Canon Support for imageCLASS MF236n | Canon U.S.A., Inc.
imageCLASS MF236n
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 12.19.23
File Size 476.17 KB
Date 10.03.19
File Size 2.92 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 2.27 MB
Date 09.16.26
File Size 1.20 MB
Date 10.07.26
File Size 1.32 MB
Date 09.04.16
File Size 8.80 MB
Date 10.31.19
File Size 7.18 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF236n
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF236n
Products ChromeOS
imageCLASS MF236n
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 24ppm (1-sided plain paper letter)Footnote1
First Print Time 6 seconds or less (letter)Footnote2
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 600 dpi
Maximum Print Size Up to Legal (8.5 x 14 inches)
Print Modes Watermark, Page Composer, Toner Saver
Print Memory 256 MB (shared)
Copier Specifications
Copy Speed Up to 24ppm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text, Photo
Halftones 256 Levels
Warm-up Time 14 seconds or less from power on
First Copy Time Approximately 9 secondsFootnote3
Recovery Time Approximately 2 seconds
Maximum Number of Copies Up to 999 copies
Reduction/Enlargement 25-400% in 1% increments
Copy Size Platen: Up to 8.5 x 11, Feeder: Up to 8.5 x 14
Copy Features Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Copy Memory 256 MB (shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)Footnote4
Fax Resolution Up to 200 x 400 dpi (ultra fine)
Transmission Time Approx. 3 seconds per page
Memory Capacity Up to 256 pagesFootnote5
Speed Dials Up to 4 one-touch speed dials, up to 100 coded dials
Group Dialing 103 destinations
Sequential Broadcasting 114 destinations
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Fax forwarding*, Dual Access, Remote Reception, PC Fax (sending only), Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity / Result Reports, Fax Activity Management Reports
*Fax Forwarding to another registered fax number from memory.
Memory Backup Yes
pC Fax Sending only
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
Scan Size Platen / Feeder: Up to Legal
Compatibility TWAIN, WIA, ICA
Scan Features Push Scan, Pull Scan: USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 1-sheet multipurpose tray, 16-43 lb. (bond, plain paper)Footnote6
Document Feeder 35-sheet Auto Document FeederFootnote6
Paper Output 100 sheets (face down)
Media Sizes Letter, Legal, Executive, Statement
Media Types Plain, Color, Recycled, Heavy, Bond, Label, Envelope
Envelope Capacity 1 (multipurpose tray)
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (network)
Mobile Functions Canon PRINT BusinessFootnote7, Apple® AirPrint®Footnote8, Mopria™ Print ServiceFootnote9
Network Functions Print, PC Fax, Scan
Web Browser Support for Remote UI IE 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS
TCP/IP Set of Application Services Bonjour(mDNS),DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP
OS Compatibility Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012, 2012 R2, 2008, 2008 R2, 2003, 2003 R2, Mac OS 10.6.8 or later
Cable Included Power Cord, Phone Cable (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, MF Scan Utility, Address Book Tool
Environmental Specifications
Power Consumption Approx: Operation: 420 W, Standby: 5.1 W, Energy Saver: 1.1 W (USB), 1.3 W (wired)
General Specifications
Dimensions 15.4"(W) x 14.7"(D) x 14.2"(H)
Unit Weight (without/with cartridge) 25.4 lbs. w/o cartridge, 26.7 lbs. w/ cartridge
Cartridge Type Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard
LCD Display Tiltable, Touch LCD
Duty Cycle Up to 15,000 pages per month, RMPV (Recommended Monthly Print Volume): 500 - 2,000 pages
Security IP/MAC address filtering, IEEE802.1x, SNMPv3, HTTPS/IPPS
Languages English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean
Warranty 1 year limited exchange/carry-in warrantyFootnote11 (extended warranty available)
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Support | Service Notice: FAX Unable to Receive Automatically on the MF236n, MF247dw or MF249dw
Advisory Type
Date 05.20.18
Advisory Type
Date 03.29.15
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
