Canon Support for Speedlite 480EG | Canon U.S.A., Inc.
Speedlite 480EG
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Software Development Kit
Flash
Type Grip-style TTL automatic, external sensor-based automatic and manual flash (with bounce function).
Attachment Via TTL Shoe Cord E, Synchro Cord 480 or with optional slave unit as off-camera cordless light source.
Guide Number 160 (ISO 100, ft. @ 35mm coverage angle).
Flash Coverage 20mm-135mm (using wide and tele panels).
Number of Flashes Alkaline-Manganese batteries: 100 to 700
Ni-Cd Battery Pack: 90 to 600
Recycling Time With Alkaline-Manganese batteries: 0.2 to 17 sec.
With Ni-Cd Battery Pack: 0.2 to 6 sec.
Color Temperature Same as Daylight.
Flash Duration 1/850 sec. to 1/20,000 sec.
Synchronization First curtain, X-Sync.
Flash Control System TTL automatic control by metering light reflected from the film plane (with TTL Shoe Cord E connection); External sensor auto flash control (with Synchro Cord 480); Variable-power Manual.
Flash Coupling Range TTL autoflash; 2.4-104.9 ft. (with 50mm f/1.4 @ ISO 100)
General
Power Source With Transistor Pack E: Six size-C LR14 alkaline-manganese (Battery Magazine TP) or NR-SC Ni-Cd (sealed Ni-Cd Pack TP) batteries.
Dimensions Main Unit: 3-7/8 x 10-1/16 x 4-1/2 in. (98 x 256.5 x 114.3mm)
With clamp and bracket: 11-7/16 x 10-1/16 x 4-1/2 (291 x 256.5 x 114.3mm)
Weight Main unit: 25.03oz. (715g) without batteries
With clamp and bracket: 37.03oz. (1,065g) without batteries
Canon Flashes Limited International Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
  1. loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
  2. if equipment is defective as a result of leaking batteries or liquid damage.
  3. if equipment has been serviced or modified by other than our Authorized Agents.
  4. Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
  5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
Equipment covered by this Warranty will be repaired in other countries:
a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
Online Repair
Title Canon Support | Service Notice: Caution Concerning use of Lithium Batteries
Advisory Type
Date 04.28.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
