Canon Support for EOS C500 Mark II | Canon U.S.A., Inc.
EOS C500 Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
SELECT ERROR CODE
Sensor | Full-frame / Super 35mm (crop) / Super 16mm (crop)(6062 x 3432): CMOS Sensor with DAF Technology |
Signal-to-noise ratio | In the 59.94 Hz mode: 66 dB (Typical) [Full size/3840x2160/29.97P. Canon Log2 Base Sensitivity ISO 800 (Dynamic Range 1600%)] In the 50.00 Hz mode: 66 dB (Typical) [Full size/3840x2160/25.00P. Canon Log2 Base Sensitivity ISO 800 (Dynamic Range 1600%)] |
Dynamic Range | Canon Log 2: 1600% / 15+ stops (at ISO 800) Canon Log 3: 1600% / 14 stops (at ISO 800)02 |
Horizontal resolution | Depends on the lens used |
Sensitivity | 59.94 Hz f/10 (2048x1080/59.94P) or f/14 (1920x1080/29.97P) 50.00 Hz f/11 (2048x1080/50.00P) or f/16 (1920x1080/25.00P) 01 All values for ISO 800, 2000 lux, and reflections rate or 89.9% * Some lens specification may not enable these f-numbers |
Total Pixels | Approx. 20.8 Megapixels (6062 x 3432) |
Number of Effective Pixels | Approx. 18.69 Megapixels (5952 x 3140): When 5952 x 3140, 4096 x 2160 or 2048 x 1080 is selected Approx. 17.52 Megapixels (5580 x 3140): When 3840 x 2160 or 1920 x 1080 is selected as the resolution |
Lens Mount | Canon EF mount with support for EF and EF-S lenses Optional Interchangeable Mounts: PL and EF-C Locking |
Exposure Modes | (1) Manual exposure based on shutter setting, iris setting, ISO/gain setting and ND filter setting (2) Push auto iris control, auto iris control (Light metering system selection, shift possible) |
Shutter Setting | Speed, Angle, Clear Scan, Slow, or Off mode selected Either 1/3 or 1/4 steps selected as speed increment |
Iris Setting | Can be set to 1/2-stop, 1/3-stop or Fine (1) Push auto iris control (2) Auto iris control Lenses that support Auto Iris:
ISO/Gain | 1 step, 1/3 step settings [*100 - 160 - 25600 - 102400*] *When the sensitivity is expanded ISO Speed Displays: Users can select from the following 2 display formats:
Gain (dB) Displays
ND Filter | Internal ND filters with 5 density settings (2, 4, 6, 8*, 10* stops) *When expansion is selected |
Focus Control | Dual Pixel CMOS AF (DAF), Manual Focus, One-Shot AF, Continuous AF, AF- Boosted MF, Face Detection AF* * Only lenses that support AF functions can be used in these modes |
Focus Guide | Available; displays focus status or unfocused status using the AF signal. |
LCD Monitor | LM-V2 LCD Monitor |
White Balance | AWB, Kelvin setting (setting range: 2000K-15000K), Daylight, Tungsten, Set (A/B) |
Standardized Frame Rates | 59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P 50.00 Hz mode: 50.00i/50.00P/25.00P 24.00 Hz mode: 24.00P |
Slow and Fast Motion | If recording Is performed at a frame rate which is below the frame rate of the recording format, so-called "undercranking"
shooting results, and a fast motion effect will be obtained. Conversely, if recording is performed at a frame rate which
exceeds the frame rate of the recording format, so-called "overcranking" shooting results, and a slow motion effect will be obtained. During Slow and Fast Motion Recording external timecode input is not permitted and Timecode output is disabled. If Timecode "Free Run" was specified before S&F is selected, the setting switches to "RecRun." No sound is recorded.
RAWii
Cinema RAW Light HQ, ST, LT 12-bitiii
Setting Frame Specifics are shown below: 59.94P: (15, 30, 44, 48, 52, 56, 60, 90, 120) 29.97P (15, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 90, 120) 23.98P/24.00P: (12, 16, 18, 20, 22, 24, 26, 28, 30, 32, 36, 40, 44, 48, 52, 56, 60, 72, 96, 120) 50.00P: (15, 25, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120) 25.00P: (15, 17, 19, 21, 23, 25, 26, 28, 30, 34, 38, 42, 46, 50, 54, 58, 60, 75, 100, 120) |
CFexpress™ Cards (2 slots) | Recording of movies (Cinema Raw Light/XF-AVC), custom pictures, metadata
SD Card | Recording of movies (XF-AVC (proxy)), photos (JPEG), custom pictures, metadata, menus and other data |
Video | (1) XF-AVC/ MPEG-4 AVC/H.264 (2) RAW: Cinema RAW Light |
Audio | Linear PCM (24 bit - 48kHz; 4-channel recording) |
Resolution/Sampling | 4096 x 2160 / YCC422 10 bit 3840 x 2160 / YCC422 10 bit 2048 x 1080 / YCC422 10 bit 1920 x 1080 / YCC422 10 bit |
Bit Rate | 810/410/310/160 Mbps Intra-frame |
Resolution/Sampling | 2048 x 1080 / YCC420 8 bit |
Bit Rate | 35/24 Mbps Long GOP |
Bit Depth | 12/10 bit |
Resolution | 5952 x 3140 4096 x 2160 (cropped) 2048 x 1080 (cropped) |
Time Code | Drop frame* or non-drop frame * Only in the 59.94 Hz mode Rec Run, Free Run, Regeneration |
Gamma | Canon Log 3, Canon Log 2, Wide DR, Normal 1, HDR-PQ, HDR-HLG |
Color Space | Cinema Gamut, BT.2020 Gamut, DCI-P3 Gamut, BT.709 Gamut |
In-Camera LUTs | BT.709, BT.2020, DCI, ACESproxy, HDR-PQ, HDR-HLG, HDR1600%, HDR400%, and 4 user uploadable |
Other Features | Slow & Fast motion recording, pre-recording, relay recording, double slot recording, custom picture settings, color bar, peaking display, zebra display, My Menu settings, waveform monitor display, assignable buttons, key lock, marker display, enlarged display, custom display, control via browser remote, peripheral illumination correction, diffraction correction, built-in monaural microphone, fan control, geotagging and other functions |
