Canon Support for EOS M50 | Canon U.S.A., Inc.
EOS M50
Language
Download Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 06.01.23
File Size 142.00 B
Date 06.01.23
File Size 142.00 B
Date 03.27.18
File Size 3.21 MB
Date 06.01.23
File Size 142.00 B
Date 07.08.21
File Size 6.16 MB
Date 02.28.18
File Size 24.16 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at https://developercommunity.usa.canon.com. To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
Digital single-lens non-reflex AF/AE camer
Recording Media
SD/SDHC/SDXC memory card
* UHS-I compatible
Image Format Approx. 22.3 x 14.9mm (APS-C Size)
Compatible Lenses
EF-M lens (and EF/EF-S lenses when using Mount Adapter EF-EOS M)
Equivalent to approximately 1.6x the focal length indicated on a mounted lens
Type
Canon CMOS Sensor
Pixels
Effective pixels: Approx. 24.1 Megapixels
Total pixels: Approx. 25.8 Megapixels
  • Pixel count may decrease due to image processing.
Pixel Unit
Square pixel approx. 3.72 µm
Aspect Ratio
3:2
Dust Deletion Feature
Auto / Manual
Recording Format
EXIF 2.31 (DCF2.0)
JPEG / RAW (CR3 a Canon 14-bit RAW format)
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
RAW: 6000 x 4000
C-RAW: 6000 x 4000
16:9 Aspect Ratio
Large: 6000 x 3368
Medium: 3984 x 2240
Small 1: 2976 x 1680
Small 2: 2400 x 1344
RAW: 6000 x 3368
C-RAW: 6000 x 3368
4:3 Aspect Ratio
Large: 5328 x 4000
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600
RAW: 5328 x 4000
C-RAW: 5328 x 4000
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
RAW: 4000 x 4000
C-RAW: 4000 x 4000
File Number
Continuous, Auto Reset, Manual Reset
RAW + JPEG Simultaneous Recording
Yes
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 13
Picture Style
  • Auto (Ambience priority)
  • Auto (White priority)
  • Daylight (Approx. 5200K)
  • Shade (Approx. 7000K)
  • Cloudy (Approx. 6000K)
  • Tungsten light (Approx. 3200K)
  • White fluorescent light (Approx. 4000K)
  • Flash (Approx. 5200K)
  • Custom
  • Color temp. (Adjustable from 2500K to 10000K in 100K increments)
White Balance Correction
Blue/Amber: ±9 levels
Green/Magenta: ±9 levels
Type
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
Grid Display
3 types
Depth of Field Preview
Provided
Type
Dual Pixel CMOS AF (Face+Tracking AF, Zone AF, 1-point AF)
AF Points
143 / 99 points
AF Working Range
EV -218 (at room temperature 73°F/23°C, ISO 100, when using EF-M 22mm f/2 STM)
Focusing Modes
  1. TTL Autofocus
    • One-Shot AF
    • Servo AF
  2. Continuous AF
  3. MF (Manual Focus)
    • MF Peaking
    • Electronic Manual Focus on Lens (Focus is manually adjusted after One-Shot AF operation)
Continuous AF
Provided
AF Assist Beam
Built-in LED lamp
Metering Modes
Real-time metering using the image sensor
  1. Evaluative metering (384 zones)
  2. Partial metering (6.4%)
  3. Spot metering (2.8%)
  4. Center-weighted average
Metering Range
EV 020 (at room temperature 73°F/23°C, ISO 100)
Exposure Control Systems
  1. Program AE
  2. Shutter-priority AE
  3. Aperture-priority AE
  4. Manual exposure
ISO Speed Range (Recommended Exposure Index)
ISO Auto Range (AUTO mode): ISO 1006400
Max. ISO Speed (P mode): ISO 25600
Max. Expanded ISO Speed (P mode): ISO 51200
Exposure Compensation
  1. Manual: ± 3 stops in 1/3-stop increments
  2. AE Bracketing: ± 2 stops in 1/3-stop increments
AE Bracketing can be used together with manual compensation.
AE Lock
Manual / Auto
Type
Electronically controlled focal-plane shutter
Shutter Speeds
1/4000 sec. to 30 sec.
Highest flash-sync shutter speed: 1/200 sec.
Self Timer
Off, 2 sec. delay, 10 sec. delay, Custom, Remote Shooting
Camera Start-up Time
Approx. 1.0 sec.
Type
Manual pop-up flash
Guide Number
GN approx. 5/16.4 (ISO 100 m/ft.)
