Web Content Viewer
Actions
imagePRESS 1110S
Monochrome Sheetfed Digital Presses
  • Twin Sleeve Development:
  • A dual sleeve design that delivers toner to the photoreceptive drum. This design produces blacks that are solid and avoids uneven distribution of toner.
  • ITB:
  • The image transfer belt is responsible for transferring the latent image to the media. This is similar to how an offset blanket works on a offset lithographic press. The advantage is with this design it is possible to run thick stocks without the concern the stock will jam in the engine.
  • Paper Handling:
  • The imagePRESS 1110S has enhanced air assist technologies, through the main drawer, to ensure the reliable feeding. The suction feeding, enhanced air assist and air separation technologies provide reliable feeding and maximum productivity.
  • Image Quality:
  • With 1200 x 1200 dpi imaging technology, produce near lithographic halftone images, crisp text, full solids that are free from mottle and fine lines.
  • Accurate Registration:
  • With a tolerance of +/-0.5mm, the imagePRESS 1110S produces a professional looking product that is correctly aligned from front to back.
  • Media Versatility:
  • The imagePRESS 1110S has the advantage of being able to print accurately on thin and thick stocks. This press can print on the stocks as thin as 14lb. bond and as thick as 110lb. cover.
  • Durability:
  • This engine was designed with longevity in mind. The photoreceptive developing drum is composed of a very durable Amorphous Silicon, also known as a-Si. This material has a long life span of 6 million impressions.
  • Productivity:
  • The imagePRESS 1110S prints at rated speed on all uncoated LTR media. Regardless if you are printing on a 28lb. (LTR) bond media or a thick 110lb. (LTR) cover, the engine will print without a decrease in speed.
This is to make Misc appear on the page when needed.
Specifications
Model Name
imagePRESS 1110S
Imaging System
Laser Electrostatic Transfer System
Printing Resolution
Up to 1200 x 1200 dpi
Halftone
256-Level Grayscale
Letter
Simplex: 110
Duplex/Perfect: 55
Ledger
Simplex: 68
Duplex/Perfect: 34
Maximum Original Size
13 x 19.2
Standard Paper Capacity
2,000 Sheets (20 lb. Bond)
Maximum Paper Capacity
8,000 Sheets (20 lb. Bond)
Acceptable Paper Weights
Cassette
Uncoated: 14 lb. Bond to 110 lb. Bond Cover
Coated: 24 lb. Bond to 90 lb. Cover
Duplexing
Automatic Duplex/Perfect
Any Supported Stock
Power Requirements
208V/30A+15A
Dimension
54.12 x 54.62 x 31.87
Weight
1,103 lb.
Estimated Toner Yield
69,000 impressions at 6% coverage (LTR pgs)
Paper Supply Options
Description
Standard Side Paper Deck-AF1 (Opt.)
Paper Capacity
6,000 Sheets (2,000 x 3) (20 lb. Bond)
Paper Sizes
13 x 19.2
Paper Weights
Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays)
Coated: 24 lb. Bond to 90 lb. Cover (All Trays)
Power Source
120V/15A
Dimensions
43.25 x 38.75 x 81.37
Weight
331 lb.
Output Options
Finishers Output Trays
Description
Finisher-AG1/Saddle Finisher-AG2 (Opt.)
Paper Weights
Finisher: 14 lb. Bond to 110 lb. Cover
Saddle Finisher: 14 lb. Bond to 110 lb. Cover
Paper Size
Stapling: Executive, Letter-R, Letter, Legal, 11 x 17
Sheet Stacking: Up to 13 x 19.2
Saddle Finisher: Letter-R, Legal, 11 x 17, 12 x 18, 13 x 19
Number Of Trays
3
Top Tray
250 Sheets (20 lb. Bond)
Middle Tray
1,500 Sheets (20 lb. Bond/Letter)
Lower Tray
2,500 Sheets (20 lb. Bond/Letter)
Saddle Stitch Tray
25 Booklets
Staple Positions
Corner-Stapling, Double-Stapling
Stapling Capacity
Up to 100 Sheets
Max. Booklet Stapling Capacity: Up to 20 Sheets Saddle-Stitched
Power Source
120V/15A
Dimensions
Finisher-AG1: 41 x 25.75 x 30.12
Saddle Finisher-AG2: 41 x 30.25 x 30.12
Weight
Finisher-AG1: 130 lb.
