Canon Support for EOS R | Canon U.S.A., Inc.
EOS R
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 12.04.19
File Size 765.66 KB
Date 12.04.19
File Size 32.21 MB
Date 07.07.21
File Size 6.16 MB
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Digital single-lens non-reflex AF/AE camera
Recording Media
SD/SDHC/SDXC memory cards
  • SD card speed class-compatible.
  • UHS-I and II supported.
  • Use of UHS-II microSDHC/SDXC cards with a microSD to SD adapter is not recommended. When using UHS-II supported cards, use SDHC/SDXC cards compatible with UHS-II.
  • Eye-Fi cards not supported.Multimedia cards (MMC) cannot be used.
Image Format
Approx. 36.0 x 24.0mm
Compatible Lenses
Canon RF lens group (excluding EF, EF-S and EF-M lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount
Canon RF mount
Type
CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels
Approx. 30.3 Megapixels
Pixel Unit
Approx. 5.36 &micro;m square
Total Pixels
Approx. 31.7 megapixels
Aspect Ratio
3:2 (Horizontal:Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • At power off only / Enable / Disable. Performed automatically (taking about 3.0 sec. as indicated on the screen) or manually (taking about 9.0 sec. as indicated on the screen).
    • After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
    • When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
    • Not available with EF-S lenses, in cropped shooting or when distortion correction is applied.
  3. Manual cleaning (by hand)
Recording Format
EXIF 2.3 (DCF2.0)
File Size
3:2 Aspect Ratio
Large/RAW/C-RAW: 6720 x 4480
Medium: 4464 x 2976
Small 1: 3360 x 2240
Small 2: 2400 x 1600
1.6x (Crop)
Large/RAW/C-RAW: 4176 x 2784
4:3 Aspect Ratio
Large/RAW/C-RAW: 5952 x 4480*
Medium: 3968 x 2976
Small 1: 2976 x 2240*
Small 2: 2112 x 1600*
16:9 Aspect Ratio*
Large/RAW/C-RAW: 6720 x 3776
Medium: 4464 x 2512
Small 1: 3360 x 1888
Small 2: 2400 x 1344
1:1 Aspect Ratio
Large/RAW/C-RAW: 4480 x 4480
Medium: 2976 x 2976
Small 1: 2240 x 2240
Small 2: 1600 x 1600
  • Values for Recording Pixels are rounded to the nearest 100,000 or 10,000.
  • For RAW and JPEG images, information outside the cropping area is not retained.
  • JPEG images are generated in the set aspect ratio.
  • RAW images are generated in [3:2], and the set aspect ratio is appended.
* Indicate an inexact proportion.
File Numbering
The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Possible
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] will be set automatically.
    • [Standard] is the default setting for [User Def. 1-3].
Settings
  1. Auto
  2. Day Light
  3. Shade
  4. Cloudy*
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature
* Effective also in twilight and sunset.
Auto White Balance
Option between ambience priority and white priority settings.
Color Temperature Compensation
Blue/amber bias: &plusmn;9 levels
Magenta/green bias: &plusmn;9 levels
Corrected in reference to the current WB mode's color temperature.
Type
OLED color electronic viewfinder
Coverage
Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
Coverage
At approx. 23mm eyepoint
Magnification
Approx. 0.76 (with 50mm lens at infinity, -1 m-1)
Eye Point
Approx. 23mm (at -1 m-1 from the eyepiece lens end)
Viewfinder Information
  1. AF point information
  2. Number of remaining multiple exposures
  3. HDR shooting
  4. Multiple-exposure shooting
  5. Dual Pixel RAW shooting
  6. Multi Shot Noise Reduction
  7. Digital Lens Optimizer
  8. AF method
  9. AF operation
  10. Drive mode
  11. Metering mode
  12. Anti-flicker shooting
  13. Shooting mode
  14. Scene icons
  15. AE lock
  16. Flash-ready
  17. Flash off
  18. FE lock
  19. High-speed sync
  20. Shutter speed
  21. Multi-function lock warning
  22. Aperture
  23. Lens information
  24. Exposure level indicator
  25. Exposure compensation
  26. Highlight tone priority
  27. ISO speed
  28. Possible shots
  29. Number of self-timer shooting
  30. Maximum burst
  31. Battery level
  32. Exposure simulation
  33. AEB
  34. FEB
  35. Still photo cropping
  36. Aspect ratio
  37. Auto Lighting Optimizer
  38. Picture Style
  39. White balance
  40. White balance correction
  41. Image Quality
  42. Bluetooth® function
  43. Wi-Fi® function
  44. Histogram
  45. Electronic level
Type
Phase-difference detection system with image sensor (Dual Pixel CMOS AF)
AF Points
Max. 5,655
When selected with cross keys.