Flash Coverage
Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm)
Flash Exposure Compensation
±2 stops in 1/3-stop increments
Flash Metering
E-TTL II autoflash
FE Lock
Provided
External Flash Settings
Flash functions settable with the camera
Drive Modes
Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting)
File Format
MP4
Video: MPEG-4 AVC / H.264
Audio: MPEG-4 AAC-LC (stereo)
File Size
Recording Sizes:
3840 x 2160 (4K UHD), 1920 x 1080 (Full HD) and 1280 x 720 (HD)
Frame Rates
[3840 x 2160]: 23.98 fps
[1920 x 1080]: 59.94 fps / 29.97 fps / 23.98 fps
[1280 x 720]: 119.9 fps / 59.94 fps
Metering Mode
  1. Center-weighted average
ISO Auto Range (AUTO and Manual mode): ISO 1006400
1920 x 1080 (Full HD), 1280 x 720 (HD)
ISO Auto Range (AUTO and Manual mode): ISO 10012800
Expandable to ISO 25600
±3 stops in 1/3-stop increments
Type
TFT color liquid crystal monitor
Monitor Size
3.0 type
Pixels
Approx. 1.04 million dots
Features
Vari-angle
Touch-screen Panel
Electrostatic capacitance type
Brightness Control
Interface Languages
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese)
Display Format
  1. Single-image display
  2. 1 shot + information display
    • Simple information
    • Detailed information
      • Histogram
      • Lens information
      • Picture Style
      • Noise reduction
      • Correction data
  3. Index display
    • 4-image
    • 9-image
    • 36-image
    • 100-image
  4. Image rotate
Highlight Alert
Provided
Image Protection
Provided
Compatible
PictBridge-compatible printers
Resize
Provided
Red-eye Correction
Provided
Compatible Printers
PictBridge
Printable Images
JPEG and RAW* are printable.
*Prints JPEG images after RAW processing.
DPOF
DCF-compliant DPOF compatible (Version 1.1)
Custom Controls (Camera Controls / Buttons Customization)
Functions can be assigned to the following controls (set in Custom Functions):
  • Shutter button
  • Cross button (up, down, left, right)
  • AE lock button
  • M-Fn button
  • Movie button
USB Terminal
Micro USB
Audio / Video OUT Terminal
HDMI OUT terminal Type D
HDMI output while recording (shooting screen without sound) available
HDMI output to HDR compatible TVs* available
* Movie playback not supported. JPEG images are not displayed in HDR.
Battery
LP-E12
Battery Life
Number of Still Image Shots (CIPA compliant: room temperature 73°F/23°C)
Screen On*: Approx. 235 shots
Electronic Color Viewfinder On*: Approx. 235 shots
Number of Still Image Shots (Eco Mode On)Screen On**: Approx. 370 shots
Movie Recording Time (CIPA compliant: room temperature 73°F/23°C)
Screen On: Approx. 85 min.
Electronic Color Viewfinder On: Approx. 85 min.
Movie Recording Time*** (Continuous Shooting)
Screen On: Approx. 130 min.
Electronic Color Viewfinder On: Approx. 130 min.
* Approx. 290 shots when power saving is enabled.
** Approx. 425 shots when power saving is enabled.
*** Total shooting time when shooting is performed under the following conditions: using default AUTO Mode; without using zooming and other operations; when max. recording time per movie is reached and recording stops/resumes automatically.
Playback Time
Approx. 4 hr.
  • Time when playing back a slideshow of still images.
Dimensions (W x H x D)
Approx. 4.6 x 3.5 x 2.3 in. (116.3 x 88.1 x 58.7mm)
  • CIPA compliant.
Weight
Black
Approx. 12.4 oz. / 351g (body only)
Approx. 13.7 oz. / 387g (including battery pack, memory card)
  • CIPA compliant.
White
Approx. 12.5 oz. / 354g (body only)
Approx. 13.8 oz. / 390g (including battery pack, memory card)
  • CIPA compliant.
Working Temperature Range
32-104°F / 0-40°C
Working Humidity Range
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: EOS M50: Firmware Version 1.0.3
Advisory Type
Date 11.20.19
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Service Notice: EOS M50 EF-M 15-45mm IS STM Kit may contain an incorrect battery charger (LC-E17)
Advisory Type
Date 07.10.19
Title Canon Support | Firmware Notice: EOS M50: Firmware Version 1.1.0
Advisory Type
Date 10.18.20
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
