Web Content Viewer
Actions
imagePROGRAF PRO-2000
Professional Photo & Fine Art
Everything Large Format at your fingertips. Download the App today.
Canon Large Format Media
You can count on extraordinary consistency with Canon imagePROGRAF media.
Click here to receive free print samples printed on the 11-color imagePROGRAF PRO Series Large-Format printers.
Features
The new LUCIA PRO ink set adopts newly formulated 11-color pigment inks and a Chroma Optimizer. Designed specifically to meet the demands of even the most critical photographer, the LUCIA PRO ink formulation includes microencapsulated colorants that enable smooth gradients, an expanded color gamut, and deeper color expression. This system helps you achieve stunning color reproduction, image clarity, and enhanced darker areas. A first for the Canon large format printers is the addition of a Chroma Optimizer. Used when printing on glossy and semi-glossy paper, this acts as a clear coat, improving color performance and gloss characteristics enriching the dark areas of a print.
This new ink set helps:
  • Enhance gloss uniformity
  • Improve scratch resistance
  • Enhance dark area reproduction
  • Reduce graininess
The PF-10, a 1.28”-wide print head with 18,432 nozzles equipped with anti-clogging FINE technology, generates fast print speeds while reducing the possibility of clogging. Ink ejection conditions are precisely checked by 27 sensors, and if a clog is detected, another nozzle will automatically provide back-up.
This new print head is wider than previous imagePROGRAF print heads requiring models to only have one instead of two. Having only one print head means a more compact printer that achieves faster print speeds while maintaining high print quality.
The imagePROGRAF printers are powered by the L-COA PRO high-speed image processing engine. With three new processing chips, this high-precision control engine performs the processing of massive image data, and controls the optimal ink layout that produces high resolution prints.
The color calibration function is designed to produce consistent color reproduction. This new printer includes an upgraded, built-in color densitometer that offers precise calibration and color matching. Using a three-color LED and newly developed condenser lens the sensor enables accurate recalibration of the device, allowing you to maintain a low average printer-to-printer color difference. The color calibration is finished quickly after a few simple steps on the printer’s operation panel. A single color calibration performed with one type of media can be applied to media in all printing modes.
Device Management Console
The Device Management Console software, ideal for fleet management, lets you perform color calibrations remotely. This software lets you monitor the printer status of up to 50 units from any location in the world, be notified via email when an error has occurred, or check the amount of ink left in the printers without ever having to leave the comfort of your desk.
The newly engineered unibody structure provides a strong platform for stable print head scanning, resulting in precise ink droplet placement. The perfect combination of speed and high-quality printing is achieved with this new design.
The optional Multifunction Roll System is a versatile media handling solution system that enables either a second roll of media to be loaded on the printer, or the unit can be configured as a bi-directional media Take-up unit.
Dual –Roll Feeding: The dual-roll feeding mechanism enables users to load a second roll of a different media type and size so that users can simultaneously switch from printing on matte to gloss paper without pausing their work to reload. Additionally, the second roll can be used to support high-volume printing be enabling two rolls of the same media to be fed to the printer.
Bi-Directional Rewinding: The Multifunction Roll System may also be configured by the operator as a take-up unit to rewind longer printouts. The user can choose to rewind media with the printed surface on the outside or the inside of the roll, thereby supporting “bi-directional rewinding”.
Loading media on a Canon larger format printer has never been easier. Simply set the roll holder in the printer, rotate the roll holder handles and let the media automatically feed into the printer. No need to touch the paper; decreasing the risk of creasing and blemishes.
The PRO-Series is designed to work seamlessly when changing media types. Matte black and Photo black inks have their own dedicated nozzles, so no manual switching between ink tanks is necessary. You can print on fine art paper then glossy paper with no worries, no changes, and no waste.
The large 3.5" color LCD touch panel makes it easy to view printer information as well as perform operations.
Stay Connected. A first for the imagePROGRAF large format printers, Wi-Fi connectivity is now standard with this new PRO series.