Saddle Finisher-AG2: 234 lb. Puncher Unit-BF1 (Option for Finisher-AG1/Saddle Finisher-AG2) (Opt.)
Acceptable Paper Weight: 14 lb. Bond to 140 lb. Index
Paper Sizes
2-Hole: Legal, Letter-R
3-Hole: 11 x 17, Letter, EXE
Punch Speed: Up to 110 ppm
Power Source: From Finisher
Weight: 8.2 lb. Inner Booklet Trimmer-A1 (Opt.)
Margin Trimming: Fore-Edge Trim
Trim Amount: 0.08 to 0.78
Trim Thickness: 20 Sheets
Acceptable Paper Weight: 14 lb. Bond to 110 lb. Cover
Power Source: From Saddle Finisher Professional Puncher and Integration Unit-B1 (Opt.)
Paper Size: Letter
Supported Media Weights: 20 lb. Bond to 80 lb. Cover
Productivity: Up to 135 ppm (Depends on Speed of Marking Engine)
Chip Tray Capacity: 25,000 Sheets
Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb
19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H
Power Source: 120V/15A
Dimensions (H x W x D): 41 x 22.5 x 31.25
Weight: 258.2 lb.
Document Inserters
Description
Document Insertion Unit-F1 (Opt.)
Paper Weight
Paper Sizes
13 x 19.2
Feeder Capacity
400 Sheets (200 x 2) (20 lb. Bond)
Dimensions (H x W x D): 55.37 x 29.37 x 31.25
Weight: 122 lb.
Power Source: 120V/15AColor Image Reader-L1 (Opt.)
Image Sensor: CMOS
Document Size: Statement to 11 x 17
Resolution: 600 x 600 dpi, 256 Gradations
Dimensions (H x W x D): 2.8 x 25 x 23.2
Weight: 26.5 lb.
Power Supply: From Main Unit DADF (Duplex Automatic Document Feeder) (Opt.)
Tray Capacity: 300 sheets (20 lb. Bond)
Scanning Speed B/W: Up to 200 ipm (300 dpi)
Up to 120 ipm (600 dpi)
Scanning Speed Color: Up to 80 ipm (300 dpi)
Up to 40 ipm (600 dpi)*
Acceptable Original Size: Statement to 11 x 17
Acceptable Paper Weight: 14 lb. Bond to 120 lb. Index
Dimensions (H x W x D): 7.12 x 25 x 23.12
Weight: 59.3 lb.
Power Source: From Main Unit
Paper Folding
Description
Paper Folding Unit-F1 (Opt.)**
Paper Weight
14 lb. Bond to 28 lb. Bond
Fold Type
V-fold: Letter-R
Z-fold: Legal, 11 x 17, Letter-R
C-fold: Letter-R
Zigzag Fold: Letter-R
Dimensions (H x W x D): 46.87 x 13.25 x 31.25
Weight: 144 lb.* System Upgrade RAM-B1 required for 600 dpi color scanning
** Requires either the Finisher-AG1 or the Saddle Finisher-AG2
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imagePRESS 1110S that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imagePRESS 1110S / 1110P / 1125P / 1135P Series Configurator.
imagePRESS 1100 Digital Press Series Customer Testimonial
  • Click here to view the Essential Business Builder Program Customer Testimonial
  • Click here to view the Essential Builder Testimonial
  • Click here to view the Canon "Protecting Your Environment" In-Brief Video
Brochures
Loading...
 Return to Top
