Canon Support for EOS 20Da | Canon U.S.A., Inc.
EOS 20Da
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 06.09.08
File Size 5.33 MB
Date 10.23.07
File Size 4.49 MB
Date 09.30.07
File Size 11.53 MB
Date 10.14.10
File Size 8.08 MB
Date 04.13.09
File Size 7.50 MB
Date 07.22.12
File Size 6.88 MB
Date 06.09.08
File Size 10.99 MB
Date 06.09.08
File Size 4.94 MB
Date 03.31.07
File Size 419.87 KB
Date 04.15.09
File Size 6.96 MB
Date 01.24.12
File Size 10.69 MB
Date 03.25.08
File Size 1.84 MB
Date 03.04.10
File Size 12.70 MB
Date 07.22.12
File Size 6.38 MB
Date 10.14.10
File Size 8.41 MB
Date 10.09.26
File Size 142.00 B
Date 10.09.26
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital, single-lens reflex, AF/AE camera with built-in flash
Recording Media Type I and II CF card
Image Format 22.5mm x 15.0mm
Compatible Lenses Canon EF and EF-S lenses (35mm-equivalent focal length is equal to approx.1.6 times the marked focal length.)
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, single-plate CMOS sensor
Pixels Approx. 8.25 megapixels (3520x2344)
Total Pixels Approx. 8.50 megapixels (3600x2360)
Aspect Ratio 3:2
Color Filter System RGB primary color filter
Low Pass Filter Located in front of the image sensor, non-removable
Recording System
Recording Format JPEG (except when Adobe RGB is set) supporting Design rule for Camera File system and RAW
Image Format JPEG and RAW (12-bit)
File Size (1) Large/Fine: Approx. 3.6 MB (3504x2336 pixels)
(2) Large/Normal: Approx. 1.8 MB (3504x2336 pixels)
(3) Medium/Fine: Approx. 2.2 MB (2544x1696 pixels)
(4) Medium/Normal: Approx. 1.1 MB (2544x1696 pixels)
(5) Small/Fine: Approx. 1.2 MB (1752x1168 pixels)
(6) Small/Normal: Approx. 0.6 MB (1752x1168 pixels
(7) RAW (3504x2336 pixels): 8.7MB RAW + Small/Normal: Approx. 9.3 MB RAW + Small/Fine: Approx. 9.9 MB RAW + Medium/Normal: Approx. 9.8 MB RAW + Medium/Fine: Approx. 10.9 MB RAW + Large/Normal: Approx. 10.5 MB RAW + Large/Fine: Approx. 12.3 MB * Exact file sizes depend on the subject and ISO speed.
File Numbering Consecutive numbering, auto reset
Color Space sRGB, Adobe RGB
Two sets of standard parameters plus up to three sets of custom processing parameters (4 items with 5 settings each) as well as monochrome photography with custom parameters can be set.
White Balance
Settings Auto, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash, Manual Color Temperature Setting and Custom
Auto White Balance Via image sensor data
Color Temperature Compensation +/- 9 steps in 1-step increments
Viewfinder
Type Eye-level pentaprism
Coverage Approx. 95% vertically and horizontally (Coverage against JPEG Large)
Magnification 0.9x (-1 dpt. with 50mm lens at infinity)
Eye Point 20mm
Dioptric Adjustment Correction -3.0 - +1.0 dpt.
Focusing Screen Fixed, Precision Matte screen
Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60. No mirror cut-off with lenses up to EF 600mm f/4)
Viewfinder Information AF (AF points, focus confirmation light), exposure (shutter speed, aperture value, manual exposure, AE lock, exposure compensation amount, AEB level, partial metering area), flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, flash exposure compensation), warnings (exposure warning, improper FE lock warning, CF card full warning, CF card error warning, no CF card warning, busy), maximum burst for continuous shooting, shots remaining.
Depth Of Field Preview Enabled with depth-of-field preview button
Autofocus
Type TTL-CT-SIR with a CMOS Sensor (TTL Cross Type secondary image registration)
AF Points 9
AF Working Range EV 0.5-18 (at 20&deg C, ISO 100)
Focusing Modes One-Shot AF, Predictive Al Servo AF, AI Focus AF, Manual focus (MF)
AF Point Selection Automatic selection, Manual AF point selection
Active AF Point Indicator Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam Intermittent firing of built-in flash
Effective Range Approx. 4.0m/13.1 ft. at center, approx. 3.5m/11.5 ft. off-center
Exposure Control
Metering Range EV 1-20 (at 20&deg C with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Basic Zone modes: Automatic
Exposure Compensation AEB: +/-2 stops in 1/2- or 1/3 stop increments
AE Lock Auto: Applied when focus is achieved in the One Shot AF mode with evaluative metering. Manual: Applied with AE lock button
Shutter Vertical-travel focal-plane shutter with all speeds electronically controlled1/8000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/250 sec.Soft-touch electromagnetic release10 sec. delayN3-type remote control
Type Vertical-travel focal-plane shutter with all speeds electronically controlled
Shutter Speeds 1/8000 - 30 sec. (1/2- or 1/3-stop increments), bulb, X-sync at 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10 sec. delay
Remote Control N3-type remote control
Built in Flash
Type Auto pop-up E-TTL II autoflash (retractable)
Guide Number 13 (ISO 100m), 43 (ISO 100 ft.)
Recycling Time Approx. 3 sec.
Flash Ready Indicator Flash-ready indicator lights in viewfinder
Flash Coverage 17mm lens angle covered
Flash Exposure Compensation +/-2 stops in 1/2- and 1/3 stop increments
External Speedlite
EOS Dedicated Speedlite E-TTL II autoflash set with EX-series Speedlites
PC Terminal Provided
Drive System
Drive Modes Single frame, Continuous, Self-timer
Continuous Shooting Speed Approx. 5 fps (at 1/250 sec. or faster speeds)
Maximum Burst 23 shots (Large/Fine JPEG) or 6 shots (RAW or RAW+JPEG)
LCD Monitor
Type TFT color liquid-crystal monitor
Monitor Size 1.8 in.
Pixels Approx. 118,000 pixels
Coverage Approx. 100% for JPEG images
Brightness Control 5 levels
Playback
Display Format Single image, 9-image index, Magnified zoom, Auto play, Auto play right after shooting
Highlight Alert In the single image and single image (Info) modes, any overexposed highlight areas with no image information will blink
Image Protection and Erase
Protection Single images can be protected or unprotected
Menus
Menu Categories Shooting menu: Red
Playback menu: Blue
Setup menu: Yellow
LCD Monitor Language 12 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, and Japanese)
Firmware Update Update possible by the user
Power Source
Battery One Battery Pack BP-511A/BP-511/BP-512/BP-514AC power can be supplied via the optional DC coupler.
Battery Life At 68&deg F / 20&deg C: 650 (No Flash), 500 (50% Flash Use), At 32&deg F / 0&deg C: 500 (No Flash), 400 (50% Flash Use). These figures apply when a fully-charged Battery Pack BP-511A/BP-511/BP-512/BP-514 is used.
Battery Check Automatic
Power Saving Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min
Dimensions and Weight
Dimensions (W x H x D) 5.7 x 4.2 x 2.8 in. / 144 x 105.5 x 71.5mm
Weight 24.2 oz / 685 g (body only)
Operating Environment
Working Temperature Range 32 - 104&deg F / 0 - 40&deg C
Working Humidity Range 85% or lower
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: BG-E2 Battery Grip
Advisory Type
Date 10.16.05
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: EOS Utility
Advisory Type
Date 12.12.19
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