PDF and JPEG files can be directly printed on the imagePROGRAF PRO-2000 from a USB thumb drive. Simply input the thumb drive into the USB port on the printer, preview the image on the operation panel, and print! Fast and easy printing without the use of a computer.
Available in 160ml, 330ml, and 700ml ink tanks, you have the flexibility to purchase ink based on your printing needs. 700ml photo black ink tanks can be purchased for those often printing nightscapes and 160ml magenta ink tanks for the occasional sunset image, giving you the power to purchase ink based on the color frequency at which you print.
The Sub-Ink Tank System allows all of the available ink in a tank to be used before having to replace it, helping eliminate any wasted ink. The empty tanks can also be replaced on-the-fly without stopping the printer. This is extremely useful during your long print jobs.
The imagePROGRAF PRO-2000 features a new multipositional basket that can be freely adjusted to enable various output positions and options:
  • Catch Basket
  • Flatbed Stacking
  • Slope (can be used to display a print)
A built-in 320 GB hard drive within the printer increases productivity by relieving workload from the host Mac or PC, while providing a large capacity for print job data storage and retrieval. This 320 GB hard drive enables job data to be stored in protected mailboxes for easy access via web browser or at the printer for job re-printing. The embedded hard disk is ideal for medium to large workgroups to share a printer efficiently with multiple users, offering sample job storage space.
Creating large format prints is now easier with the introduction of Professional Print & Layout for imagePROGRAF large format printers. This software offers features that streamline your printing workflow. Compatible with Canon Digital Photo Professional® software, Adobe Photoshop® software, and Adobe Lightroom® software, Professional Print & Layout offers versatility never before seen with Canon Large Format printing. Features include:
  • Create and save custom layouts
  • Nesting of images
  • Import multiple images and make batch edits that apply to all
  • Create "Favorites" settings
  • Crop images
Recognizing the expanding array of media options for large format printers and to further improve the versatility of these new imagePROGRAF models, Canon has developed a Media Configuration Tool, which allows customers to not only utilize Canon-branded media, but provides the ability to make adjustments to printer settings to enhance the precision and quality of output achieved with third party media.
Settings that can be configured using media parameter adjustment features include:
  • Media weight and thickness
  • Ink drying
  • Automatic cutting settings
  • Borderless printing
  • Paper feed amount
  • Print-head height
  • Vacuum strength
  • Maximum ink usage
In today's printing environment, it is more important than ever to understand how much ink and media each print job is costing your business. Both Mac® and Microsoft® compatible, Accounting Manager serves as a powerful feature, used for accurately managing your print costs. With the Accounting Manager feature you can track how much ink and paper is being consumed when printing in large format of up to 50 printers! Each individual ink tank can have its own cost associated to it, as well as a variety of different paper types. Costs can be assigned to ink and paper to determine expenses based on your own "Cost of Goods". The user can also input a variable cost that will be added to the total of the print cost. The data is exportable to a .csv format for Microsoft Excel so the data can be used for billing purposes. This feature will allow you to determine the cost of each print based on your actual cost. Features include:Job Cost (ink, Media and variable cost inputted by user)Ink Consumed per Job*Media Consumed per Job Job Completion time And more
This Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive.
The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows and Mac driver).
This utility makes it easy to print large-format documents created in Microsoft Word, Excel, or PowerPoint. The Plug-in appears in a tool bar inside the Microsoft application and has an easy-to-follow "Wizard". The Plug-in will bypass the printer driver to simplify the printing process. A few simple steps convert your 8.5" x 11" office document to poster size.
Quick Utility Toolbox is a portal to where all of the Canon printer software and tools can be accessed.
