The use of Canon optoelectronic components benefits applications where mechanical systems require accuracy and resolution. Our products deliver high-precision solutions to help you achieve the most while streamlining operations.
EXPECT EXCELLENCE IN OPTOELECTRONICS
Digital Laser Scanner System
Canon’s leading industrial, fully digital Galvano scanners deliver high speed and high accuracy performance, supporting a laser beam diameter of up to 30mm.
Optical Digital Laser Rotary Encoder
Canon’s compact, high-precision rotary angle senor helps lead development of high-technology products, including in robotics, manufacturing machinery and measuring equipment.
Custom Design Encoders
Canon's Actuator Units are developed and designed by utilization and implementation of simulation techniques combined with motors - our core technology. These small sized, lightweight actuators are designed to satisfy customer specifications and can be used in various applications, such as water boiler valve actuators.
OPTICAL DIGITAL LASER ROTARY ENCODER
Laser Technology
MORE INDUSTRIAL PRODUCTS
Canon's DC Motors are custom manufactured to achieve the exact speed, power and current required for your OEM.
Canon has created a solution that utilizes leading optical and processing technologies.