Playback Operations | Normal playback, fast forward (at speeds of 5x), fast reverse (at speeds of 5x), frame forward, frame reverse, forward skip, reverse skip, rec review |
Clip Display | 3 x 4 (clip) index display (RAW, XF-AVC, XF-AVC proxy, photo index) |
Clip Information Display | Clip metadata display, custom picture data display |
Edit | Clip deletion |
Input | MIC jack, INPUT terminal (1/2)*, REMOTE terminal (A) * Digital input (AES/EBU standards) supported |
Output | HDMI, headphone jack, MON. terminal, SDI OUT terminal*, VIDEO terminal * 12G-SDI supported |
Input/Output Control | TIME CODE (in/out), Expansion System terminal, USB (for GPS units) * For the EVF-V50, EU-V1 or EU-V2 Expansion Units |
Power Input | DC IN 12V jack (DC 11.5V-20V), Battery terminal (DC 14.4V), DC 12-20V* * When using a V-mount battery with the EU-V2 Expansion Unit
Image Processing Platform | DIGIC DV 7 Image Processor |
Related Accessories | Battery Pack BP-A30/BP-A60 (provided with camera) Battery Charger CG-A10/CG-A20 (provided with camera) Remote Controller RC-V100 Compact Power Adapter CA-CP200B (provided with camera) Shoulder Strap SS-1200 (provided with camera) Tripod base TB-1 WFT-E9 Wireless Transmitter GPS Receiver GP-E2 Unit Cable UN-5 (provided with camera)/UN-10 (sold separately) Canon OLED Electronic View Finder EVF-V50/EVF-V70 Extension unit 1: EU-V1 Extension unit 2: EU-V2 Extension unit 3: EU-V3 EF Cinema Lock Mount Kit CM-V1 PL Mount Kit PM-V1 B4 Mount Adapter MO-4E/MO-4P LCD Monitor LM-V2 (included)/LM-V1 LCD Attachment Unit LA-V2 (included)/LA-V1 Camera Grip GR-V1 (included) Shoulder Support Unit SU-15 Shoulder Style Grip Unit SG-1 Clamp Base CL-V2 Rod Clamp RD-1 Handle Unit HDU-2 8-pin Remote Cable RR-10/RR-100 Canon EF/EF cinema lens group, Canon PL cinema lens group and accessories designed for these lenses |
IP Streaming | Streams video to decoder transmission device or computer over the network |
Compression Method | MPEG-4 AVC/H.264 8 bit |
Bit Rates | 9 Mbps/4 Mbps (1920 x 1080) |
Frame Rates | 59.94p/59.94i/50.00p/50.00i |
Audio | MPEG-2 ACC-LC 2ch |
Audio Rate | 256 Kbps |
Transfer Media | Wi-Fi®, Ethernet |
Protocols | (1) UDP: Prioritizes transfer speed. Lost or lagging packets ignored. (2) RTP: Standard system for sending videos and audio online. Lost or lagging packets ignored. (3) RTP+FEC: Error correction (FEC) control during RTP transfer enables recovery of lost or corrupt packets on the receiving side. (4) RTSP+RTP: Real-time data streaming control via RTSP (Real Time Streaming Protocol) and transfer via RTP. The receiving side can start or stop streaming. |
Standards | Follows the specifications for the WFT-E9 Wireless File Transmitter (optional accessory) |
Wi-Fi® Setup Methods | (1) WPS [Wi-Fi® Protected Setup] (push-button system, PIN code system) (2) Manual Setup (3) Search for Access Points |
Authentication Systems | Open system, WPA-PSK, WPA2-PSK |
Encryption | WEP-64, WEP-128, TKIP, AES |
IP Address Settings | Auto (automatic switching between DHCP and AutoIP), Manual |
Dimensions (W x H x D) | Approx. 6.0 x 5.8 x 6.6 in. (153 x 148 x 168mm) |
Weight | Approx. 3.8 lb. (1750g) |
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
- Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
- If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
- If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
- If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
- Any internal modification to product hardware or firmware;
- Any applicable fee for Maintenance of the Equipment;
- If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Color Calibration Service
Canon USA is now offering a comprehensive display color calibration service. Whether you operate in the film, post-production, broadcast, corporate or educational world, our goal is the same: to help ensure image fidelity.
Benefits
Calibration Services
This service supports both standard and high dynamic range (HDR) workflows, and ensures your device meets industry standard specifications (SMPTE, DCI, and ITU).*
What to Expect
Our Imaging Science Foundation (ISF) certified professionals will travel to your site to ensure that any calibration is tailored specifically to your viewing environment. During a calibration session, several key image quality elements will be measured including: white point, grayscale, primary and secondary color chromaticity, luminance and gamma.
Customized Service
For added flexibility, our team can perform calibrations on virtually any type of display technology. Whether it be a consumer grade PC monitor or professional reference display, our service helps ensure your panel is operating to the best of its ability.
Additionally, to remove any ambiguity of your display’s performance, clients will also be provided with detailed pre and post calibration reports.
Canon’s Color Calibration Service offers one-time calibrations, recurring service contracts, and customized training. For more information or to request a free consultation, please fill out the form below.
