imagePROGRAF TX-4200 MFP Z36
As low as $0.00
Out Of Stock
  • 44" Printer with 36" Scanner
  • Up to 3.3 D-size pages per min*
  • Scans up to 13" per second for monochrome prints
  • Optional Multifunction Roll Unit
  • EPEAT Gold and Energy STAR registered
* 3.3 ANSI D prints/minute speed measured after first print in Fast Q5 mode, using plain paper. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type, and orientation of paper.
Show more
Overview
With the capability to print both monochrome line drawings and eye-catching full-color posters, the imagePROGRAF TX large-format printer series is designed with production and versatility in mind within the aqueous inkjet market.
imagePROGRAF eCarePAK Extended Service Plans
Extends service coverage beyond the initial warranty period for up to 5 years total coverage.
ecarepak logo
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Bring Your Ideas To life
Everything Large Format at your Fingertips
The Canon Large Format Printer App gives users access to how to videos, printing and photo events, firmware and software updates.
person using phone
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
A collage of various large format media
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
EPEAT Gold Logo
ENERGY STAR® Certified
Canon imagePROGRAF printers are ENERGY STAR® certified products. Products that earn the ENERGY STAR® label meet strict energy-efficiency specifications set by the U.S. EPA, helping you save energy and money while protecting our planet.
ENERGY STAR Certified
Main Unit Specs
Printer Type
5-Color 36-inch Printer
Technology
FINE (Photolithography Inkjet Nozzle Engineering)
Print Resolution (Max.)
2400 x 1200 dpi
Line Accuracy(1)
±0.1% or Less
Minimum Line Weight(2)
0.02 mm
Number of Nozzles
Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Ink Type
Pigment: Matte Black (MBK), Cyan (C), Magenta (M), Yellow (Y), Black (BK)
Ink Tank
Shipped with Printer:
MBK/BK/C/Y/M: 330 ml
Replacement:
M: PFI-111(160ml)/PFI-311(330ml)/PFI-711(700ml)
MBK/BK/C/Y: PFI-110(160ml)/PFI-310(330ml)/PFI-710(700ml)
Nozzle Recovery System
Non-firing Nozzle Detection and Compensation
Ink Supply Method
Tubing System with Sub Tanks for Continuous Ink Supply
Printer Controller
L-COA PRO
Nozzle Pitch (Head Resolution)
1200 dpi x Two Rows
Ink Droplet Size
5 picoliter
Printer RAM
128 GB (Virtual) 2 GB (Physical)
Hard Drive
500 GB
Media Width
Cut Sheet: 6”-44” (152 mm - 1118 mm)
Roll Feed: 6”-44” (152 mm - 1118 mm)
Printable Margins
Roll Feed: All Sides: 0.12" (3 mm) or 0" for Borderless
Maximum Print Length (Single Page)(3)
Roll Feed: 59' (18 m)Cut Sheet: 63" (1.6 m)
Borderless Printing Widths (Roll Media Only)
Custom Roll Width 6” - 44” with Micro Margin Technology
Media Cutter
Automatic horizontal rotary cutter: standard
Media Thickness
0.07 - 0.8 mm
Media Core Sizes
2” with 3” Core Adapters Included
Maximum Roll Outer Diameter
6.7" (170 mm)
Media Output Options
TX Stacker or Multipositional Catch Basket
Media Method
Roll Feed: One Roll, Front-loading, Front Output
Front Loading Manual Feed: One Roll, Front Output
Printing Software Utilities
Accounting Manager, Canon Print Service, Canon Production Printing (CPP) Driver Select, Canon Production Printing (CPP) PRISMA Tech Suite, Device Management Console, Direct Print Plus, Free Layout Plus, imagePROGRAF Printer Driver for Windows®/Mac®, Media Configuration Tool, PosterArtist, Optimized Driver for AutoCAD, Quick Utility Toolbox
Operating System
W11 Enterprise LTSC (x64)
Print Languages
SGRaster, HP-GL/2, HP RTL, PDF, JPEG
Interface
USB B Port
Type: Built-in (Hi-speed USB)
Mode: Full Speed (12-Mbit/sec.), High Speed (480-Mbit/sec.), Bulk Transfer Connector Type: Series B (4 Pins)
USB A Port: Direct USB Thumb Drive Printing
Gigabit Ethernet
Type: Built-in
Standard: IEEE 802.3u 100Base-TX/Auto-Negotiation, IEEE 802.3ab 1000Base-T/Auto-Negotiation, IEEE 802.3x Full Duplex
Protocol: SNMP, HTTP, TCP/IP (IPv4/IPv6), FTP
Wireless LAN
Standard: IEEE802.11n/IEEE802.11g/IEEE802.11b4
Security: WEP (64/128-bit), WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES)
Acoustic Noise
Operation: 51 dB (A) or Less
Standby: 35 dB (A) or Less
Acoustic Power: Approx 6.9Bels
Power Supply
AC 100 - 240 V (50 - 60 Hz)
Power Consumption
Maximum: Approx. 87 W
Standby:
Approx. 1.7 W
Power Off:
Approx. 0.1 W
Certifications
Electrical Safety Regulations
C TUVus (U.S.A.), C TUVus (Canada)
Electromagnetic Interface Regulations
FCC Part 15B (U.S.A.), IC (Canada)
Radio Regulations
FCC Part 15C (U.S.A.), IC (Canada)
Environmental Certifications
ENERGY STAR® & EPEAT Gold
Operational Environment
Temperature: 59° F - 86° F (15° C - 30° C)
Relative Humidity: 10 - 80% (No Condensation)
Printer Dimensions (W x D x H) and Weight
With Basket Open: 63” x 39” x 46”; 247 lb. (Approx.)