AF Working Range
EV -6 to 18 (f/1.2, at 73&deg;F/23&deg;C, ISO 100, One-Shot AF)
Focusing Modes
  1. One-Shot AF
  2. Servo AF
  3. Manual (Manual focus)
AF Point Selection
AF Point Selection and AF Operation
AF Assist Beam
  1. Enable
  2. Disable
  3. LED AF assist beam only
    • Focus range with the AF-assist beam is generally no more than 13.1 ft. / 4m (at f/5.6).
Metering Modes
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 6.1% of the area at the center of the screen)
  3. Spot metering (approx. 2.7% of the area at the center of the screen)
    • AF point-linked spot metering not provided.
  4. Center-weighted average metering
Metering Range
EV -3 - 20 (at 73&deg;F/23&deg;C, ISO 100)
Exposure Control Systems
  1. Scene Intelligent Auto
  2. Flexible-priority AE
  3. Program AE (shiftable)
  4. Shutter-priority AE (Safety shift possible)
  5. Aperture-priority AE (Safety shift possible)
  6. Manual exposure
  7. Bulb
  8. Custom shooting mode C1, C2, C3
ISO Speed Range
Manual Setting
Normal ISO 100–40000 (in 1/3-stop or whole-stop increments)
Expanded L: equivalent to ISO 50, H1: 51200, H2: 102400
  • For [Highlight tone priority], the minimum ISO speed limit will be ISO 200 to 40000.
  • ISO speed safety shift possible with Custom Function.
  • All the expanded ISO speeds including those for movies are only “equivalent speeds.”
Auto
Shooting Mode ISO Settings
No Flash With Flash
Scene Intelligent Auto ISO 100–12800 ISO 100–1600
Fv/P/Tv/Av/M ISO 100–40000*1 ISO 100–1600*1
B ISO 400 fixed ISO 400 fixed
*1 Depending on [Minimum] and [Maximum] of [ISO speed settings] or [Range for stills].
Exposure Compensation
AE Lock
  1. Auto AE lock
    • The metering mode for AE lock after focus can be customized.
  2. Manual AE lock
    • In the Fv, P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
    • Enabled in all metering modes.
Type
Electronically controlled focal-plane shutter
  1. Electronic first curtain, mechanical second curtain
  2. Electronic shutter (slit rolling read out)
  3. Mechanical first and second curtain
Shutter Speeds
1/8000 to 30 sec., bulb (total range of all shooting modes)
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay
Shutter Lag Time
Shutter Lag Time
Flash Metering System
E-TTL II autoflash
Flash Exposure Compensation
&plusmn;3 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
External Flash Settings
The camera can set the following with EX series Speedlites:
  1. External flash control
    • Flash firing, E-TTL II Flash metering, Slow synchro, Safety FE, Flash mode, Wireless function, Flash zoom, Shutter synchronization and Flash exposure compensation
  2. Flash Custom Function setting
    • The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive Modes
  1. Single shooting
  2. High-speed continuous shooting
    • Max. approx. 8.0 fps
      • The conditions are attaining the maximum continuous shooting speed are as follows:
      • Shooting with a fully charged battery in One-Shot AF mode at a 1/1000 sec. or faster shutter speed and maximum aperture (depending on the lens), at room temperature (73°F/23°C), with flicker reduction, Dual Pixel RAW shooting and Digital Lens Optimizer disabled.
      • In One-Shot AF mode with Image Stabilizer off when using these lenses: EF 300mm f/4L IS USM, EF 28-135mm f/3.5-5.6 IS USM, EF 75-300mm f/4-5.6 IS USM, EF 100-400mm f/4.5-5.6L IS USM.