Canon's included PosterArtist Lite poster creation software gives users the ability to quickly and easily create professional large format prints. Users simply follow the program's four (4) easy steps to create posters that can be used in applications such as Office presentation, Trade shows, Retail Signage, and much, much more. The PosterArtist QuickCopy feature provides an easy solution for a CanoScan desktop scanner to be used as a copier, making letter-size flyers and documents into full-size posters with a touch of a button. For those with more demanding poster creation needs, Canon's optional PosterArtist offers advanced features such as Auto Design, Variable Data, and in-application image editing features, as well as additional templates, royalty-free photos, and clip art. The built-in weblink feature in PosterArtist Lite links users directly to the PosterArtist website for useful hints and tips, and even more free content for download.
Specifications
Printer Type
11-Color plus Chroma Optimizer 24-inch Printer
Number of Nozzles
Total: 18,432
All colors: 1,536 nozzles
Nozzle Pitch
600 dpi x 2
Non-firing nozzle detection and compensation
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
32bit: Windows® (Vista/7/8, 8.1/10)
64bit: Windows® (Vista/7/8, 8.1/10)
Mac (OS X 10.7.5-10.11)
Standard Interfaces
USB 2.0 High-Speed
10/100/1000 Base-T/TX, Wireless LAN (IEEE 802.11 b/g/n)
Ink Droplet Size
Minimum 4 picoliter
Ink Capacity
160ml, 330ml, or 700ml per color*
Ink Droplet Size
Pigment based LUCIA PRO Ink
Color Set
Photo Black, Matte Black, Cyan, Magenta, Yellow, Photo Cyan, Photo Magenta, Gray, Photo Gray, Red, Blue, +Chroma Optimizer
Hard Drive
320GB
Media Width
Cut Sheet - 8- 24
Roll Feed - 8 - 24
Media Thickness
Roll: 0.07 - 0.8 mm (2.8 - 31.5mil)
Maximum Roll Print Length
Roll Feed - 59' (18 meters)**
Maximum Media Roll Diameter
6.7 (170mm)
Borderless Printing Width
10, B4, A3, 14, A2, 17, B2 (20.28/515 mm), A1 (23.38/594mm), 24
Paper Feed Method
(Roll Media Only) 10, 14, 17, B2 (20.3/515 mm), A1 (23.4/594mm), 24
Roll Feed: One Roll, Front-loading, Front Output
Manual Feed: Front-loading, Front Output
Languages
Language: Swift Graphic Raster (SGRaster)
Noise Level Approx
Operation: 48 dB (A) or less
Acoustic Power: 6.4 Bels or less
Physical Dimensions
46.0 (H) x 43.7 (W) x 38.7 (D) (with basket open)
Weight
Approx.223 lbs (roll holder included, no inks, no print heads)
Power Source
AC 100-240V (50-60Hz)
Power Consumption
Maximum: 88 W or less
Standby 3.6 W or less
Power Off: 0.5 W or less
Operating Environment
Temperature: 59 - 86°F
Relative Humidity: 10-80% (No Condensation)
User-replaceable items
Print Head (PF-10)
Maintenance Cartridge (MC-30)
Ink Tanks (PFI-1100/PFI-1300/PFI-1700)
Software Included
imagePROGRAF Printer Driver, Print Studio Pro, Print Studio PRO, Quick Utility Toolbox, Print Plug-In for Office, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC only), Printer Driver Extra Kit (Free Layout and Advanced Preview), Print Plug-in for Microsoft Word/Excel/PowerPoint (PC only)
Supplies and Accessories
Accessories
MSRP
Roll Holder Set RH2-27
$137.00
Maintenance Cartridge MC-30
$90.00
Cutter Blade CT-07
$86.00
Multifunction Roll Unit RU-21
$800.00
PosterArtist
$395.00
Print head PF-10
$675.00
Ink Tanks
MSRP
PFI-1100 MBK
$97.00
PFI-1100 PBK
$97.00
PFI-1100 C
$97.00
PFI-1100 M
$97.00
PFI-1100 Y
$97.00
PFI-1100 PC
$97.00
PFI-1100 PM
$97.00
PFI-1100 GY
$97.00
PFI-1100 PGY
$97.00
PFI-1100 R
$97.00
PFI-1100 B
$97.00
PFI-1100 CO
$94.00
PFI-1300 MBK
$173.00
PFI-1300 PBK
$173.00
PFI-1300 C
$173.00
PFI-1300 M
$173.00
PFI-1300 Y
$173.00
PFI-1300 PC
$173.00
PFI-1300 PM
$173.00
PFI-1300 GY
$173.00
PFI-1300 PGY
$173.00
PFI-1300 R
$173.00
PFI-1300 B
$173.00
PFI-1300 CO
$166.00
PFI-1700 MBK
$294.00
PFI-1700 PBK
$294.00
PFI-1700 C
$294.00
PFI-1700 M
$294.00
PFI-1700 Y
$294.00
PFI-1700 PC
$294.00
PFI-1700 PM
$294.00
PFI-1700 GY
$294.00
PFI-1700 PGY
$294.00
PFI-1700 R
$294.00
PFI-1700 B
$294.00
PFI-1700 CO
$283.00
This is to make Misc appear on the page when needed.
