapixels)
Total Pixels
4206 x 2280; Approx. 9.6 megapixels
Sensor Type
CMOS
Sensor Size Super 35mm
4K: 26.2 x 13.8 (29.6 mm diagonal)
UHD: 4K: 24.6 x 13.8 (28.2 mm diagonal)
Sensor Modes Super 35mm, Super 16mm(cropped)
Pixel Pitch
6.4 µm
Scanning System
Progressive
Number of Sensors
1
Filter
RGB Primary Color Filter (Bayer Array)
Imaging Processor
DiG!C DV 7
Lens Mount
Default Mount: RF Mount
Zoom/Focus Preset
Not Available
Shockless Zoom
Not Available
Digital Teleconverter
1.5x/2.0x/2.5x/3.0x
ND Filter
Mechanical ND filter system with option of clear, 2, 4, and 6 stops; 8 and 10 stops in extended mode
Peripheral Illumination Correction
Available
Chromatic aberration Correction
Available
Distortion Correction
Available (RF Lenses only)
Diffraction Correction
Available
Exposure Modes
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control
(3) Auto ISO mode
Metering Modes
Standard, Spotlight and Backlight
Gain
Normal Setting -6dB to 54dB
Fine Setting -2dB to 54dB in 0.5 dB increments
ISO
100 to 102,400
Auto Gain Control (AGC)
Not Available
Shockless Gain
Not Available
Exposure Compensation/AE Shift
2.0 to +2.0 in 0.25 point intervals
Shutter Modes
3 Modes: OFF; Speed; Angle; Slow Shutter; Clear Scan
Speed Mode is selected in 1/3 or 1/4 stop increments
Shutter Speed Range
59.94Hz/24.00Hz: 1/12 to 1/2000
50.00Hz: 1/15 to 1/2000
Shutter Angle Settings
59.94Hz/50.00Hz/24.00Hz: 360, 240, 180, 120, 90, 60, 45, 30, 22.5, 15, 11.25
Iris Settings (EF)
Can be set to 1/2 stop, 1/3 stop or Fine.
(1) Push auto iris control
(2) Auto iris control (Compatible lens required)
Focus Control
Dual Pixel CMOS AF with EOSxITR
Focus Modes
Manual focus, Continuous AF, One-Shot AF, AF-Boosted MF, Face Detection AF
Only lenses that support AF functions can be used in AF modes. Face Detection and Tracking AF in Slow & Fast recording modes (24-120p). New with Firmware update 1.0.5.1.
System Frequency
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P
50.00 Hz mode: 50.00i/50.00P/25.00P
24.00 Hz mode: 24.00P
Resolution
ModeResolutionFrame Rates
XF-AVC4096x2160/
3840x2160
59.94p / 29.97p /
23.98p / 50.00p /
25.00p / 24.00p
2048x1080/
1920x1080
59.94p / 29.97p /
23.98p / 50.00p /
25.00p / 24.00p
 1280x720 59.94p/50p
MP44096x2160 / 3840x216059.94p / 29.97p / 23.98p /
50.00p / 25.00p / 24.00p
2048x1080 / 1920x108059.94p / 29.97p / 23.98p /
50.00p / 25.00p / 24.00p/ 59.94i / 50i
1280x72059.94p / 50p
Color Gamuts*
Cinema Gamut, BT.709, BT.2020
Gamma Curves*
Canon 709, BT.709, Wide DR, Canon Log 2, Canon Log 3, PQ, HLG
*Enabled for recording (including proxy) and output from each terminal
Internal Recording
RAW Recording/ Cinema RAW Light: RAW HQ (high quality), RAW ST (standard quality), and RAW LT (light recording).
Video Compression Formats
XF-AVC: MPEG-4 AVC/H.264 (10bit, 8bit (proxy))
MP4(HEVC): H.265/HEVC (10bit)
MP4(H.264) : MPEG-4 AVC/H.264 (8-bit)
Audio Recording System
XF-AVC: Linear PCM (24bit, 48kHz) 4-channel recording
MP4 (1) : MPEG-2 AAC LC (16-bit, 48 kHz, 2-channel)
MP4 (2) : Linear PCM (16-bit, 48 kHz, 4-channel)
SD Cards Approved by Canon Inc.