With Basket Closed: 63” x 31” x 46”; 247 lb. (Approx.)
With Stacker Opened: 63” x 47” x 46”; 273 lb. (Approx.)
With Stacker Closed: 63” x 45” x 46”; 273 lb. (Approx.)
Package Dimensions (W x D x H) and Weight
Printer (Main Unit with Stand and Pallet): 72” x 36” x 41”; 370 lb. (Approx.)
Basket: 56” x 21.9” x 8.4”; 20 lb. (Approx.)
Stacker: 49.2” x 35.7” x 11.5”; 60 lb. (Approx.)
Roll Unit: 68” x 23” x 19”; 75 lb. (Approx.)
Options
• Multifunction Roll System (RU-42)
• 2"/3" Roll Holder Set (RH2-46)
User-Replaceable Items
• Ink Tank (PFI-110/111, PFI-310/311, PFI-710/711)
• Print Head (PF-06)
• Maintenance Cartridge (MC-30)
• Cutter Blade (CT-07)
Scan Speed(5)
• 24-bit Color @ 200 dpi: Up to 3” per second
• 8-bit Grayscale and Monochrome @ 200 dpi: Up to 13” per second
Copy Speed
24-bit Color @ 200 dpi: Up to 6” per second
Color Space
sRGB
Maximum Resolution
1200 dpi (Optical)
Scan Accuracy(6)
±0.1% : ±1 pixel
Maximum Scan Width/Maximum Media Width
36”/38”
Maximum Scan Length
164’ (PDF); 315” (JPEG); 598” (TIFF)
Maximum Media Thickness
0.003” - 0.04” (0.07 mm - 1.0 mm)
Digital Imaging Technology
Contact Image Sensor (CIS) Technology
(SingleSensor Assembly)
• 24-bit RGB
• 16-bit grayscale image capture
• Panchromatic monochrome and black and white
• Bi-directional extra long-life LED light system for
optimum object illumination and instant-on scanning
capability
Included Software
SmartWorks MFP Scan-to-Copy/File/Email with Real-time Image Viewer; supports TIFF, JPEG, and PDF
Scanner Interface Kit
3x USB 3.2 and 1x USB 2.0 rear and 1x USB 3.2 front, all type A
Operating Environments
10°C - 35°C, 10 - 90% RH, Non-condensing
External Power Supply
100 - 240 VAC Autosensing +/- 10%, 50 - 60 Hz
Scanner Power Consumption
• Sleep: 0.2 W
• Idle: 12.4 W
• Scanning Color/Grayscale at 200 dpi: 22.7 W/23.3 W
• Controller: 35 W
Compliances
ENERGY STAR®, CB(62368-1), CE, FCC(EMC), Cul/UL, CCC, NOM-019, EAC, C-TICK, VCCI, BIS, EMC +LOA, UL AR, WEEE, REACH, RoHS, EU - Tier 3 of Lot 6
MFP Package Dimensions (W x D x H) and Weight
(With Stand, Pallet, and Scanner)
50" x 17" x 19.5", 75 lb. (Approx.)
Disclaimers
  1. Line accuracy repeatability is guaranteed after a user performs the necessary adjustment and under the same environmental conditions. Applies to media for line drawing (Plain Paper, Coated Paper, CAD Translucent Matte Film, and CAD Tracing Paper) only.
  2. Theoretical value based on data resolution.
  3. The maximum printable length varies depending on the application, OS, and RIP used.
  4. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  5. The scan rate is proportional across the full range of resolutions supported by the scanner. Actual scan times will depend on the host system performance. Quoted top speeds may be limited by the effective bandwidth of the USB 2 and is not guaranteed for all media types.
  6. The quoted scan accuracy may vary depending on the operating environment and the thickness of the media.
Resources
File Name
Canon imagePROGRAF TX Series Brochure
Date
12.29.25
File Size
4.3 MB
File Name
Large Format Full Line Brochure
Date
09.04.25
File Size
25.6 MB
File Name
Canon imagePROGRAF TX-4200 MFP Z36 Spec Sheet
Date
12.29.25
File Size
1.1 MB
Sort By:
Untitle Video
In this video we will show you how to unbox and install a Canon imagePROGRAF TX Series Large Format printer with stacker.
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
The imagePROGRAF TX MFP Z36 system contains multiple components, some of which are manufactured by third parties. To the extent that such third-party offerings come with limited warranties, those such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation.
All speed measured on Plain Paper in Fast Q5 mode.
  1. SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
  2. Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
  3. The 700ml ink tank is only available for service authorized partners.
  4. Plain Paper, Fast (Q5) mode.
  5. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  6. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package.
