Add to Cart
Intelligent Grading Solution PRO
IGS PRO 10-2
As low as $0.00
In Stock
  • Print test answer sheets on any Canon imageRUNNER ADVANCE MFP, copier, or scanner
  • Scan completed answer sheets using any imaging device or copier
  • Email images directly from an MFP to the cloud
  • Support for online testing
  • Cloud-based solution—no servers or software to install
  • Teachers can use standard answer sheets or build custom tests
  • Extensive built-in reporting
  • Print reports on your MFPs
Return Policy