ModelManufacturerCapacity (GB)Speed Class
RP-SDZA64GAKPanasonic64C10/U3/V90
RP-SDZA128AKPanasonic128C10/U3/V90
PGSD128GBCKNAProGrade128C10/U3/V90
AVP128SDMK2V90Angelbird128C10/U3/V90
AVP256SDMK2V90Angelbird256C10/U3/V90
Recording Time
XF-AVC Recording Times
Capacity (XF-AVC)Recording mode (minutes)
600Mbps500Mbps410Mbps310Mbps300Mbps260Mbps250Mbps240Mbps
32 GB0608091213151616
64 GB1316192527303233
128 GB2732395154616466
256 GB546578103108123128133
512 GB109131156207216246256267
160Mbps50Mbps35Mbps24Mbps17Mbps
32 GB2580114167236
64 GB50160229334472
128 GB100321458668994
265 GB20064291713371888
512 GB4011284183426753776
SD
Card
H.265 MP4
64
GB
225 Mbps
170 Mbps
135 Mbps
100 Mbps
35 minutes
47 minutes
59 minutes
80 minutes
50 Mbps
35 Mbps
12 Mbps
9 Mbps
160 minutes
229 minutes
668 minutes
891 minutes
SD
CARD
H.264 MP4
64
GB
150 Mbps
35 Mbps
8 Mbps
53 minutes
229 minutes
1003 minutes
File Format SD Card x 2 slots
(Still Images (JPEG), Custom Picture Data, Clip Metadata, and menu settings); SD/SDHC/SDXC Supported
File Format XF-AVC: MXF (OP-1a)
MPEG4: MP4
HEVC: MP4
File System
SDHC card: (up to 32 GB): FAT32
SDXC card (more than 32 GB): exFAT
File division unit: 4 GB for FAT32, none for exFAT
Maximum Clip Number
999 (per media)
Recording Format
Linear PCM; 4-Channel; 24-Bit; 48 kHz
Built-in Microphone
Stereo/Monaural
External Audio Inputs
2 Mini-XLR inputs (Auto and Manual level settings)
External microphone terminal: (3.5 mm diameter)
Recording Chanel Selection
Up to 4 channel audio recording is supported.
XLR Mic Trimming
Available; -12dB, -6 dB, 0dB or +12 dB
Limiter
Available
Recording Level Adjustment Range
- Infinity to +18dB
Phantom Power
Available; +48V
Headphone Adjustment
16 Settings; Volume is muted at lowest setting
Built-in Speaker
Available; Volume Adjustable
1KHz Tone
Available (off, -12, -18, or -20 dB)
Playback
Clip Display: 3x4 Index Display.
Clip Playback: Forward Search (x5, x15, x60), Reverse Search (x5, x15, x60), Forward frame Advance, Reverse Frame Advance, Record Review, Skip to next clip, skip to previous clip
Clip information Display: Clip Metadata display, custom picture settings
Playback Functions: Clip Delete
Photo Playback: index, single playback, delete, protect
Slow and Fast Motion Recording
Available; Records at a different frame rate then the playback rate allowing for fast and slow motion effects:
Sensor ModeRecording ModeAvailable Frame Rates
Super35XF-AVC
 23.98P/24P: 12-120
 29.97P: 15-120
 25P/50P: 15-120
 59.94P: 15-120
Super16
(Crop)
XF-AVC
 23.98P/24P: 12-180
 29.97P: 15-180
 25P/50P: 15-180
 59.94P: 15-180
Super35MP4
 23.98P/24P: 12-120
 29.97P/24P: 15-120
 25P/50P: 15-120
 59.94P: 15-120
Super16
(Crop)
MP4
 23.98P/24P: 12-120
 29.97P: 15-180
 25P/50P: 15-180
 59.94P: 15-180
Special Recording Functions
Relay Recording*; Double-Slot Recording**
* Not available during Slow Motion recording
** Not available in combination with slow and fast motion recording or relay recording
Photo Recording Mode
Available; Images captured to SD Card
Waveform Monitor
Available (HDR Compatible);
(a) Line display
(b) Line + spot: Line display over a red waveform in a red frame.
(c) Line select display
(d) RGB (parade)
(e) YPrPb (parade)
Output gain can be selected as either 1x or 2x. With gain set to 2x, the vertical axis (Y-position) offset value can be chosen.
When gamma is set to PQ, a PQ index (nits index) can be displayed. When gamma is set to HLG, an HLG index (0.01.0 relative index) can be displayed.
Vectorscope
Available
False Color
Available
Exposure / Focus Aids
Peaking (2 types), Zebra Pattern, Magnify, Black and White Mode, Focus Guide
Frame Record
Not Available
Pre-Record
Yes, 3 seconds cache (Audio and Video)
Time code
Drop Frame (DF) and Non-Drop Frame (NDF)
Time Code Modes
Regeneration, Record Run, Free Run and External Source
Auto White Balance (AWB)
Available
White Balance
Kelvin Setting:
2,000K to 15,000K in 100K increment
-20CC to +20CC in 1 CC increments
White Balance Presets
Daylight (5,600K); Tungsten (3,200K), Custom A, Custom B
Auto Black Balance Available
Custom Picture Settings
20 Custom Picture settings
Custom pictures can be adjusted using the following settings and saved for later recall:
Gamma, Black, Black Gamma, Low Key Saturation, Knee, Sharpness, Noise Reduction, Skin Detail, Selective Noise Reduction, Color Matrix, White Balance, Color Correction, Setup Level
Custom Pictures can be saved to an SD card for later use or transferring between cameras
Custom Display
Yes; LCD panel and EVF information display can be customized
On Screen Markers
Available marker options include center, horizontal, grid, aspect, safety zone, and user marker.
With user markers, user can set their preferred size and position.
Markers can be displayed in yellow, blue, green, red, black, gray, or white.
