Canon Support for imageCLASS MF515dw | Canon U.S.A., Inc.
imageCLASS MF515dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.11.22
File Size 1.59 MB
Date 09.11.25
File Size 1.20 MB
Date 09.11.25
File Size 1.20 MB
Date 09.29.16
File Size 717.77 KB
Date 09.24.23
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 05.20.18
File Size 23.81 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 09.29.21
File Size 1.50 MB
Date 09.16.24
File Size 1.20 MB
Date 03.26.17
File Size 716.21 KB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 02.03.20
File Size 649.44 KB
Date 12.19.23
File Size 476.17 KB
Date 04.03.19
File Size 645.16 KB
Date 10.03.19
File Size 2.92 MB
Date 12.23.20
File Size 649.44 KB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 12.21.17
File Size 645.82 KB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 2.27 MB
Date 09.16.26
File Size 1.19 MB
Date 09.16.26
File Size 1.20 MB
Date 10.07.26
File Size 1.32 MB
Date 04.03.16
File Size 29.68 MB
Date 10.03.17
File Size 80.00 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF515dw
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15 Tahoe 26 Golden Gate 27
imageCLASS MF515dw
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 42 ppm (1-sided plain paper letter) / 20.5 ppm (2-sided plain paper letter)1
First Print Time 7.5 seconds or less (letter)2
Printer Language UFR II (Host-based), PCL6 (5c, XL) / PS
Print Resolution Up to 600 x 600 dpi,
1200 x 1200 dpi Quality
Maximum Print Size Up to Legal (8.5 x 14 inches)
Duplex Print Yes
Print Modes Poster, Booklet, Watermark, Page Composer, Toner Saver
Print Memory 1 GB (Shared)
Direct Print from USB PDF/JPEG/TIFF formats
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 42 ppm (1-sided plain paper letter) / 20.5 ppm (2-sided plain paper letter)1
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text, Photo
Halftones 256 Levels
Warm-up Time 16 seconds or less from power on
First Copy Time 9.6 Seconds or Less (Letter)3
Recovery Time 8 seconds or less
Maximum Number of Copies Up to 999 copies
Reduction/Enlargement 25-400% in 1% increments
Copy Size Platen: Up to 8.5 x 14,
Feeder: 5.1 x 5.5 to 8.5 x 14 (legal size)
Copy Features Frame Erase,
Memory Sort,
2 on 1,
4 on 1,
ID Card Copy
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)4
Fax Resolution Up to 406 x 391 dpi (ultra fine)
Transmission Time Approx. 3 seconds per page (ECM-JBIG, transmitting from the memory at 33.6 Kbps)
Memory Capacity Up to 512 sheets4a
Speed Dials 19 one-touch dials, Up to 262 coded dials
Group Dialing 199 destinations
Sequential Broadcasting 310 destinations
Duplex Fax Yes (sending)
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Fax Forwarding, Dual Access, Remote Reception, PC Fax (TX only), Fax Activity / Activity Result Reports, Fax Activity Management Reports, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Memory Backup Yes
Activity Reports Fax Activity / Result Reports, Fax Activity Management Reports
pC Fax Sending only
Fax Forwarding SMB, E-mail, FTP, iFax Simple
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical),
9600 x 9600 (software interpolated resolution)
Scan Size Platen / Feeder: Up to Legal
Duplex Scan Yes
Compatibility TWAIN, WIA 2.0
Output File Formats JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Scan Features Push Scan, Pull Scan, Scan to USB
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Send Specifications
Scan to Email JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Scan to SMB JPEG, TIFF, PDF, PDF(Compact), PDF (OCR)
Paper Handling Specifications
Standard Paper Source(s) 500-sheet cassette plus 100-sheet multipurpose tray5
Optional Paper Source(s) 500-sheet cassette5 (up to 2 cassettes) (PF-45)
Cabinet Type - M1: 24 inches (W) x 25.5 inches (D) x 13.5 inches (H) (Recommended for use with 1 or 2 optional cassettes)
Document Feeder Duplex Auto Document Feeder 50-sheets5
Paper Output 250 sheets (face down)
Paper Weight 16 to 32 lb. bond (plain paper, cassette / option),
16 to 53 lb. bond (plain paper, multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive, Statement, Postcard and Index Card via Multipurpose Tray only
Media Types Plain, Heavy, Recycled, Color, Label, Envelope
Envelope Capacity 10 (Multipurpose Tray)
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n Wireless6, Wi-Fi Direct Connection6a
WiFi Access Mode Infrastructure Mode, WPS Easy Set Up
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS)
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business7, Apple&reg; AirPrint&reg;8, Mopria&trade; Print Service9, Google Cloud Print&trade;10
Network Functions Print, Scan (SMB, E-mail, FTP), PC Fax
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI IE 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1, SNMPv3 (IPv4, IPv6)
OS Compatibility Windows&reg; 10, Windows&reg; 8.1, Windows 8, Windows 7, Windows Vista&reg;, Windows Server&reg; 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X&reg; 10.6 & up
Drivers available for download from www.usa.canon.com
Cable Included Power Cord, Phone Cable (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager
Environmental Specifications
Power Consumption During Operation: 750W, Standby: 11.3W, Energy Saver: 1.4 W (wireless), .7 W (USB), .8 W (wired) in sleep mode
Typical Energy Consumption 1.7kWh
General Specifications
Dimensions 17.9"(W) x 18.8"(D) x 19.9"(H)
Unit Weight (without/with cartridge) 50.8 lbs w/o cartridge,
53.6 w/ cartridge
Package Weight 66.2 lbs.
Cartridge Type Cartridge 324 (Yields approximately 6,000 pages),
Cartridge 324II (Yields approximately 12,500 pages) Single Cartridge System
*Yields based on ISO/IEC Standard
Department Counter Yes
LCD Display 3.5 Inch, Color Touch LCD
Duty Cycle Up to 100,000 pages per month
Department ID Management Yes, up to 300 ID's
Security IP/MAC address filtering, SNMPv3, IPSEC, HTTPS, IEEE802.1x, Department ID (up to 300), Secured Print
Languages English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean
Warranty 1 year limited exchange/carry-in warranty11 (Extended warranty available)
Other Features: Energy Star
PRODUCT LIMITED WARRANTY
Cartridge Warranty
CANON imageCLASS/FAXPHONE/PC Copier TONER /
imageCLASS DRUM LIMITED WARRANTY
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Service Notice: Terms of imageWARE Remote Service
Advisory Type
Date 09.01.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
