Canon Support for Speedlite Transmitter ST-E3-RT | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Flash
| Type | Radio transmissions wireless Speedlite transmitter |
| Compatible Cameras | Type A EOS cameras (E-TTL II/E-TTL autoflash) |
| Sync Speed | High-Speed Sync provided (EOS-1D X and EOS 5D Mark III only) |
| Flash Exposure Confirmation | Flash exposure confirmation lamp lights in green * If it does not light, shooting is not performed with the standard exposure |
| AF Assist Beam | N/A |
Wireless Functions
| Transmission System | Radio Transmission |
| Transmission Range | Approx. 98.4 ft. (30m) |
| Flash Ratio Control | 1:8 - 1:1 - 8:1, power 1/2-stop increments |
| Flash Coverage | Transmission Angle: 360° all around |
| Receiver Operation Confirmation | Green Light Lit: Radio Transmissions Okay Red Light Lit: Not Connected Blinking: Transmission Error/ Too many units (Sender units + receiver units = more than 16 units) Orange Light Lit: Sub-sender transmission Blinking: Receiving remote release shooting, linked shooting signal |
| Receiver Unit SE Mode Cancellation | The test flash button can be pressed to test if the receiver units fire or cancel the auto power off status. |
General
| Power Source | AA/LRG Alkaline Batteries x2(Ni-MH and Lithium batteries can also be used) Battery Life: Approx. 10 hours continuously *When using AA/LR6 alkaline batteries used (At a room temperature +23°C/73°F). |
| SE Mode | Power off after 5 min. of idle operation |
| Dimensions | 2.65 (W) x 2.42 (H) x 3.05 (D) in. / 67.4 (W) x 61.5 (H) x 77.4 (D) mm |
| Weight | 3.9 oz. / 110g (excluding battery) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
next to your download
