Canon Support for Speedlite 600EX II-RT | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 05.29.16
File Size 7.49 MB
Software Development Kit
Compatible Cameras
Type-A EOS cameras (E-TTL II/E-TTL autoflash)
Type-B EOS cameras (TTL autoflash)
Guide Number
The Guide No. is approximately 49.2 ft./15m at ISO 100.
The maximum Guide No. is approximately 196.9 ft./60m at ISO 100 and 200mm flash coverage.
When the extendable wide panel is pulled out, the flash coverage is 14mm.
Number of Flashes
Approx. 100-700 flashes.
* Nominal min. time when using 1900mm Ah type AA/HR6 Ni-MH batteries.
* Based on Canon Testing Standards.
Recycling Time
Normal flash: 0.1-5.5 sec.
Quick flash: 0.1-3.3 sec.
Flash Range
Effective flash range with EF 50mm f/1.4 lens at ISO 100
  1. Normal Flash:
    Approx. 1.6-91.2 ft./0.5-27.8m
  2. Quick Flash (at Guide No. 68.2 ft./20.8m):
    Approx. 1.6-48.6 ft./0.5-14.8m
  3. High-speed Sync (at 1/250 sec. shutter speed):
    Approx. 1.6-48.2 ft./0.5-14.7m
AF Assist Beam
System:
Infrared AF-assist beam
Compatible AF System:
TTL second image formation phase-difference AF
Supporting 1-65 AF points (28mm or longer focal length)
  • Phase-difference AF during viewfinder shooting
  • Quick mode during Live View shooting or movie shooting
Effective Range (Approx.):
At center: 2.0-32.8 ft./0.6-10.0m
At periphery: 2.0-16.4 ft./0.6-5.0m
Custom Functions
15 Functions
6 Functions
Power Source
Four AA-size/LR6 alkaline or AA/HR6 Ni-MH batteries
External Power Source
Compatible (Compact Battery Pack CP-E4N recommended)
Dimensions
Approx. 3.10 x 5.64 x 4.83 in./78.7 x 143.2 x 122.7mm
Weight
Approx. 15.34 oz./435g
Canon Flashes Limited International Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
  1. loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
  2. if equipment is defective as a result of leaking batteries or liquid damage.
  3. if equipment has been serviced or modified by other than our Authorized Agents.
  4. Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
  5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
Equipment covered by this Warranty will be repaired in other countries:
a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
Online Repair
Title Canon Support | Service Notice: Caution Concerning use of Lithium Batteries
Advisory Type
Date 04.28.26
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
