Arizona 2300 UV Flatbed Printer Series
- True, stationary flatbed versatility at an affordable price
- FLXflow Technology to easily handle heavy or irregular substrates and greatly reduce or eliminate the need for masking
- Roll Media Option available for true roll-to-roll capability with instant switching between roll-to-roll and flatbed printing
- Available in 4-, 6- or 8-channel models that include support for CMYK plus White, Varnish and light Cyan and light Magenta inks
- Supports cost efficient 3-liter size CMYKcm IJC357 or IJC358 inks
- UV-LED provides instant-on printing
In the box
Return Policy
Overview
Lift Your Business
Explore the unlimited creativity, accuracy and quality of the latest world-leading Arizona flatbed printer! The Arizona 2300 series consists of true, stationary flatbed printers based on UV-curable inks. Quick, reliable and low-maintenance, the latest Arizona printer provides the optimum in print quality and versatility for both rigid and flexible media applications.
Enjoy a mind-blowing application range, Instant-On capability and self-learning technology that will help you further your expertise - and business. Join the Arizona family and rely on instant-on printing and incredible, creative applications print after print, year after year.
The Arizona 2300 series is designed to serve the versatile printing needs of printers who require production capacity of over 300,000 ft2/year, or a peak capacity of approximately 13,000 ft2/week. Rock-solid in its basic configuration and ready for upgrades such as the Roll Media Option and additional ink channels, including our brightest ever white UV ink.
As the global leader in large format imaging systems, Canon has set a market standard in productivity, instant operation, reliable performance and amazing quality.
New FLXflow Technology saves you time
As an alternative approach to the successful Arizona Classic flatbed architecture, the Arizona series now offers new FLXflow technology. The standard Hold feature, which uses an impressive airflow technique with a zone-less, multi-origin table layout is an advancement that greatly reduces or even eliminates the need for masking open areas of the table enabling quicker job setups. FLXflow’s new optional Float feature with Instant Switch functionality floats heavy or irregular substrates on a cushion of air, allowing for easier handling and less waste. The Instant Switch feature allows for operators to quickly switch between Hold and Float using the foot pedal.
Do you frequently need to produce complex, layered files such as backlits and double-sided, right reading window graphics with a blockout layer? The optional PRISMAguide XL software will save you the headache of trying to remember all the steps involved. Just do it once and the software learns from you and saves those steps into a recipe that you can reapply to the same type of job in the future. Controller enhancements also allow you to make last-minute adjustments at the printer, such as nesting, batching of complex jobs, step & repeat, mirroring, and reassignment of print modes. Production of textured prints is also possible with the optional PRISMAelevate software that puts creative control into the designer’s hands while streamlining the printing process for the print providers. This unique, high margin application is sure to deliver a huge WOW factor to your end users!
Supplies
The key to completing a successful project is starting with the proper supplies. With Canon, you have access to genuine supplies that are engineered to work with your equipment.
Main Unit Specs
2300 Series XTF - 121.3" x 98.4"
2300 XTF - 1,023 ft2/hr.
2360 Series - 6 ink channels upgradeable to 2380 for 8 channels
2380 Series - 8 ink channels
Resources
Arizona Family Brochure FLXflow
03.28.25
6.5 MB
Arizona 2360 GTF XTF Inks Consumables
04.09.25
1.2 MB
Arizona 2380 GTF XTF Inks Consumables
04.09.25
1.2 MB
ARIZONA 2340 GTF XTF Inks Consumables
04.09.25
1.2 MB
Large Format Full Line Brochure
06.01.26
5.7 MB
Canon Arizona 2300 Brochure
07.07.26
1.6 MB
Arizona 2300 Series Spec Sheet
03.06.26
13.1 MB