      • The continuous shooting speed for high-speed continuous shooting may be lower, depending on conditions such as these: battery level, temperature, flicker reduction, Dual Pixel RAW shooting, shutter speed, aperture, subject conditions, brightness, AF operation, type of lens, use of flash and shooting settings.
      • The maximum continuous shooting speed may be lower when using a cold battery in cold environments or when the battery level is low, at approx. 6.0 shots/sec.
  3. With Servo AF: Max. approx. 5.0 fps (shooting speed priority) [Silent LV shooting: Mode 1]
    • With Servo AF, the maximum continuous shooting speed may become slower depending on subject conditions or the lens used. Also, the maximum continuous shooting speed will become slower when setting the [LV silent shooting] to [Disable].
  4. Low-speed continuous shooting (Tracking priority)
    • Max. approx. 3.0 fps
    • With Dual Pixel RAW: Max. approx. 2.2 fps
      • High-speed continuous shooting not possible.
  5. Self-timer: 10 sec./remote control
  6. Self-timer: 2 sec./remote control
Shooting Modes
Still photo shooting and video shooting
Focusing
  1. Dual Pixel CMOS AF
  2. Manual focus
    • Magnified view possible by approx. 5x or 10x for manual focusing (not possible during movie shooting).
Metering Modes
  1. Center-weighted average metering
    • Metering brightness range: EV -1 - 20 (at 73°F/23°C, ISO 100)
  2. AF point-linked evaluative metering
    • For face detection with Face detection + Tracking AF.
Metering Range
EV -4 - 18 (at 73&deg;F/23&deg;C, ISO 100, One-Shot AF, with 29.97 fps)
Grid Display
  1. Off
  2. 3x3
  3. 6x4
  4. 3x3+diag
File Format
MP4
Video: MPEG-4 AVC / H.264
  • Variable (averaged) bit rate
Audio:
ALL-I: Linear PCM*
IPB: AAC
*4K All-I recording requires an SD Memory card with a minimum write speed of 60MB/s.
Movie-recording Quality SD Card
4K (UHD)
3840 x 2160
29.97 fps 25.00 fps
24.00 fps, 23.93 fps
ALL-I UHS-II, Video Speed Class 60* or higher
IPB UHS-I, UHS Speed Class 3 or higher
Full HD
1920 x 1080
59.94 fps, 50.00 fps ALL-I UHS-I, UHS Speed Class 3 or higher
IPB SD Speed Class 10 or higher
29.97 fps, 25.00 fps
24.00 fps, 23.98 fps
HDR movies
IPB SD Speed Class 4 or higher
29.97 fps, 25.00 fps IPB
Light
HD
1280 x 720
119.9 fps, 100.0 fps ALL-I UHS-I, UHS Speed Class 3 or higher
59.94 fps, 50.00 fps ALL-I Speed Class 10 or higher
HDR movies
IPB Speed Class 4 or higher
* With Movie crop set to [Disable]. Movie digital IS set to [Disable].
Focusing
  2. Manual focus
Range
Full range (0 to 255)
Exposure Control
Exposure control
Shutter Speed
ISO Speed (Recommended Exposure Index)
Type
TFT color, liquid-crystal monitor
Monitor Size
3.15-inch (screen aspect ratio of 3:2)
3.15 in./8.01cm diagonal (2.63 in./6.67cm width, 1.75 in./4.44cm height)
Pixels
Approx. 2.10 million dots
Coverage
Approx. 100% vertically/horizontally
Brightness Control
Manually adjustable to one of seven brightness levels
Coating
Clear View LCD II
  • Anti-smudge coating provided.
  • Anti-reflection coating not provided.
Interface Languages
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
  1. Single image display
    • No information display
    • Basic information display
    • Detailed shooting information display
      • Detailed information
      • Lens/Histogram information
      • White balance information
      • Picture Style information 1
      • Picture Style information 2
      • Color space/Noise reduction information
      • Lens aberration correction information 1
      • Lens aberration correction information 2
      • Record of sent images
      • GPS information
      • IPTC information
    Display selection is available for Basic information display and Shooting information display.
  2. Index display
    • 4-image index
    • 9-image index
    • 36-image index
    • 100-image index
Highlight Alert
The white areas with no image data will blink.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase
Except protected images
  1. Select images to erase
  2. Select range
Compatible Printers
Images can be sent via Wi-Fi&reg; to a PictBridge-compatible (Wireless LAN) printer and printed.
