Product Discontinuation Notice – 3D Machine Visions Systems RV Series
Please be advised that Canon U.S.A., Inc. (“Canon”) plans to discontinue sales of its 3D Machine Visions Systems RV Series (RV-1100, RV-500, and RV-300) by November 15th. Customers who are currently using these products or considering additional purchases are encouraged to contact Canon or their authorized Canon representative for details regarding final order availability. Repair and maintenance support is currently planned in accordance with Canon’s standard policies and subject to parts availability. Information pertaining to how to acquire part parts, service and support for the 3D Machine Visions Systems RV Series can be found at www.support.cusa.canon.com.
Thank you for your continued support.
3D MACHINE VISION FOR RANDOM BIN PICKING
3D random bin picking is a challenging area in manufacturing industries that has perplexed engineers for years.
To meet this challenge, Canon has aimed for and created a solution that utilizes Canon's leading optical and processing technologies. The installation is simple, yet the system is sophisticated. It automatically recognizes parts, determines the best pick candidate, and calculates the most optimal path so that the robot can safely, but surely, pick up the part and move it to its desired destination. It is a complete solution for random bin picking on any production floor.
Random Bin Picking in Mass Production
Canon’s advanced 3D Machine Vision guides a robot to pick and place resin molded printer parts which are randomly piled in mass production line.
SIMPLE FLOW OF AUTOMATION
Incorporating the Machine Vision system into your production line is easy. Setup is simple with the use of user-friendly software. Simply dump the parts into a bin and hit the start button. The system will search for the best pick candidate from the pile based on your application. Your robot, fully integrated with Canon's Machine Vision system, then automatically picks the part and places it, getting you ready for the next process with ease.
1. SETUP
BIN
PART
GRIPPER
GRASP
2. 3D SCAN
Quick Process
3. RECOGNIZE
Precise CAD Fitting
4. PICK
Sophisticated path planning and collision check algorithms
5. PLACE
No additional scan needed due to precise recognition
PROVEN RECORDS IN MASS PRODUCTION
Car Door Panel
1.4x1.7m/4.6x5.6ft
Metal Plate
Use HDR* for easy recognition of glossy parts
Lid
3mm/0.12in
Use "Recognize as Thin Work” capable of 4mm/0.16in or less (RV300)
Hexagon Bolt
320mm x Φ 16mm
Cable Clamp
24mm/0.9in Width
Minimum size 10x10mm/0.39x0.39in (RV300)
VIDEOS
OPTIONAL SOFTWARE
SYSTEM CONFIGURATION
For the PC: Windows 7, 8.1, or 10 or 11 Professional, along with an nVidia GeForce graphics card and Intel Gigabit network LAN card, is required. Please contact Canon for the most up-to-date PC requirements.
MEASUREMENT AREA
SPECIFICATIONS
RV Series
| RV300
| RV500
| RV1100
| RV1100+ Option
Measurement area
H x W x D | 340 x 340 x 100 mm (13.4” x 13.4” x 3.9”) | 540 x 540 x 200 mm (21.3” x 21.3” x 7.9”) | 1160 x 1160 x 600 mm (45.7” x 45.7” x 23.6”) | See the red framed trapezoid area. |
Minimum recognizable part size
| 10 × 10 mm (0.39” x 0.39”) | 20 × 20 mm (0.79” x 0.79”) | 45 × 45 mm (1.77” x 1.77”) | 50 × 50 mm (1.97” x 1.97”) |
Recognition time *
| 1.6 sec | 1.6 sec | 1.8 sec | 1.8 sec |
Dimension of 3D Machine Vision Head
| 252 x 206 x 129 mm (9.9” x 8.1” x 4.9”) | |||
Weight of 3D Machine Vision Head
| 6.5 kg (14.3 lb) | |||
IP Rating
| Equivalent to IP54 | |||
Operating Temperature
| 0 – 45°C (32 – 113°F) | |||
3D Machine Vision for Random Bin Picking
Canon has created a solution that utilizes leading optical and processing technologies.
