Canon Support for imageCLASS MF5950dw | Canon U.S.A., Inc.
imageCLASS MF5950dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 11.06.11
File Size 21.28 MB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 11.06.11
File Size 68.74 MB
Date 09.24.23
File Size 2.27 MB
Date 11.06.11
File Size 4.07 MB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 11.06.11
File Size 13.37 MB
Date 10.03.19
File Size 2.92 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 09.16.26
File Size 1.32 MB
Date 09.16.26
File Size 2.27 MB
Date 09.16.26
File Size 1.20 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF5950dw
imageCLASS MF5950dw
Printer
Printing Method Monochrome Laser
Print Speed (up to) Default Print Mode: 2-sided
Black: Up to 17 ppm (2-sided, plain paper letter)11
Black: Up to 35 ppm (1-sided, plain paper letter)11
First Print Time
6 seconds or less (letter)
Print Resolution (Up to) Up to 600 x 600 dpi
1200 x 600 dpi quality
Toner Compatibility (for Laser MFP) Canon Cartridge 119 (Yield: 2,100 pages*)
Single Cartridge System
Canon Cartridge 119 II Hi-Capacity (Yield: 6,400 pages*)
*Yield is based on ISO/IEC Standard
Paper Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Paper Compatibility Plain Paper, Heavy Paper, Bond Paper, Label, Index Card, Envelopes (up to 5 via MP tray - Com 10, Monarch, DL, C5, B5)
Printer Features Printer Language
UFR II LT (Host-based)
Print Modes
Poster, Booklet, Watermark, Toner Save, Page Composer
Print Memory
256MB (shared)
Paper Weights 16 to 31 lb. bond (cassette)
16 to 51 lb. bond (multipurpose tray)
Output Tray Capacity 150 sheets (face down)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Black: Up to 35 cpm (letter)
Duplex Black: Up to 17 cpm (letter)
Type Monochrome Laser
Zoom 25 - 400% in 1% increments
Halftones 256 Levels
First Copy Time Less than 8 seconds1
Warmup Time: Less than 17 seconds
Recovery Time: 5 seconds or less
Reduction / Enlargement 25%, 50%, 64%, 78% / 129%, 200%, 400%
Document Feeder 50-sheet duplex5
Copy Size Platen: Up to Letter
ADF: 5.5" x 5" to Legal
Copy Features Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Scanner
Scanner Type Color Contact Image Sensor (CIS)
Scanner Compatibility: TWAIN, WIA
Max. Resolutions Up to 600 x 600 dpi (optical)
Up to 9600 x 9600 dpi (interpolated)
Scanner Features Scan to USB Host 1.1 (Hi-Compression PDF, PDF, JPEG, TIFF), Rotate Image, Pull Scan, Push Scan, Scan to Email, Scan to SMB
Color Depth 24-bit
Max. Document Size Platen: Up to Letter
File Format Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4
Fax
Modem Speed Up to 33.6 Kbps (Super G3)2
Transmission Speed (approx.) JBIG (approx. 3 seconds)
Memory Capacity Up to 512 sheets3
Fax Resolution Up to 400 x 400 dpi (ultra fine)
Speed Dialing 19 one-touch speed dials; 181 coded dials
Group Dialing Group Dialing: 199 destinations
Sequential Broadcasting: 210 destinations
Receive Mode FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Collate, Auto Fax Reduction, PC Fax, Fax Forwarding, Memory Backup (1 hour)
General
Other Features USB Device 2.0 Hi-Speed6, 10/100 Base-T Ethernet (Network), IEEE802.11b/g/n (wireless)7
WiFi Access
Infrastructure Mode
WiFi Authentication Method
Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Mode
WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods
Push-button mode, PIN code mode
Embedded Web Server (Remote UI) w/ IE 6.0 or later, Safari 1.3.2 or later
Department Counter (print, copy, scan)
5-row backlit LCD w/ animation (fax installation, toner installation, paper jam)
Print Protocols: LPD, RAW, WSD
Supported Network Protocols: TCP/IP v4, TCP/IP v6 (print only)
TCP/IP Set of Application Services: DHCP, BOOTP, RARP, ARP+PING, Auto IP, Bonjour, HTTP, SHTTP, NetBIOS
Network Management Protocols: SNMPv1, SNMPv38
MIB: RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB
Languages: English, French, Spanish, Portuguese
Security: IP Filtering, MAC Address Filtering, Secure Print
OS Compatibility Windows&reg; 8, Windows 7, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server 2003, Windows XP/2000, Mac&reg; OS X 10.4.9 & up
Software Included Canon Drivers, MF Toolbox, Document Management & OCR Software
Power Consumption (approx.) 1,000W (Max), 9W (Standby), 2.1W (Energy Saver Mode)
Typical Energy Consumption (TEC): 1.4k Wh
Dimension (W x D x H) 15.4" (W) x 18.6" (D) x 17.0" (H)
Weight 40.4 lbs. (without Cartridge); 42.2 lbs. (with Cartridge)
Warranty 1 year limited exchange/carry-in warranty9 (Extended Warranty available)
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the imageCLASS MF5950dw/MF5960dn Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Feature Notice: Possible Inaccurate Detection of the One-Touch Panel Open/Close Signal for the imageCLASS MF5960dn/MF5950dw/D1370/D1350
Advisory Type
Date 06.19.12
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