DPOF
Compliant to DPOF Version 1.1
Custom Controls
Customizable Buttons
Still Photo Shooting Movie Shooting
Shutter button Multi-function button
Movie button LCD panel illumination button
Multi-function button MODE button
LCD panel illumination button AF-ON button
MODE button AE lock button
AF-ON button AF point selection button
AE lock button Lens AF stop button
AF point selection button Up key (cross keys)
Lens AF stop button Left key
Up key (cross keys) Right key
Left key Down key
Right key SET button
Down key
SET button
Customizable Dials
Main dial
Wuick control dial
Control ring
Functions that Can be Assigned (Shooting) Functions that Can be Assigned (Playback)
ISO speed Function shortcut
White balance Jump display
Check focus/Display info.
Movie shooting
AF
User customization
USB Terminal
Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
  1. For PC communication
  2. For WFT-E7 (Ver. 2) connection
    • Shared with terminal for in-camera charging with the USB Power Adapter PD-E1.
    • In-camera charging: although it is compatible with USB Type-C (5V/1.5A) equivalent, do not charge the camera other than with the USB Power Adapter PD-E1.
Video Out Terminal
Type C (Resolution switches automatically) / CEC not compatible
  • Images can be displayed through the HDMI output and on screen at the same time.
  • Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Extension System Terminal
3.5mm diameter stereo mini jack
Battery
Battery Pack LP-E6N (or LP-E6) x 1
  • With the AC Adapter + DC Coupler, AC power is possible.
  • When the Battery Grip BG-E22 is used, two battery packs (LP-E6N or LP-E6) can be installed.
  • With the USB Power Adapter PD-E1, in-camera charging of LP-E6N is possible but LP-E6 cannot be charged. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Battery Check
Automatic battery check when the power switch is turned ON.
Displayed in 6 levels. Battery level displayed on the LCD panel and in the viewfinder.
One of six levels displayed for LP-E6N and LP-E6.
The display for other power sources is different.
Power Saving
Power turns off after the set time of non-operation elapses.Display off
Available time options: 15 sec. / 30 sec. / 1 min. / 3 min. / 5 min. / 10 min. / 30 min.
Auto power off
Available time options: 30 sec. / 1 min. / 3 min. / 5 min. / 10 min.
Disable
Viewfinder off
Available time options: 1 min. / 3 min. / Disable
At least approx. 6 min. until auto power off while the [Date/Time/Zone] screen is displayed.
Date/Time Battery
Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months.
Recharge time: approx. 8 hrs.
The recharge time required to provide the above number of months with no battery pack installed.
Start-up Time
Approx. 0.9 sec.
  • Based on CIPA standards.
Dimensions (W x H x D)
Approx. 5.35 x 3.87 x 3.32 in. / 135.8 x 98.3 x 84.4mm
Approx. 5.35 x 3.87 x 2.67 in. / 135.8 x 98.3 x 67.7mm (from grip to monitor)
Weight
Approx. 1.46 lbs. / 660g (including battery, SD memory card; without body cap)
Approx. 1.28 lbs. / 580g (body only; without battery, card or body cap)
Working Temperature Range
32-104&deg; F / 0-40&deg; C
Working Humidity
85° or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model Price*
Various EOS R cameras $100
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
Title Canon Support | Firmware Notice EOS R Firmware Version 1.1.0
Advisory Type
Date 02.11.19
Title Canon Support | Firmware Notice: EOS R: Firmware Version 1.6.0
Advisory Type
Date 12.04.19
Title Canon Support | Firmware Notice: EOS R: Firmware Version 1.7.0
Advisory Type
Date 07.23.20
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS R: Firmware Version 1.8.0
Advisory Type
Date 11.17.20
Title Canon Support | Firmware Notice EOS R Firmware Version 1.2.0
Advisory Type
Date 04.17.19
Title Canon Support | Firmware Notice EOS R Firmware Version 1.4.0
Advisory Type
Date 09.25.19
Title Canon Support | Firmware Notice EOS R Firmware Version 1.3.0
Advisory Type
Date 08.21.19
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
