Web Content Viewer
Actions
ColorStream 8000 Series Inkjet Press
Color Continuous Feed Digital Presses
Features
Reduce the effort needed to achieve your production goals. The ColorStream 8000 series incorporates workflow automation features that streamline production processes, maximize uptime, and optimize labor.
Move confidently to new production processes, to drive targeted content for mass customization. Whether enabling on-demand printing, white-paper solutions, 1:1 marketing, omnichannel communications, or dynamic publishing solutions, the ColorStream 8000 series will support your business environment.
Eliminate printing bottlenecks and open up new business models. The ColorStream 8000 series makes it easy to access broader revenue streams with stunning print quality on a wider range of media and applications. Be ready to address future trends, to deliver advanced personalization, shorter run lengths, and stunning inkjet print quality
Manufactured using solar energy and with long-life components, the ColorStream 8000 series is produced for 24/7 productivity, while safeguarding low energy consumption and minimizing paper waste with printing on the ramp across a broader range of applications.
Colorstream 8000 Series
TECHNOLOGY
INKJET
1,200 dpi DigiDot drop-on-demand, piezoelectric
INK
ColorStream 8000 water-based pigment inks, MICR*
DROP SIZE
Variable/Multilevel 2 - 5 p
PAPER TRANSPORT
Pinless, tight web, automatic tension control
PRINT SPEED PAGES PER MINUTE
ColorStream 8133: 436 ft/min – 1,903 US letter duplex
ColorStream 8160: 525 ft/min – 2,290 US letter duplex
MAX. EFFECTIVE DUTY CYCLE
AMPV 16 – 75 M US Letter
PAPER
PAPER WIDTH
6.5”– 22”
PAPER LENGTH
3” to 60”
PAPER WEIGHT AND CALLIPER
40 – 160 gsm, up to 200 microns; < 40 gsm and > 160 gsm with positive media testing
SUBSTRATES
Uncoated, inkjet-treated, pre-printed, recycled, inkjet coated
POWER REQUIREMENT PER TOWER
CONNECTION**
400V/63A per Tower, 10A per Chiller, 10A per Web Cleaner, 16A Controller
CONSUMPTION PRINTING**
25.4 kVA per Tower
CONSUMPTION IDLE**
1.2 kVA per Tower
PHYSICAL DATA
LENGHT X WIDTH (PER TOWER)
139” x 57”
LENGTH X WIDTH (TWIN WITHOUT PPU***)
494” x 91”
HEIGHT
78.7"
WEIGHT (PER TOWER)
6,239 lbs
ENVIRONMENTAL
TEMPERATURE
Optimal 68 – 79 °F
HUMIDITY
40 – 60 %
OPERATING NOISE
< 80 dBa
WORKFLOW
CONTROLLER
SRA MP
INPUT DATA FORMAT****
AFP/IPDS (IS/3), PDF, PDF/VT (APPE 5), PCL 6, Line Data, LCDS, Metacode, PostScript, PPML, TIFF, VIPP
PRINT MANAGER (OPTIONAL)
PRISMAproduction
CONNECTIVITY
Gigabit Ethernet (copper); 10 Gigabit Ethernet (copper, Optic MMF/SR, Optic SMF/LR)
GENERAL
PRINT MODES
1/1 – 4/4 – 1/0 – 4/0 + MICR
CONFIGURATION
Twin system, CMYK + MICR (option)
Speed versions: ColorStream 8160; ColorStream 8133
This is to make Misc appear on the page when needed.
Resources
Articles
Colorstream 8000 Series Brochure
05/13/21
1.05 MB
Colorstream 8000 Series Datasheet
05/13/21
374 KB
DISCLAIMERS
*MICR printing at 600 dpi
**Consumption per tower at typical printing conditions at 525 ft/min full color on 90 gsm media with 22” print width
***Paper Processing Unit
****Partly in combination with PRISMAproduction
 Return to Top