Assign Buttons
13 total assignable buttons on body
Color Bars
Color bars compliant with SMPTE, EBU, or ARIB standards can be selected depending on system frequency selected
Sensitivity
59.94 Hz: f/10 (2048x1080/59.94P) or f/14 (1920x1080/29.97P)
50.00 Hz: f/11 (2048x1080/50.00P) or f/16 (1920x1080/25.00P)
All values for ISO 800, 2000 lux, and reflectance rate of 89.9%
Dynamic Range
Canon Log 2: 1600% / 16+ stops (ISO 800)
Canon Log 3: 1600% / 14 stops (ISO 800)
Type
3.5-inch (8.8 cm diagonal) color wide-screen LCD
Approx. 2,760,000 dots (1280 x RGB x 720),
Aspect Ratio
16:9
Field of View Coverage
100%
Display Adjustments
Brightness, Contrast, Color, Sharpness, and Luminance
Time code In/Out
Yes; BNC Connector (Input and Output)
HDMI
Yes (Type A)
[4096x2160/3840x2160]/1920x1080/1280x720
Audio Input Terminal
2 Balanced 3-pin XLR (Mic Level, Mic Level with phantom power and Line Level)
3.5mm Microphone terminal
Headphone Jack
Available; 3.5mm stereo mini-jack
Remote Terminals
Remote A (Standard LANC Compatible or RC-V100)
Remote Control through WiFi/LAN Adapter
USB
Available
CCU
Remote Controller RC-V100 (Optional)
Supply
14.4V DC (Battery Pack)
Power Terminal
14.4 V DC (battery pack), 24.0 V DC (DC IN)
Battery
BP-A Series (BP-A30, BP-A60)
Compact Power Adapter
CA-CP200L (for Camera and Battery charger CG-A20)
GPS Receiver
GP-E2 with Interface cable IFC-40AB III / IFC-150AB III) Via USB-C
Wi-Fi Adapter / Ethernet Adapter
TypeBrandModelNotes
Wi-FiASUSUSB-AC68Requires USB to USB-C adapter
ASUSUSB-AC56Requires USB to USB-C adapter
TP-LINKArcher T9UHRequires USB to USB-C adapter
EdimaxEW-7822UACRequires USB to USB-C adapter
 I-O DATAWN-AC867U DWA-182(C1)*
*Not compatible with DWA-182(D1)
EthernetStarTechUS1GC30W
TP-LinkUE300Requires USB to USB-C adapter
Mount Adapters
Canon Mount Adapter EF-EOS R 0.71x
Canon Control Ring Mount Adapter EF-EOS R
Canon Drop-In Filter Mont Adapter EF-EOS R with Circular Polarizer Filter
Canon Drop-In Filter Mont Adapter EF-EOS R with Variable ND Filter
Dimensions
(Width x height x depth, excluding cable and grip belt)
Body Only: Approx. 130.2 x 160 x 115.9 mm
Weight
RF Camera body: Approx. 1.17 Kg (2.6 lbs)
Battery Pack BP-A30: Approx. 225 g (7.9 oz.)
Compact Power Adapter CA-CP200L: Approx. 290 g (10.2 oz.) *Not including AC cable
Battery Charger CG-A20: Approx. 145 g (5.10 oz.)
Mic holder unit: Approx. 56 g ( 2.0 oz.)
Body cap: Approx. 17 g (0.60 oz.)
Temperature and Humidity
Performance requirements: 0ºC to 40ºC, 85% (relative humidity)
Operating requirements: -5ºC to 45ºC, 60% (relative humidity)
Language Support
English, Japanese, Chinese, German, Spanish, French, Italian, Korean, Russian
Time and Date
Automatic Calendar range January 1st, 2020 through December 31, 2050
World Clock
World Clock support UTC time setting: Setting range from +14:00 to -12:00
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Title Canon Support | Service Notice: EOS C70
Advisory Type
Date 06.12.21
Title For Users that Use the Continuous Recording Functions of Professional Camcorders and Digital Cinema Cameras
Advisory Type
Date 07.27.22
Title Firmware Notice: EOS C70: Firmware Version 1.0.2.1.00
Advisory Type
Date 12.07.21
Title Firmware Notice: EOS C70: Firmware Version 1.0.1.1.00
Advisory Type
Date 07.29.21
Title Firmware Notice: EOS C70: Firmware Version 1.0.3.1
Advisory Type
Date 03.23.22
Title Firmware Notice: EOS C70: Firmware Version 1.0.4.1
Advisory Type
Date 09.20.22
Title Software Notice: EOS C70: Remote Camera Control Application for macOS Version 1.1.0
Advisory Type
Date 06.20.23
Title Software Notice: Remote Camera Control Application for Windows Version 1.5.0
Advisory Type Software Notice
Date 11.28.23
Title Software Notice: Multi-Camera Management Application Version 1.0.0
Date 11.28.23
Title Software Notice: Remote Camera Control Application for macOS Version 1.2.0
Date
Title Firmware Notice: EOS C70: Firmware Version 1.1.4.1
Advisory Type Firmware Notice
Date 08.19.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
