Web Content Viewer
Actions
varioPRINT iX-series
Color Sheetfed Digital Presses
Features
More jobs. Shorter runs. Tighter deadlines. To stay ahead, commercial printers need a press that allows them to easily set up jobs, switch media, personalize and run 24/7 with minimal operator intervention. This is where the varioPRINT iX-series excels.
  • 312 ipm and more than 9360 4/4 letter sheets per hour
  • 4740 11 x 17 sheets 4/4 per hour
  • 4500 12 x 18 sheets 4/4 per hour
  • More than 94% uptime
  • All-in-one print platform with end-to-end automated workflow
  • Paper input capacity of up to 23,400 letter or 13,500 sheets any format
Thanks to many iQuariusiX innovations, the varioPRINT iX-series print quality rivals any other established print technology. It prints coated and uncoated media, up to 350 gsm with consistently high quality.
  • Innovative printheads and image processing
  • Intelligent nozzle activity and uniformity control
  • Print environment optimization and ink conditioning for optimal printing performance
  • Proprietary polymer pigment water-based iX inks and ColorGrip
  • High registration accuracy
  • Advanced color management
The varioPRINT iX-series excels in cost-efficient operation. How do attractive running costs sound? How do savings in labor and operations sound? Experience the varioPRINT iX-series, and enjoy more profit.
  • Attractive low running costs
  • More than 2x more productive than other B3 toner presses
  • High automation and minimal operator intervention
High-quality brochures that blow customers away with their color and detail. Sturdy postcards and direct mail pieces with targeted content. Books, versioned manuals, collateral, and catalogs. That’s what the varioPRINT iX-series delivers.
  • Offset coated media from 90 to 350 gsm
  • Uncoated media from 60 to 350 gsm
  • Mixed media during a run
  • Workflow automation
  • Wide choice of online connected finishing with open DFD interface
The foundation of the varioPRINT iX-series is an integration of highly innovative technologies that make it possible to:
  • Transport a wide range media.
  • Print at incredibly high speeds.
  • Produce stunning image quality
TECHNOLOGY
PRINT TECHNOLOGY Inkjet, Drop-on-demand, piezoelectric
INK Proprietary polymer pigment water-based iX inks
DROP SIZE Variable, MultiLevel
PRINT SPEED varioPRINT iX3200: 312 letter duplex images per minute 4740 11 x 17 sheets 4/4 per hour 4500 12 x 18 sheets 4/4 per hour
varioPRINT iX2100: 205 letter duplex images per minute
DUTY CYCLE varioPRINT iX3200: 1,000,000 – 10,000,000 letter impressions/month
varioPRINT iX2100: 1,000,000 – 7,000,000 letter impressions/month
PRINT RESOLUTION 1200 × 1200 dpi
PAPER
PAPER WEIGHT Uncoated: 60 - 350 gsm
Coated: 90 - 350 gsm
SUBSTRATES Commodity coated and uncoated papers including specialties
STANDARD CONFIGURATION 2 Paper Input Module (PIM Flex XL) 1 High Capacity Stacker
PAPER SIZES PIM Flex XL: All sizes between 8” x 8” and 13.78 x 20” supported
MAXIMUM PRINTABLE AREA 13.3 X 19.8
PAPER CAPACITY 3 PIMS x 4,600 sheets per PIM (13,800) 20 lb. bond
PAPER INPUT MODULE FLEX XL
PAPER TRAYS 2 × 600 sheets, 2 × 1,650 sheets (80 gsm)
STANDARD PAPER CAPACITY 4,500 sheets
PAPER SIZE Paper trays 1 and 2: 600 sheets 20 lb. bond 8 x 8 to 13.78 x 20
Paper trays 3 and 4: 1,700 sheets 20 lb. bond 8 x 8 to 13.78 x 20
DIMENSIONS (WxDxH) 37.2 x 34.8 x 44.4
WEIGHT 441 lbs
HIGH CAPACITY STACKER
STACKS 2 × 3,000 sheets (80 gsm) per stacker
DIMENSIONS (WxDxH) 36 x 30 x 43.2
WEIGHT 353 lbs
INTEGRATED CAMERA MOUNTING UNIT (OPTIONAL)
  Inline camera inspection
DIMENSIONS (WxDxH) 3.2 x 1.2 x 4.6
WEIGHT 448 lbs
PRISMASYNC CONTROLLER
NETWORK CONNECTIVITY
Internal: 1 x 10 Gbit Ethernet; External: 2 x 1 Gbit (10/100/1000 Base-T), TCP/IP (LPR /LPD, 9100 Socket), Static IP / Auto-IP (DHCP), IPv4, IPv6 (only in Document printing mode)
PAGE DESCRIPTION LANGUAGES PDF 1.7 (Extension Level 3), APPE DP mode is 5.4, APPE for TP mode is 4.9, PDF/VT (Level 1), Postscript, PPML 2.2, IPDS IS/3, SRA PCL6
JOB SUBMISSION
lpr, Hotfolders via WebDAV, Socket (streaming), JDF/JMF, IPP 2.0, Remote PDF Driver
PROTOCOLS SNMP v1, SNMP v3, Host Resources MIB, MIB II, Printer MIB, Job Monitoring MIB, Job Management MIB (partially), IEEE 802.1x
SPOT COLOR LIBRARIES PANTONE+ Solid (Coated & Uncoated), PANTONE GOE (Coated & Uncoated), HKS (K,N), HKS (K,N) 3000+ PANTONE+ Solid 336 New (Coated & Uncoated)
CONNECTION REQUIREMENTS
CONNECTION FUSE 230/400 VAC, 100A; 100-240 VAC, 13-20A; 100-240 VAC, 13-20A; 200-240 VAC, 13-20A; 100-240 VAC, 13-20A
POWER CONSUMPTION PRINTING 14.9 kW
POWER CONSUMPTION IDLE 7.1 kW
POWER CONSUMPTION SLEEP 0.9 kW
COMPRESSED AIR 5-12 bar, dry and oil free
WATER Reverse osmosis water system
ENVIRONMENTAL
TEMPERATURE Optimal range 20–26 °C
HUMIDITY Optimal range 30–50%
OPERATING NOISE Printing 72 dB, Standby 61 dB
PHYSICAL DATA
LENGTH x WIDTH x HEIGHT 33 x 9.2 x 7.3
WEIGHT Approximately 15,900 lbs. (main engine, 2 PIMs, 1 HCS)
OPTIONS
PAPER TRAYS Duo Paper Trays
HIGH CAPACITY STACKER Second High Capacity Stacker
INLINE FINISHING DFD interface SFD interface
PRISMAsync DPlink DocBox*
PRISMAlytics Dashboard*
PRISMAsync Simulator
PRISMAprofiler
* Included in Base Configuration
INTEGRATED CAMERA MOUNTUNG UNIT
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
