Web Content Viewer
Actions
VB-M741 LE
All Network Cameras
Item Code: 0312C001AA
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
  • IP66 Rated Enclosure and Built-in Heater
  • Built-In Infrared Illuminators for Surveillance in 0 Lux
  • Canon's Unique Remote Adjustment Function for Easy Post-Installation Changes to the Camera's Zoom
  • Canon 2.4x Optical Zoom Lens with 113.4° Angle of View
  • 1.3 Megapixel High-Sensitivity CMOS Sensor with Exceptional Low-Light Performance
  • Advanced DIGIC DV III Image Processor to help Maximize Image Quality
  • Haze Compensation, Smart Shade Control and Auto Gain Control Limit
  • Area-Specific Data Size Reduction (ADSR) to Maintain Video Quality in Important Areas While Reducing Bandwidth Usage
  • Scheduled Custom Video Settings
  • On-Board Video Analytics and Versatile Functions
  • Powerful DIGIC NET II Processor allows for Simultaneous Streaming of M-JPEG and H.264 in Multiple Resolutions
  • Multiple Networking Configuration, Security and Encryption Functions
  • Audio and I/O Support
  • Built-in SD Card Slot
  • Multiple Power Options: 24 VAC, 12 VDC, PoE and PoE+
  • ONVIF 2.4.2 / Profile S / Profile G Conformant
This is to make Misc appear on the page when needed.
Brochures
Loading...
VB-M741LE Network Camera
VB-M741LE Network Camera VB-M741 LE Main Unit Ceiling Mount Bracket CD-ROM Safety Wire Interface Cable Installation Guide Screw Torque wrench Template Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-M741 LE that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION
ANALOG VIDEO STANDARD
ANALOG S/N RATIO
SCANNING METHOD
Progressive Scan
LENS
2.4x optical zoom lens (electric drive)
FOCAL LENGTH
2.55 (W) - 6.12 mm (T)
F-NUMBER
F1.2 (W) - F1.8 (T)
DIGITAL ZOOM
4x
HORIZONTAL VIEWING ANGLE
113.4° (W) - 46.5° (T)
VERTICAL VIEWING ANGLE
61.4° (W) - 26.2° (T)
DAY/NIGHT SWITCH
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.02 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR lamp on)
0.001 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR lamp off)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3 m (12 in.) - infinity
Night Mode: 0.3 m (12 in.) - infinity
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source/Manual Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/ Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
PAN ANGLE RANGE
344° (±172°)
TILT ANGLE RANGE
93° (-3° - +90°)
ROTATION ANGLE RANGE
344° (±172°)
IR ILLUMINATION RANGE
30 m (98.4 ft.) (When using 24 V AC, PoE+)
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64-16384 kbps
VIDEO SIZE
JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1280 x 960 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
Ver. 2.4.2, Profile G, Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), mDNS,ARP, ICMP, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), AutoIP, RTP/RTCP, RTSP, SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), mDNS, ICMPv6, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), RTP/RTCP, RTSP,SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
AUTO IP(LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
Number of registers: Max. 20 positions (+Home Position)
Items to Reg.: Digital Pan/Digital Tilt/Digital Zoom, Exposure, Smart Shade Control, Focus, White Balance, Video Quality Adjustment, Day/Night, Haze Compensation
Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO
Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch Number of Linked Events: 2
Linked Event Conditions: AND, OR (whether or not there is a sequence to events)
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Operating Temperature Range (including direct sun exposure)
AC, PoE+: -50°C - +55°C (-58°F - +131°F)
DC, PoE: -10°C - +55°C (+14°F - +131°F)
Start-up Temperature Range (including direct sun exposure)
AC, PoE+: -30°C - +55°C (-22°F - +131°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3at Type1 PoE compliant)
AC ADAPTER
PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 10.1 W
WITH AC ADAPTER
AC Adapter PA-V18: Max. approx. 12.8 W (100 V AC) Max. approx. 12.8 W (240 V AC)
WITH 12VDC
Max. approx. 11.1 W
WITH PoE +
Max. approx. 21.2 W
WITH 24VAC
Max. approx. 22.2 W
OTHER
DIMENSIONS
(H x W x D) 111 x 102 x 214 mm (4.37 x 4.02 x 8.43 in.) (camera body only)
- Length when joint fully extended (D): 384 mm (15.12 in.)
MOUNTING POSITION
Ceiling mount/Surface mount
HEATER
Built-in
WEIGHT
Approx. 2120 g (4.68 lb.)
OUTDOOR READY
Yes
IP RATING
IP66
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
A&E System Design Tools
A&E Specifications
Date
10/10/15
Size
513 KB
Drawings / 3D CAD
Date
10/13/15
Size
7.01 MB
Date
10/13/15
Size
739 KB
Date
10/08/15
Size
592 KB
Date
10/08/15
Size
58.6 KB
Date
10/08/15
Size
696 KB
Date
10/08/15
Size
76.1 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
This is a class A product. In a domestic environment this product may cause radio inference in which case the user may be required to take adequate measures.
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