Use the Media Compatibility Guides to find the perfect media for your Canon machine.
Fine Art Natural
230gsm
14mil
German Etching by Hahnemuhle
310gsm
18mil
Fine Art Bright White
230gsm
14mil
330gsm
20mil
Artistic Satin Canvas
350gsm
19mil
Artistic Matte Canvas
340gsm
21mil
Water Resistant Matte Canvas
400gsm
24mil
Fine Art Photo Rag by Hahnemuhle
188gsm
11.5mil
Fine Art Enhanced Velvet
225gsm
14mil
255gsm
21mil
Photo Paper Pro Premium Matte
210gsm
12mil
Premium Fine Art Smooth
310gsm
16.5mil
Satin Photo Paper
170gsm
7mil
Satin Photo Paper
200gsm
8mil
Satin Photo Paper
240gsm
10mil
Glossy Photo Paper
170gsm
7mil
Glossy Photo Paper
200gsm
8mil
Glossy Photo Paper
240gsm
10mil
Premium RC Photo Matte
255gsm
10mil
Premium RC Photo Luster
255gsm
10mil
Premium Glossy Photographic Paper 2
280gsm
11mil
Premium Semi-Glossy Photographic
Paper 2
280gsm
11mil
Photo Paper Pro Premium Platinum
300gsm
12mil
Photo Paper Pro Luster
260gsm
10mil
Back Print Backlit Film
165gsm
5mil
Durable Matte Polypropylene Banner
130gsm
7mil
Durable Backlit Film
250gsm
7mil
Adhesive Matte Vinyl
290gsm
11mil
Scrim Banner Vinyl
460gsm
14mil
Water Resistant Matte Polypropylene
115gsm
6mil
Water Resistant Adhesive Matte Vinyl
330gsm
13mil
Water Resistant Matte Banner Vinyl
480gsm
13.8mil
Premium Gift Wrapping Paper
95gsm
4mil
Economy Bond Papper
75gsm
4mil
Premium Plain Paper (2 Rolls per box)
80gsm
4mil
High Resolution Coated Bond
120gsm
6mil
Heavyweight Coated Paper
140gsm
7mil
Heavyweight Coated Paper HG
145gsm
6mil
Double Matte Film
160gsm
5mil
Matte Coated Paper
90gsm
5mil
Matte Coated Paper
170gsm
8mil
Heavyweight Matte Coated Paper
230gsm
10mil
20lb. Bond, 150ft
75gsm
4mil
20lb. Bond, 3000ft
75gsm
4mil
20lb Recycled Uncoated Bond, 150ft
75gsm
4mil
20lb Recycled Uncoated Bond, 300ft
75gsm
4mil
24lb Bond, 150ft
90gsm
4mil
24lb Bond, 300ft
90gsm
4mil
24lb Premium Coated Bond, 150ft
90gsm
4mil
24lb Premium Coated Bond, 300ft
90gsm
4mil
What's In The Box
imagePROGRAF PRO-2000 Box Contents imagePROGRAF PRO-2000 Stand (legs, basket & tools) US AC Power Cable Print Head PF-10 160ml Starter Ink Tanks (MBK/BK/C/M/Y/PC/PM/GY/PGY/R/B/CO) 2" Roll Holder with 3” Core Adapters Quick Guide Safety and Environmental Sheet Setup Guide Printer Stand Setup Guide Important Information Sheet Print Head Alignment Sheet USB Connection Sheet Software Discs (Windows Drivers, PosterArtist Lite – 32/64 bit) Sample media (12 sheets of Heavy Weight Coated HG paper A4 size) Call Center Notice Card (USA) User Registration Card Printer and Print Head Warranty Cards (USA and Canada) Canon USA Media Compatibility Sheet imageWARE Remote Service Terms Leaflet
Brochures
Loading...
