Canon Support for imageCLASS D1620 | Canon U.S.A., Inc.
imageCLASS D1620
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.11.22
File Size 1.59 MB
Date 09.11.25
File Size 1.20 MB
Date 09.11.25
File Size 1.20 MB
Date 09.24.23
File Size 1.20 MB
Date 02.03.20
File Size 652.13 KB
Date 01.30.23
File Size 2.92 MB
Date 07.19.23
File Size 405.58 KB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 09.16.24
File Size 2.27 MB
Date 09.24.23
File Size 2.27 MB
Date 07.19.23
File Size 146.85 KB
Date 09.29.21
File Size 1.50 MB
Date 09.16.24
File Size 1.20 MB
Date 03.23.23
File Size 1.60 MB
Date 02.03.19
File Size 407.86 KB
Date 12.23.20
File Size 2.92 MB
Date 02.03.20
File Size 649.44 KB
Date 04.03.19
File Size 645.16 KB
Date 10.03.19
File Size 2.92 MB
Date 12.23.20
File Size 649.44 KB
Date 09.24.23
File Size 1.20 MB
Date 09.16.26
File Size 2.27 MB
Date 09.16.26
File Size 1.19 MB
Date 09.16.26
File Size 1.20 MB
Date 12.23.19
File Size 6.16 MB
Date 12.23.19
File Size 24.59 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS D1620
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS D1620
Products ChromeOS
imageCLASS D1620
Main Unit
Functions Print, Copy, Scan, Send
Item Code 2223C024
Processor Canon Custom Processor
Control Panel 5" Color Touch Panel
Memory 1 GB
Standard Interface Connection USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
Paper Capacity (Letter, 20 Lb. Bond) Standard: 650 Sheets
Maximum: 2,300 Sheets
Paper Sources (Letter, 20 Lb. Bond) Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional (up to three): 550-sheet Paper Cassette (Paper Feeder PF-C1)
Paper Output Capacity (Letter, 20 Lb. Bond) Standard: 150 Sheets
Supported Media Types Cassettes: Thin, Plain, Recycled, Color, Thick, Bond
Stack Bypass: Thin, Plain, Recycled, Color, Thick, Bond, Label, Envelope (10 Envelopes)
Supported Media Sizes (Cassette, Stack Bypass) Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
Supported Media Weights Cassettes: 16 lb. Bond to 32 lb. Bond (52 to 120 g/m2)
Stack Bypass: 16 lb. Bond to 53 lb. Bond (52 to 199 g/m2)
Warm-up Time From Power On: 14 Seconds or Less;
From Sleep Mode: 4 Seconds or Less
Dimensions (W X D X H) Standard (Desktop): 19.5" x 18.3" x 17.8"(494 mm x 464 mm x 452 mm)
For full configuration options and dimensions, please refer to this document.
Installation Space (W X D X H) Standard (Desktop): 23.4" x 39.6" x 28.6" (594 mm x 1005 mm x 724 mm) Fully Configured: 24.0" x 39.6" x 60.9" (634 mm x 1005 mm x 1547 mm)
Weight (Machine Only / Boxed Weight) Machine Only: Approx. 41.9 lb. (19.0 kg)
Boxed Weight: Approx. 54.0 lb. (24.8 kg)
Printer Specifications
Printing Method Laser Beam Printing
Print Speed Up to 45 ppm (Letter); Up to 36 ppm (Legal) Footnote1
First Print-out Time Approx. 6.2 Seconds
Print Resolution 600 x 600 (dpi)
Standard Page Description Languages UFR II, PCL&reg;6, PCL&reg;5, Adobe PostScript 3&reg;
Double-sided Printing Automatic (Standard)
Direct Print Available from USB Memory (JPEG, TIFF, PDF)
Printing From Mobile and Cloud-based Services Apple® AirPrint,® Mopria® Print Service, Canon PRINT appFootnote3
Operating Systems (Print / Scan) UFR II/PCL/PS: Windows® 7/ Windows 8.1/ Windows 10/ Windows Server 2008/ Windows Server 2008 R2/ Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later)
Copier Specifications
Copy Speed Up to 45 ppm (Letter); Up to 36 ppm (Legal)
First Copy-out Time (Letter) Approx. 6.2 Seconds
Copy Resolution (dpi) 600 x 600 (dpi)
Copy Size Platen and ADF: Up to Legal
Multiple Copies Up to 999 Copies
Magnification 25% - 400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 78%
Preset Enlargements 129%, 200%, 400%
Copy Features Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
Scanner Specifications
Scan Type Single-Pass Duplexing Automatic Document Feeder
Document Feeder Paper Capacity (20 Lb. Bond) 50 Sheets
Document Feeder Supported Media Sizes Legal, Letter, Statement
Document Feeder Supported Media Weights Single and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book
Pull Scan ScanGear MF for TWAIN, WIA, and ICA
Supported OS Windows 7 / Windows 8.1 / Windows 10 / Windows Server 2008 / Windows Server 2008 R2/ Windows Server 2012/ Windows Server 2012 R2/ Windows Server 2016 / Mac OS X v10.8.5 (or later)
Scan Resolution (dpi) 300 x 600, 600 x 600 (dpi)
Scan to Mobile Devices Canon PRINT Business
Scan Speed (Letter) Single-sided: 13/38 ipm (300 x 600 dpi) (Color/BW)
Double-sided: 26/70 ipm (300 dpi) (Color/BW)
Memory Media Standard USB Memory (JPEG, TIFF, PDF)
Send Specifications
Destination Email/Internet FAX (SMTP), SMB, FTP
Address Book LDAP (50)/Local (300)/Speed dial (281)
Send Resolution (Dpi) 600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
Communication Protocol File: FTP, SMB; Email/iFax:: SMTP, POP3, iFax (Simple)
File Format Standard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
Security Specifications
Authentication Standard: Department ID Authentication
Network Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
Document Standard: Secure Print
Optional: Encrypted PDF, User and Device Signatures
Wi-fi® Authentication Methods Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
Environmental Specifications
Operating Environment Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
Power Requirements AC 120-127 V:7.1 A, 60 Hz
Power Consumption Maximum: Approx. 1390 W;
Standby: Approx. 17 W;
Sleep Mode: Approx. 0.9 W;
Typical Electricity Consumption (TEC) Rating: 0.47 kWh
Standards ENERGY STAR® certified, EPEAT SilverFootnote5
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