Awards
2016 Editor's Choice Award
2017 BLI Line Of The Year Wide Format Printer Line
Videos
Introduction to Professional Print and Layout with Eddie Tapp
Professional Print and Layout Software Overview
How To Nest Images In Professional Print & Layout
How To Do Basic Prints Using Professional Print & Layout
How To Create Job Settings In Professional Print & Layout
How To Create Slots and Templates in Professional Print & Layout
How To Use Advanced Digital Image Tools In Professional Print & Layout
How To Use Color Management in Professional Print & Layout
Introduction to Professional Print & Layout
Introducing the imagePROGRAF PRO Series line of Professional Large-format Printers
Understanding the Media Configuration Tool Software
Layout Plug-In (Gallery Wrap)
Learn how to calculate Large-format Printer’s Cost per print
Learn how to print and share your large format files using Canon Direct Print & Share
Learn how to nest and print images
using canon imagePROGRAF Free Layout
How to print on an Canon imagePROGRAF LF Printer
How to make a Poster Using Canon PosterArtist
Introduction to Canon’s Water Resistant Media
How to print using the imagePROGRAF Free Layout Tool
How to print a poster from a PDF file
using the imagePROGRAF Printer Driver
How to print a banner using the imagePROGRAF
Print Plug-in for Microsoft Powerpoint
How to create and print posters using
Canon PosterArtist Lite
How to Use Canon’s Print Plug-in for Microsoft office
Color Calibration Management Console Software
Adjustment Pattern Settings
Print Plug-In for Adobe Photoshop
2017 Wide Format Printer Line of the Year
ImagePrint Red Overview
How to Install a blade on the Graphtec Cutter
How to set the Course Adjustment on the Graphtec Cutter
How to set the Course Adjustment on the Graphtec Cutter - Method 2
How to load paper in the Graphtec Cutter
How to set speed on the Graphtec Cutter
How to cut using the Graphtec Cutter
How to set the fine adjustments on the Graphtec Cutter
How to install the cutting pen on the Graphtec Cutter
Videos
imagePROGRAF PRO Series testimonial by Digital Silver
Imaging featuring photographer Nick Nichols
Canon: Large Format printing with Douglas Kirkland
Photography
Canon: From 4K to Large Format Prints with Ori Media
Canon: imagePROGRAF Behind the Scenes on James
Franco’s “Tar” Film
DISCLAIMERS
Canon and imagePROGRAF are registered trademarks and LUCIA PRO logo are trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. All other referenced product names and marks are trademarks of their respective owners. Prices, specifications, and availability are subject to change without notice. Actual prices are set by individual dealers and may vary. All printout images and effects are simulated. 1. Print Studio Pro plug-in software is compatible with Adobe Photoshop CS5/CS6/CC/CC (2014)/CC (2015), Adobe Photoshop Lightroom 3/4/5/6, and Canon Digital Professional 3.12 or later.
2. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
*The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
**The maximum printable length varies, depending on application, OS, and RIP used.
Recycled paper and Chlorine-free paper can be used.
 Return to Top
